Old 23rd October 2017, 19:53   #1
Thanked: 58 Times
Default Force Gurkha: Tyre Upsize & Lift
Hello,
I am thinking of purchasing the new Gurkha Explorer and would like to get some information on Tire Size Upgrades.
Is installing a 2" lift straightforward, and are kits available in India?
Will a size similar to 33/12.5R16 fit without needing any other modifications?
Will upgrading to a size like this negatively impact power, drive-ability and any on/off-road performance?
Thank you for help in advance!
bolbolerobol is offline   Reply With Quote
Old 23rd October 2017, 20:20   #2
Jaggu's Avatar
Thanked: 8,858 Times
Default re: Force Gurkha: Tyre Upsize & Lift
Gurkha suspension is front coil springs right? If so finding a lift kit will be a pain. Clearance was never a big issue with Gurkha, issue was always power to weight ratio which made the hard tops handful in offroad situations.
Will a size similar to 33/12.5R16 will fit without needing any other modifications?
Going one size up should not cause major issues. What is the stick size?
This depends on how much difference in circumference you are ending up with upsize, a 2% difference will not cause great drop in performance as a thumb rule.
Jaggu is offline   (2) Thanks Reply With Quote
Old 25th October 2017, 09:28   #3
dhanushs's Avatar
Thanked: 4,530 Times
Default Re: Force Gurkha: Tyre Upsize & Lift
Your best bet would be to install a body lift kit. Not suspension lift. That'll keep the dynamics in check too.
No idea.
Will upgrading to a size like this negatively impact power, driveability and any on/off-road performance?
Your gearing will go high. You will feel a loss of initial power. But, the Mahindra MDI handles it pretty well, so, the Ghurha should also cope with it. The high-speed performance will increase.
dhanushs is offline   (2) Thanks Reply With Quote
Old 25th October 2017, 16:12   #4
Thanked: 58 Times
I believe the stock size is 245/70R16.
Thank you!
Old 26th October 2017, 10:35   #5
Jaggu's Avatar
Thank you!
Wow that is more than +11.9% increase, gearing will surely go for a toss. On road in high speed ratio would go for a toss for sure. Not really worth it if you ask me..
Buying a Force Gurkha!! Monster_BHP SUVs, MUVs & 4x4s 87 15th July 2016 23:25
Force Gurkha on sale again. Launched @ 6.25 Lakhs GTO The Indian Car Scene 447 16th July 2015 13:43
SCOOP Pics & Video - 2013 Force Gurkha satya180 The Indian Car Scene 62 16th February 2013 08:49
Pre-Release Test Ride : New Gurkha 4x4 @ Force Motors Pune mohan 4x4 Vehicles 97 16th February 2013 08:47
Force Gurkha on sand! Monster_BHP 4x4 Excursions 48 5th September 2008 18:04
