Old 23rd May 2016, 14:28   #1606
antihero's Avatar
Thanked: 147 Times
Default re: The Offroad Rims & Tyres Thread
Originally Posted by Sawyer View Post
Yokohama Geolandars AT; available in the 215 size. Excellent tyre for Gypsy.
@Sawyer Good price decent specs, but will the sidewalls handle the kind of terrain i frequent is a point to ponder...
antihero is offline   Reply With Quote
Old 23rd May 2016, 15:44   #1607
Thanked: 1,334 Times
I don't think that is a problem. If at all there is one, it will happen if you have to move through sections where sidewalls grazing against adjacent to sidewall terrain cannot be avoided. Few radials will cope with that kind of abuse.
Isolated examples of sidewalls so damaged can be obtained for any tyre in use.
Sawyer is offline   (1) Thanks Reply With Quote
Old 13th June 2016, 09:49   #1608
antihero's Avatar
Thanked: 147 Times
Been running Aeolus CrossAce AS01 (215/75/15) on a friend's MG410W since Nov2016. Its been a very good winter tyre so far. We haven't had more than 6 inches of snow and ice this winter but the grip levels are good. Detailed review as we spend more time on them. Available through online platforms and via their own website
antihero is offline   (1) Thanks Reply With Quote
Old 26th July 2016, 18:42   #1609
DrivingNirvana's Avatar
Thanked: 46 Times
Dear members,
I want to change the tyres of my new Scorpio S4+ 4wd which came with factory fitted Apollo Aptera. I want to invest in a good set of AT tyres. The factory fitted tyre is of 235/65 R 17. I do not want to change the rim diameter and am looking for options in 17 inch only.
Looking forward to your suggestions, friends.
Saubhik
DrivingNirvana is offline   Reply With Quote
Old 29th July 2016, 23:30   #1610
Vikram Arya's Avatar
Thanked: 353 Times
Originally Posted by DrivingNirvana View Post
Dear members,
Saubhik
My money would be on Bridgestone Dueler D684. They are a little expansive but are one of the best tires out there in this size. My wife has these tires (235/60 R18) on her Santa Fe and she has put 43,000 kms but they look as if they are just a year old. Ride comfort is superb and grip in rains/light snow is also good. Though this is an H/T tire and not an A/T the tread pattern is fairly reasonable for regular highway use; please note that an overly aggressive pattern will result in excessive road noise & harsher ride.
My second recommendation would be the Goodyear Wrangler AT/SA. This is also a good tire for this application.
I have Michelin Latitude on my Ford Edge & I find the ride too harsh which is surprising as these are supposed to be premium tires. Other Michelin users may want to chime in on these.
You may also want to look at Hankook Dynapro HP, Hankook has a great reputation among SUV tire users but I don't have any personal experience with these.
Vikram Arya is offline   (1) Thanks Reply With Quote
Old 24th September 2016, 23:03   #1611
cool_dube's Avatar
Thanked: 372 Times
Default Re: The Offroad Rims & Tyres Thread
Hello friends,
My new Gypsy King should be getting delivered in another week or so, and I intend to swap the OE nylon tyres with A/T radials ASAP. I have zeroed in on 2 options for the same:
a) Yokohama Geolander
b) Continental ContiCrossContact
Any pointers / feedback to help me finalize would be highly appreciated.
Best regards...
cool_dube is offline   (1) Thanks Reply With Quote
Old 25th September 2016, 08:52   #1612
cool_dube's Avatar
Thanked: 372 Times
Further to the post above - if anyone wants the OE tyres, please let me know. I'd prefer giving them to a TBHPian any day - sweet deal guaranteed :-)
cool_dube is offline   Reply With Quote
Old 27th September 2016, 17:26   #1613
sriny_blr's Avatar
Thanked: 49 Times
I got Pirelli Scorpion ATR for my MM550 and it's pretty good. Seems a notch above Yokohama which was on my MM550.
sriny_blr is offline   Reply With Quote
Old 2nd October 2016, 00:15   #1614
cool_dube's Avatar
Thanked: 372 Times
How much did they cost? Can you please share some pics?
