Old 24th February 2009, 23:04   #406
Samurai's Avatar
Thanked: 15,686 Times
Originally Posted by vishwaschettri View Post
2. When stuck up in rocks the load on wheels/rims is immense. Isn't these the conditions where people shear/break their axles? But don't know if the load on axle/drivetrain necessarily translates into load on rims.
Don't wheels always carry the load, why does that become immense only on rock? Wheels are always between the chassis and the ground. It can become immense if the impact happens at highspeed or if one does indulge in show jumping the Jeep/Gypsy. The tyres are not fully deflated, they are just halved at the most.
Old 25th February 2009, 11:28   #407
Originally Posted by bigman View Post
How good does the tread pattern look on this? OTR regulars - please help.
hrag is offline   Reply With Quote
Old 25th February 2009, 12:28   #408
Alfa_Kilo's Avatar
Originally Posted by Ricky_3007 View Post
Sorry Guys (Alfa Kilo/Randeep)
I am still confused. I have stock tyres of MRF Sandgrips (7.5X16) / JK Vikrant 7.50X16 on my 550. (attached)
as 275/70/R16 are too big for the rim , I thought 235/70/R16 would fit in.
If you say 235/70/R16 also have to be pinched in then which is perfect size to put on Army Rims?
I have one tyre /wheel guide word file which says 235/70/R16 is equivalent to 7.5X16 .(attached)
I dont want to change the rim so pls help in this.
Tarkesh
The actual diameter of a typical 7.5-16 offroad tyre is ~32".
235/75R15 or 235/70R16 are 29" tyres. 235/85R16 is a 32" tyre, but being wider than 7.5-16, it should be installed on a 6.5" rim.
Alfa_Kilo is offline   Reply With Quote
Old 26th February 2009, 12:30   #409
harjeev's Avatar
Thanked: 256 Times
Originally Posted by ex670c View Post
After using the Sandgrip for 40,000 kms I will add.
  • Sand: Excellent (obvious)
  • Rocky Surface - Dry: Very Good
  • Rocky Surface - Wet: Good
  • Wet Grassy/Hard Damp muddy trail: Good
  • Slush: Bad
  • Loose gravel/jungle trail - DRY: Very Good
  • Loose gravel/jungle trail - Wet: Good
I have taken my MM540XD up to Kanakpura/Muthathi and the nearby off-road Trails and the only problem was in mud/slush.
Most people run the MRF Sand Grip over inflated to get the best out of the tyre.
some suggest Tyre Pressure for the MRF Sand Grip.
Road - 28-35 psi depending on the Wheel Disc.
Sand - 10-15 psi
Rocks -15-20 psi
Trails - 20 psi
After 15-20K kms the tyre is suitable for only Road and Sand use.
Arka
Hi Arka
I am too thinking of buying Apolo Bullets on my MM550.
I would just like to know the difference in MRF Sandgrips and Apolo Bullets.
I think that the tread pattern is similar so is it just the branding which is different. Will the preformance of the Bullets be better or worse compared to sandgrips??
I am buying the Bullets as sandgrips are not available.
harjeev is offline   Reply With Quote
Old 28th February 2009, 23:10   #410
Thanked: 247 Times
For those who asked the MRF wanderer is available for ~Rs 5500 a piece here in Delhi. The tyres looks much better than earlier MRF ZVRL. But don't expect too much from it. Tread dint look much promising.
cheers
vishwas
vishwaschettri is offline   Reply With Quote
Old 28th February 2009, 23:13   #411
Thanked: 21 Times
cheers
vishwas
So I guess it is worth paying the small premium for BFG AT's instead of these ?
bigman is offline   Reply With Quote
Old 28th February 2009, 23:43   #412
harjeev's Avatar
Thanked: 256 Times
Guys I have given the advance on Apollo Bullets.
Will get then in a couple of days.
Old 28th February 2009, 23:47   #413
Thanked: 247 Times
Great, I will be waiting for your review, I'm literally running my jeep on slicks these days. Will need to get rid of them before monsoons hit Delhi.
cheers
vishwas
Old 28th February 2009, 23:56   #414
Thanked: 21 Times
Vishwaschettri.
Don't worry my father was at the workshop today and discussing tyres with the mechanic as the current army tyres have no tread left on them. Some other customer gave his much valued opinion which was along the lines of - you could not buy tyres as good as the army ones as they were very tough and we should not replace them but carry on running on them as they are
Old 1st March 2009, 00:04   #415
harjeev's Avatar
Thanked: 256 Times
cheers
vishwas
viswas
pardon me for asking and maybe you have already answered this
But what jeep and tryes do you have
I havent come across your thread
Old 1st March 2009, 00:31   #416
Thanked: 247 Times
@ Harjeev - I have a 2001 model army disposal MM550. Interestingly I too bought it from Padam only. I am running the sandgrips that came with it.
Though I made Ganesh swap the tyres with other jeeps that had better tread left. They served me for last 5000 kms.
@ bigman - Actualy that person isnt entirely wrong. Sandgrips are hard as nails. I have had just one flat so far that too after some serious off-roading off road and on road (jumping dividers, driving over potholes etc)
But breaking is scary outright. It swerves right and left before coming to a halt. The person in front almost pees in the pants.
cheers
vishwas
Old 1st March 2009, 09:05   #417
harjeev's Avatar
Thanked: 256 Times
vishwas
Vishwas
Please post some pics on the Jeep pic thread. I will like to see your jeep. Have you done any other modification to it??
Old 1st March 2009, 21:23   #418
Thanked: 21 Times
Anyone tried sourcing Lenso 16" alloys with 139.7 PCD in Delhi ?
I have checked the Lenso web site and the following is listed :
They look like the ones Kittigadu has on his black MM550.
Old 2nd March 2009, 11:44   #419
Kandisa's Avatar
Thanked: 453 Times
Anyone tried sourcing Lenso 16" alloys with 139.7 PCD in Delhi ? ....They look like the ones Kittigadu has on his black MM550.
Yeah i also think these are there in Kitti's jeep. Though i saw this alloy in website long back but never enquired about it in any shop as yet. They match the PCD and the bolt pattern.
-regards,
Kandisa is online now   Reply With Quote
Old 2nd March 2009, 12:33   #420
fk7
fk7's Avatar
Thanked: 140 Times
Default please help
Hi all,
Can someone please help me to source either Apollo Bullet or MRF Sandgrips (size 7.50, 16") in Kerala or the neighboring cities like Chennai or Bangalore. I am finding it very difficult source the same tyres in Calicut. Any help on this matter is very much appreciated.
Firoz
fk7 is offline   Reply With Quote
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
