Old 6th February 2018, 13:07   #1
Thanked: 11 Times
Default Help needed - Toyota B Engine upgrades
Fellow Jeepers and BHPians,
I'm running a Toyota B Engine on my 1986 Land Rover Defender 90. So far the engine has about 1800km on it. However, I'm in the process of rebuilding the car, I'd like to change or add the following components:
- A Turbocharger (although this engine is a monster, I'd like to make it even more terrifying)
- AC compressor (current compressor, when running, makes odd noises, and produces a burning smell, so I pretty much refrain from using it)
Engine Specifications:
3.0 L inline-four eight-valve OHV diesel engine. Compression ratio is 21:1. Output is 80 hp (60 kW) at 3,600 rpm with 141 lbft (191 Nm) of torque at 2,200 rpm.
The car and me are based in Bombay, and I'm looking for any help/guidance with regard to your knowledge of this engine.
Thanks in advance!
kilopapa93 is offline   (2) Thanks Reply With Quote
Old 6th February 2018, 14:20   #2
Thanked: 778 Times
Default re: Help needed - Toyota B Engine upgrades
Hi!
Not an authority on this subject, but from whatever little experience I have of old diesels, I think you are looking at not just a Turbo, but you'll need oil cooler, intercooler, and a exhaust temp gauge.
Look up NA or European forums for old Chevy diesel conversions and you'll get an idea.
I hope some others on the forum have some experience in this.
roy_libran is online now   (2) Thanks Reply With Quote
Old 6th February 2018, 14:31   #3
Thanked: 3,955 Times
21:1 compression ratio might be a little high if you want to turbo it. Look at turbo (BT) engines in the B engine family to see if you can use parts from BT engines to lower the compression and go turbo.
Sankar is offline   (2) Thanks Reply With Quote
Old 6th February 2018, 17:49   #4
Thanked: 11 Times
Definitely sounds like more work than I'm set out to do, I'll see if I can find some workarounds.
Probably going to scour Opera house for these. Now I've gotta figure out how to make the tachometer work..
kilopapa93 is offline   Reply With Quote
Old 7th February 2018, 10:33   #5
Thanked: 94,898 Times
Default Re: Help needed - Toyota B Engine upgrades
Since you are from Mumbai, I would suggest you get in touch with Allan Almeida. He's a 4x4 master, has a workshop in Navi Mumbai and lots of experience with Land Rovers (thread 1 & thread 2). You can also see some of his work on this page.
GTO is offline   (1) Thanks Reply With Quote
Help needed : Toyota Corolla 2004 Random Startup problem singh.amrit Technical Stuff 15 21st December 2016 12:45
Toyota upgrades the Corolla Altis in Thailand and Malaysia Vid6639 The International Automotive Scene 16 30th November 2010 20:50
1985 toyota corolla estate bought.Help needed! iceman1 Technical Stuff 4 10th March 2010 10:54
help me with performance upgrades on a m800 noidaboy Modifications & Accessories 37 17th June 2009 19:39
Minor Engine upgrades for Zen Lxi (suggestions plz) jatt_ambersaria Modifications & Accessories 26 15th April 2007 00:57
