Old 27th November 2014, 11:30   #1561
Shubhendra's Avatar
Thanked: 1,181 Times
Default re: The Offroad Rims & Tyres Thread
Originally Posted by sheelz View Post
I want tyre which can enhance the look of the vehicle. Mostly it will be driven on road. Thanks.
you can go as big as 31 inches on 15 inches rims/alloys or 265 on 16 inches rims/alloys. If you are going to take it to offroad rarely than buy a good set of AT tyres. for more information, go through this thread, you will get most of your answers......
Shubhendra Singh
Shubhendra is online now   Reply With Quote
Old 27th November 2014, 22:57   #1562
sheelz's Avatar
Thanked: 28 Times
Thanks shubhendra Singh. Can you suggest a suitable make along with a mag/rim make keeping in mind pcd odd MM540. Thanks. The vehicle is without power steering.
sheelz is offline   Reply With Quote
Old 28th November 2014, 02:09   #1563
Thanked: 85 Times
Would these tyres be suitable for use on a MM550 or Thar?
Live To Jive is offline   Reply With Quote
Old 28th November 2014, 11:27   #1564
predatorwheelz's Avatar
Thanked: 1,120 Times
Yes, in the 7.50 16 size.
predatorwheelz is offline   (1) Thanks Reply With Quote
Old 17th December 2014, 12:12   #1565
Rattler's Avatar
Thanked: 41 Times
Default Re: All T-BHP 4x4 JEEP Pics!!
Hi L.o.R,
The 35 inch tall tyre would definitely reduce both approach and departure angles. Because of the size, the steering lock positions on either side will have to be re adjusted so that the tyre doesn' brush against the wheel well / fenders. In my opinion, the turning radius of the Jeep will go up by at least 15% with the 9.00x16 size tyres. (Jeep Guru's please enlighten us on this)
Using of spacers can solve this problem but, they are not recommended for OTR activity.
Best regards,
Sudhir.
Rattler is offline   Reply With Quote
Old 17th December 2014, 13:39   #1566
Originally Posted by Rattler View Post
Hi L.o.R,
Best regards,
Sudhir.
Sudhir,
I am glad you brought up turning radius and track width into this discussion.
I would not want to use spacers, especially in a vehicle meant for off road use. But having said that, what about using axles that are wider that the stock axles?
For example, load carriers such as Tata 407 Etc. do coming in 4X4 Avatars and the track width of such vehicles would be roughly be about 62 inches give or take a couple of inches.
Any thoughts?
L.o.R
lifeoffroad is offline   Reply With Quote
Old 17th December 2014, 20:29   #1567
Rattler's Avatar
Thanked: 41 Times
Originally Posted by lifeoffroad View Post
Sudhir,
Any thoughts?
L.o.R
I won't be able to comment on this L.o.R. I suggest that you take expert opinion on this issue. Having wider axils that of a Tata 407 along with bigger tyres will drain the torque of the original Jeep engine due to the dead weight hence, may require a bigger engine transplant, mated to a transfer case etc, etc.
Best regards,
Sudhir.
Old 18th December 2014, 01:27   #1568
Best regards,
Sudhir.
Thanks for all your input so far Sudhir,
@JeepGuru's:
Please help me list the pros and cons of using a larger axle, say from a Tata 407 4X4 or any such vehicle in a Jeep.
In US terms, this would be the move from lets say a Dana 40 to a Dana 60 axle.
Please bear in mind that the same would be used with 35+ inches tyre and the torque loss because of the same would be accounted for.
Thanks,
L.o.R
Old 18th December 2014, 11:14   #1569
Shubhendra's Avatar
If i am not wrong Tata 407 also use Dana 44 axles.
Shubhendra
Old 18th December 2014, 20:09   #1570
dhanushs's Avatar
Thanked: 4,473 Times
Could you please explain how?
In a 48" and 51" axle, yes. But, these should be just fine in a 57" Ball Joint type axles (Mahindra Bolero, Camper, NGCS Pick Up etc..)
In offroad, when speeds are very less could you please explain why they are not recommended?
Wider axles wont require a more powerful engine. But bigger OD tyres will change the overall gearing, and will require a final drive ratio change. Nothing else.
If you just need wider axles, go for 57" ones. And to account for larger tyres, change the final drive ratio. Lots of combinations available. You will be good to go.
Old 19th December 2014, 02:50   #1571
Hi Dhanushs,
Thank you for the information. I was looking towards the 407 axles because the Jeep in question would have a SPOA suspension setup and wider axles would help to compensate for the increased height.
Also,
I have seen the internals for this axle and the half shaft are definitely beefier than that of a Jeep and also, it is a four pinion design, fully floating in the rear.
This added strength should help when it comes to the added stresses with respect to the lower gearing that would be needed.
Thanks,
L.o.R
Old 13th January 2015, 16:02   #1572
sheelz's Avatar
Thanked: 28 Times
Hi.
I have recently bought mm540. Planning to change to alloys size 10j and Tyre size 31x10x15. Just wanted to know if it's OK. And whether it will make steering hard?
Old 13th January 2015, 16:15   #1573
Shubhendra's Avatar
Hi Dhanushs,
Also,
Thanks,
L.o.R
Why you need axles of Tata 407 ? Jeep axles are very strong and its RARE to break them. I hope you will find below information useful.
This information was posted by none other than Jeep expert Arka on a different portal (4wd4all.com)
The Tata 407 Specs
Front - Steyr-Oerlikon Type with 4.6:1 Ratio CV Axle & 4 Pinion Carrier. Left Off-Set
Rear - Steyr-Oerlikon Type with 4.6:1 Ratio & 4 Pinion Carrier FFRA with Centre Diff.
T-Case - Steyr-Oerlikon with 2H-4L Single Speed Divorced T-Case (2.02:1)
Shubhendra Singh
Old 15th January 2015, 05:33   #1574
The Tata 407 Specs
Shubhendra Singh
Hi Shubhendra Sir,
I completely agree about the strength of the Fully Floating Jeep axles but having said that, the strength is relative.
With the increase in tire size and additional torque/gearing, the chances of failure do increase.
The consideration of a axle from a higher payload vehicle was to negate this and ensure reliability.
Thank you for the information though.
L.o.R
Old 15th January 2015, 11:19   #1575
Shubhendra's Avatar
SIR,
we are talking very relative here, what tyre size you are planning to fit ? What engine ? torque rating ? etc. etc.
If you are planning to use tyre within 35", you are good with existing Mahindra Diffs, think about Propeller shaft and start joints which WILL snap out in every opportunity they get (telling by experience, no google knowledge)
SHubhendra Singh
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
