Old 14th January 2009, 17:52   #226
Ricky_3007's Avatar
Thanked: 21 Times
Originally Posted by badboyscad View Post
@ harjeev : BF Goodrich all terrain is available in 275/70/16. check below link:
BFGoodrich Tires | All-Terrain T/Aź KO | Tire Sizes & Specs
And how about considering mud terrain tires??
Maxxis MT-762 bighorn is available in 275/70/16 :
MT-762 Bighorn
Thanx BBS,
Goodrich has very wide range I guess. How is the performance by the way? will it last longer than MRF/Appllo/Vikrant(JK) sandgrips? and these are radial tyres right? How much it costs? I am asking too much but pls reply.
Bighorn also lasts for 12-15K and how these tyres work if driven on road for some time? What is the cost of the same?
Somhow I like Goodrich and Yoko, lets see if it costs me less than Yoko and gives good output , i will go for goodrich .
Sombody who used goodrich pls help.
Tarkesh
Ricky_3007 is offline   Reply With Quote
Old 14th January 2009, 19:53   #227
whitemm550's Avatar
Thanked: 68 Times
Originally Posted by jeepster View Post
yes for new pcd of 550- bolero- invader- scorpio.
i dont know for old 440/540/550 pcd
here is link of neo wheels, you can have all the information on them there.
hi.
i distributre these Alloys in Goa. they are available only in 160 PCD, and not the 139 PCD for a MM550/ 540.
any further info , feel free to pm me.
whitemm550 is offline   Reply With Quote
Old 14th January 2009, 20:03   #228
gotzuk's Avatar
Thanked: 67 Times
Originally Posted by harjeev View Post
Hi Vaivhab
These tyres were promised to me by the thye dealers in Mayapuri, not the MRF dealer, which is at the red light, but the one after that. He asked me to give him an advance of 3k and he will deliver the tyres in a weeks max. He was referring to these as "jeep goddie" and they were not MRF's but Apollo or some other brand.
But do you think that these(NDMS) tyres are good for a 550? The height is 30". Should i go in for these or the yokos are better.
The Miclelin's are out of my budget and I had a chat with Mandeep and he advised me to go for either Goodyear Wanglers or BFGoodrich as a second choices but the Goodyears are not available in 16" rims. I want about 31" 11" 16" which are equivlant to 275/70/16's. And BFGoodrich's are available a max of 235's in 16".
The choice that I am left with are either yokos or NDMS's
Harjeev,
Will go and find out. Thanks for the tip.
I would suggest BFG's or Yoko's on your jeep.
NDMS are really really bad on tarmac, specially when wet.
I am using BFG's on my Gypsy, have clocked 25000 kms and still have
60% tread left on them. They rock in snow and mud with a little compromise on the braking front on tarmac.
Vaibhav
gotzuk is offline   Reply With Quote
Old 14th January 2009, 22:24   #229
badboyscad's Avatar
Thanked: 170 Times
Originally Posted by Ricky_3007 View Post
Thanx BBS,
BFG's are definitely better. They are very good for offroading.
@ harjeev : You might also want to consider putting 15 inch wheels(if possible) on your MM550, because there are a LOT more options(tires) in 15 inchers.
badboyscad is offline   Reply With Quote
Old 15th January 2009, 07:47   #230
DesertKing's Avatar
Thanked: 20 Times
DK ,
Is this 31x10.5 R16 equals to 7.5 X 16 size which I have currently on my 550 (excuse for my knowledge). These stock tyres are of Vikrant(JK tyres). Pls suggest the name of manufc.of that radial tyre. Is it Yoko/Michellin/or any other. Also the price of the same.
Tarkesh
Tarkesh, yes both these sizes are for a tyre whom total height is 31 inch. For tyre choice in redial, pls check on the following link, you can check for almost all the famous brands, their size and picture.