Also, can anyone tell me if the OE tyres on the Gypsy - MRF Estate - are tubed or tubeless?
Old 9th October 2016, 17:55   #1615
sriny_blr's Avatar
Thanked: 49 Times
Attached pics of Pirelli scorpion ATR. I paid 25600 for 4 tyres at Millivisions
Old 12th February 2017, 00:34   #1616
Bump-Stop's Avatar
Thanked: 45 Times
Hi, I have some queries with regard to brand new 15x7J steel rims (offset -30) for my gypsy.
Intention is to finally go with 30x 9.5 tyres, to compensate for a 4.16 transfer case gearing.
1. Would fitting my current 215/75s on them be an issue until I get the 4.16 gears installed?
2. Would it be prudent or necessary to carry out balancing after fitting the tyres to the new wheels?
3. Any comments on the offset ( too much , stress on CV joints etc.) Or will the stock axle withstand the additional force generated due to this and also from the larger tyres
4. What about re- allignment?
Brgds
Ronnie
Bump-Stop is offline   Reply With Quote
Old 14th March 2017, 12:37   #1617
ringoism's Avatar
Thanked: 1,249 Times
Originally Posted by ex670c View Post
The newer NDMS made by Birla, Ceat & Goodyear have cleats running parallel to the centre rib, results in much better performance on wet roads.
Like I mentioned OTR there is no Tyre in the Indian Market which can beat it.
Arka, isn't clearing/cleaning a problem with the extra, isolated void left between that parallel cleat and the center rib? It would seem as though thick clay/mud could get stuck there unless rotational speeds were pretty high. Obviously you lose a little in terms of total lateral edge area (and thus fore/aft grip), too. As with everything, tyre design & application always involves compromises.
Also wondering whether anyone had ever seen these:
Found them in Mizoram (where clayey soil is a major challenge during monsoon). Heavy ply rating (12-14?), so bit hard/heavy but otherwise basic tread design looks like it'd do the job. Road performance not likely to be a lot better than NDMS, though the centerline is a bit broader. Branded as SUPERKING, which I've not researched, but made/sold in India. Reasonable price (typical of cross-ply 6x16).
Interesting, I thought. Bet they'd make brilliant snow tyres for our Marshal.
-Eric
ringoism is offline   Reply With Quote
Old 14th March 2017, 14:36   #1618
Sheel's Avatar
Thanked: 4,977 Times
Any of you have experienced the Goodyear Wrangler AT/SA tires?
They are made in India and I hope, that, it doesn't make it inferior in any way [because of less strict norms & careless attitude of manufacturers towards India]
Old 20th August 2017, 18:50   #1619
delix's Avatar
Thanked: 17 Times
My recent experience with tyre upgrade for my day old duster awd has not been pleasant. Updgraded to Maxxis 777 AT (235/60 R16) against stock wanderer sport (216/65 R16). The car started pulling to left. I got the alignment checked, but everything was okay. Finally, I requested them to take back the Maxxis and reinstall the stock after 7 days of ownership, to which they kindly agreed. They gave me back my money as well. Please note that the load ratings for the stock and the upgraded Maxxis were 98H and 104H respectively. Now I am contemplating to buy a new set of rubber for my duster.
delix is offline   Reply With Quote
Old 2nd September 2017, 21:06   #1620
hiran77's Avatar
Thanked: 51 Times
Guys please suggest a good A/T tyre for duster AWD. would prefer a slight increase in the wheel size to increase ground clearance. Which upsize would fit the duster AWD? Also my usage is more on road. Very less off-road. But I still want the next set of tyres to be better than the stock tyres. Since stock are more for on road and not off road. Minor compromise on on road manners is ok. Also I do not want uneven tyre wear or other issues due to the upsize. Please suggest
hiran77 is offline   Reply With Quote
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
