Old 30th December 2008, 12:01   #196
Samurai's Avatar
Thanked: 15,708 Times
Originally Posted by khan_sultan View Post
. The classic 3 spoke 'rally' design on 15" is available for 4K. I just got a quote from a dealer. Available in 7J and 8.5J
Cheers,
What is the offset on these wheels?
Old 30th December 2008, 12:09   #197
sreerajunnithan's Avatar
@Samurai, I have seen a different kind of wheels on Sanker's MM540. Jammy can shed more light on the price part of it. I was thinking that Shankar changed his PCD, but later on Jammy told that this is the new design comes for 139.7 Jeep PCD. They bought it from Bangy, you can call Jammy and aks about it. Unfortunately i do not have any pictures. But it suerly looks nice and very strong also.
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 30th December 2008, 15:09   #198
Samurai's Avatar
I am eyeing these rims, they go well with CJ340 Jeep.
Old 30th December 2008, 15:16   #199
Yes this is the same one i was talking about.
--Sree--
Old 30th December 2008, 15:38   #200
Salikt's Avatar
Thanked: 33 Times
Looks nice the 5 spoke! Is it imported or Indian made? Any idea how much they cost in Blore?
sadiq
Salikt is offline   Reply With Quote
Old 30th December 2008, 15:48   #201
Samurai's Avatar
sadiq
It is Plati and is available in 15x7J and 139.7 PCD. However, I don't know the offset, it looks to be negative. Does anyone know the offset on this alloy? The price around 4.4K per rim.
Old 4th January 2009, 12:41   #202
Samurai's Avatar
Damn, the local supplier is quoting 4.9K as his best price. Anyone know the current prices in Bangalore for these?
Old 4th January 2009, 14:25   #203
Call Jammy, He has recently purchased a set of 5 for one Jeep. I am planning for a PCD change. Bolero 4X4 hubs are direct fit. you get lot of choices in 160 PCD both 16" and 15".
--Sree--
Old 7th January 2009, 10:59   #204
jeepster's Avatar
Thanked: 1,024 Times
hi
dose any one have information on bead locks.
where can we buy them in India?
what will be the price?
jeepster is offline   Reply With Quote
Old 7th January 2009, 12:55   #205
Salikt's Avatar
Thanked: 33 Times
Originally Posted by jeepster View Post
hi
Thats a new info for me! What is the use of that?
sadiq
Old 7th January 2009, 13:13   #206
harjeev's Avatar
Thanked: 256 Times
hi
Is this what I think it is, then its very useful
Purpose of a Beadlock
Air pressure within a tire forces its bead against the wheel rim and ensures that they rotate as a single unit. More traction is needed for tires on a dirt track racing or off-road vehicle. Drivers will often lower the air pressure to cause the tread to spread out and create a larger contact patch. This practice can create a safety hazard as there may not be enough pressure to secure the tire to the wheel. There are situations where there is a lot of pressure pushes the tire to one side or the other, especially on the outside rear tire of a dirt track racing vehicle when it is turning in a corner of an oval. This causes the bead of the tire to come off the wheel. It is also possible for the tire to have more traction on the ground than there is friction between the tire and wheel. In this case the wheel would spin within the tire without being able to turn the tire. Beadlocks are therefore designed to "lock" the bead of the tire onto the wheel.
Please do keep us informed. From your pics it looks that this can be attached with a two piece wheel like in GPW's or can it be attached in normal one piece rims too.
Nice find
harjeev is offline   (1) Thanks Reply With Quote
Old 7th January 2009, 16:25   #207
Ram
Ram's Avatar
Thanked: 149 Times
hi
In some civilized places, it is illegal to use a beadlock.
Why do something illegal?
If it is only for "looks" -- i.e.
  • if your ride really doesn't have battle-tank torque, or
  • if your ride isn't a heavy lorry traversing sand on deflated tires, or
  • if ripping up river-beds isn't really your idea of a "high",
then you can go for a fake lookalike,
what's called a streetlock -- looks as bling as the real thing.
Ram is offline   Reply With Quote
Old 7th January 2009, 18:41   #208
jeepster's Avatar
Originally Posted by Ram[indent]In some civilized places, it is illegal to use a beadlock
i want bead lock for off roading purpose only.
not for bling bling.
all over the world offroaders are using bead locks.
in all the civilized places it is illegal to change vehicle color- body type-engine-drive type (4x2 to 4x4)-external lights.
almost every thing that is not given by manufacturer as standard is illegal.
if i am right ,i dont think any 4x4 of any t-bhp member has a vehicle to use bead locked wheel out of necessity. (i.e. higher torque then wheels capacity )
here are some bling bling alloys
Name:  18 punch 16.jpg
Name:  19 claw 16.jpg
Old 8th January 2009, 23:26   #209
gotzuk's Avatar
Thanked: 67 Times
Nice find
Harjeev,
Beadlockers essentially sandwich the outer bead of the tyre between
the outside of the rim and a ring. The split rims of GPWs are like scooter rims, they are not beadlocks.
Jeepster,
Beadlocks are only required if you want to run pressures lower than 15Psi
on extremely low speed trail runs. They are extremely expensive to buy,
need regular maintenance and are next to impossible to centre and balance.
And they are not suitable for tarmac use, so you would need another set of tyres to get
to the off-roading site.
IMO, unless your 4X4 already has diff-locks and ultra low gearing to handle
the immense load from running big tyres and ultra low tyre pressures, they are
not worth the price.
BTW, which 4X4 are you planning to use beadlocks on??
gotzuk is offline   Reply With Quote
Old 12th January 2009, 17:29   #210
Kandisa's Avatar
Thanked: 455 Times
Attachment 86737
Hi jeepster,
does this (the 1st one) alloy's PCD match with that of 540/440? Also how much they cost, if you have any idea.
-regards,
Kandisa is offline   Reply With Quote
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