*all season tires Bridgestone*Dueler*A/T*693 275/70*R16
DesertKing is offline   Reply With Quote
Old 15th January 2009, 08:48   #231
DesertKing's Avatar
Thanked: 20 Times
Pls check there for Bridgestone Dueler A/T 693 and you will find a big range of sizes in 16 inch. I am surprised to even in 235/85 R 16. Wow, what a great hight you are going to have with these tyres, let me calculate... Oh my god, the overall hight of the tyre is 32 Inch; this means 1 inch taller than Sandgrip and with almost the same width(infect aprox 1.5 inch wider). I found this size most exciting for all those have 16 inch Army rims of 5.5 inch width.
Old 15th January 2009, 15:59   #232
Ricky_3007's Avatar
Thanked: 21 Times
Thanks DK for giving another option for choice. By the way when you say 235/85/16 then this 235 is width right ? then What is the width of Sandgrip ? increasing width will hamper drivability? or Fuel Effi? Because I dont want to do something too far from original sepc of the Jeep.
Tarkesh
Old 15th January 2009, 17:03   #233
DesertKing's Avatar
Thanked: 20 Times
Tarkesh
235/85 R 16 are 9.4 inch wide whereas Sandgrip are 7.5 inch wide.
I am using 31x11 R 15 which are 11 inch wide.
I do not think that this 1.9 inch more thikness will hamper the dirability. But offcourse you will notice anyhow difference after changing the tyres from NDMS to Redial. Redial would give you a less bumpy ride but yes, a bit more body role.
I have seen the tyres of the same size on a MM550 here today only and I will try if I can click a picture and post it here. That chap has fitted a Isuzu 1800 CC petrol engine (Ambasador)
Old 15th January 2009, 17:04   #234
Kandisa's Avatar
Thanked: 452 Times
Thats an excellent link DK. Thanks a lot. By the hows Dueler A/T's performance on tarmac, braking, mud and sand? Tarkesh, widening the tyre does have some good and bad part, but 235 is an appropriate size to upgrade. Beyond this, you may feel the need of the power steering.
-Regards,
Kandisa is offline   Reply With Quote
Old 15th January 2009, 18:56   #235
Ricky_3007's Avatar
Thanked: 21 Times
Thats great news DK if that 1.9 will not affect drivability and FE then I feel 235/85 R 16 is best choice.BTW this is radial one right ?
As Kandisa also suggested 235 is best size. Now I will check both BFG and Bridge stone . If any one of you know performance on tarmac, braking, mud and sand pls update me .
And DK if you can just take some snaps of the 550 which you are talking about it will be great.
That chap has fitted a Isuzu 1800 CC petrol engine (Ambasador) -
Tarkesh
Old 16th January 2009, 17:03   #236
Ricky_3007's Avatar
Thanked: 21 Times
Hey Guys,
I saw a new tyre yesterday on TATA Safari , which says Apollo HawkZ "Steel Radial " with 235 /70 / R10 or R16 I guess. Which is this tyre and how is the performance Off road and OTR? Is this the same as Apollo Bullet which I think sometimes comes with 550.
Attaching the pic
regards,
Tarkesh
Old 16th January 2009, 18:36   #237
Thanked: 101,555 Times
Originally Posted by Kandisa View Post
GTO has been using the Michelin in his jeep and his experiences have been rather good with these tyres; but anyways, they are the costliest in the lot!
Worth every penny IMO! I clicked this picture last month, can you believe that they have covered probably around 25,000 kms of HARD driving? I say *probably* as my speedometer has barely worked for a good amount of the last 6 years. I don't know the exact kms covered.
I must add that the Classic runs incredibly easy on the tyres. My stock JKs has a decent tread depth @ 50,000 kms!
Old 19th January 2009, 21:36   #238
Thanked: 66 Times
any idea where i could get 16 inch mud tyres for my 98 vitara
need them urgently
xtreme power is offline   Reply With Quote
Old 20th January 2009, 10:46   #239
jeepster's Avatar
Thanked: 1,024 Times
any information on these tyres
jeepster is offline   Reply With Quote
Old 20th January 2009, 12:51   #240
Salikt's Avatar
Thanked: 33 Times
Attachment 91605
They are made for tractor's front wheel
Salikt is offline   Reply With Quote
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
