Old 11th December 2008, 10:55   #151
khan_sultan's Avatar
Thanked: 3,466 Times
Best bet -- for both on/off road:
Yokohoma Geolander A/T 235/75/15
See them here in a Classic:
http://www.team-bhp.com/forum/attach...g-img_0293.jpg
Cheers,
khan_sultan is offline   Reply With Quote
Old 11th December 2008, 11:23   #152
Samurai's Avatar
Thanked: 14,538 Times
Here is a clearer picture.
http://www.tirerack.com/images/tires..._s_bw_1000.jpg
Although I do have a question here. How safe is a tubeless tyre on steel rim for offroading purpose? Should one consider putting tubes into tubeless tyres for using with steel rims?
Old 11th December 2008, 13:19   #153
... Although I do have a question here. How safe is a tubeless tyre on steel rim for offroading purpose? Should one consider putting tubes into tubeless tyres for using with steel rims?
I would have no issues on putting it on steel rims BUT would for sure would put tube into them for added precaution. (This is what I would do. Is this correct/not correct I don't know)
This reminds me that both Prithvi & Mukund are having tubeless on their steel rims. Need to check with them if they are having tube in them or just the tyre.
Cheers,
Old 11th December 2008, 15:04   #154
iraghava's Avatar
Thanked: 154 Times
It's quite safe as long as the steel rims are not rusted or bent. Instead of putting in a tube & defeating the whole purpose of the tubeless, it's better you carry a spare tube with you which can be used in case you guys bend a rim or something.
SYJ - You're not getting traction because your tyres are worn out & nearly bald.
Old 11th December 2008, 15:47   #155
razor4077's Avatar
Thanked: 252 Times
If the car is driven mainly in the city with the occassional off roading jaunt, are these still the best bet? Or will they be unsuited for extended use on tar/concrete?
Also, any idea how much these cost, say in a 235/75/15 size?
razor4077 is offline   Reply With Quote
Old 11th December 2008, 15:54   #156
I think that they should be good for on-road also. By definition, A/T should perform equally good on both on/off road (with a little bit of compromise on both ends).
I have heard in my jeeper circles that these Geo's are the best bet currently in the A/T arena.
Not so good reviews about the BFG A/T ones from the ones who have them on their jeeps.
I think the size you mentioned costs somewhere around ~5.2K
Cheers,
Old 11th December 2008, 22:48   #157
SYJ
SYJ's Avatar
Thanked: 33 Times
Cheers,
can i go for 255/75/15. and btw do you have any idea the price for a tyre..??
SYJ is offline   Reply With Quote
Old 12th December 2008, 00:52   #158
tsk1979's Avatar
Thanked: 15,684 Times
I undestand HT is highway tires
What is AT? All Terrain
AT-S is ..?
And whats RT? Rural Terrain?
Old 12th December 2008, 09:41   #159
Yes of course. you can go for the 255 also but that MAY require some changes/alterations to suspension, fenders etc to prevent the tryes from touching the body and during steering/turning.
With 235/ you have almost NO such issues.
The cost for 255/ is approx ~6K IIRC.
Cheers,
Old 12th December 2008, 09:52   #160
SYJ
SYJ's Avatar
Thanked: 33 Times
Cheers,
so wht with the 235 ones.??is the wire wheels suitable for offroads.??
Old 12th December 2008, 10:07   #161
whicked wheels's Avatar
Thanked: 56 Times
Here are some tyres that we have on our jeeps.
FJ40- TSL mud swampers- dont know the size.
mm540- Maxiss Teropedo - 35x11.5-15: rs18,500/- EACH
mm540- Maxiss Mudzilla - 33x10.5-15; rs 10,200/- EACH
whicked wheels is offline   Reply With Quote
Old 12th December 2008, 10:34   #162
DirtyDan's Avatar
Thanked: 747 Times
Good idea. I carry 2 spare tyres and wheels and one time I actually needed both. Another argument for the mm540, more room for stuff like this. I would not use tubes in a tubeless. I suspect all AT tyres will be limited in their capacity to void mud. For my little Himalayan adventures AT tyres are my compromise choice.
Goodyear has one for sale in India. I have no idea how it performs or its price but Goodyear has a decent reputation. Picture looks good but I have not seen the actual tyre. Anybody know anything about it?
Wrangler AT/R
I am wondering if the light weight of the Gypsy and mm340 offsets to an acceptable degree the inherent excessive wear that hwy usage can do to off road tyres.
Old 12th December 2008, 20:16   #163
Originally Posted by DirtyDan View Post
...Goodyear has one for sale in India. I have no idea how it performs or its price but Goodyear has a decent reputation. Picture looks good but I have not seen the actual tyre. Anybody know anything about it?
Wrangler AT/R
One of the fellow Gypsy owner has this very tyre on his Gypsy. Must say that for a light weight Gypsy this performs quite well -- I have personally seen it perform quite well in mud.
For example, if you remember the coorg OTR where the Gurkha got stuck, this MG410 Gypsy with the wranglers was able to get the front 2 tyres on the other side on it's own and was just about to make it.
He has the 255 size on STOCK gypsy rims and does NOT use a tube in them.
Cheers,
Old 12th December 2008, 20:52   #164
badboyscad's Avatar
Thanked: 154 Times
Pics of Goodyear wrangler AT/R(s) on my Scorpio(2WD).Quite good performers.
badboyscad is online now   Reply With Quote
Old 15th December 2008, 08:48   #165
DesertKing's Avatar
Thanked: 18 Times
The tyre of my Jeep is Goodyear Wrangler RT/S 31 x 10.5 R 15. I want to understand what is RT/S. Can anybody pls help. Also printed 2 plied side wall, which means they are for off road use for sure.
DesertKing is offline   Reply With Quote
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
