Old 2nd April 2009, 08:25   #496
tsk1979's Avatar
Thanked: 16,016 Times
Michelin LTX A/T Tire Reviews & Ratings - Rate or Review a Tire
I usually look at the above website, and the michelin does have high ratings!
Old 2nd April 2009, 11:17   #497
trammway's Avatar
Thanked: 219 Times
Originally Posted by Kandisa View Post
HI trammway,
what rims are these and how wide they are? I guess the advantage with the gypsy rim is it is cheap and can comfotably handle tyre of 235 width. Barring alloys and the OE rims of the 540's, i think the only available option in 16 inch will be the army rims. Don't know whether they will be suitable for classic.
-regards,
I'm really not sure which vehicle rims are they, any clue?
trammway is offline   Reply With Quote
Old 3rd April 2009, 16:58   #498
Ym-enjn's Avatar
Thanked: 55 Times
How will the BF Goodrich AT 16" work for CL340 and Classic, on 16" Army rims, guess with tube??
Behram Sir looking forward to your feedback on earlier topic of Brute?
Ym-enjn is offline   Reply With Quote
Old 3rd April 2009, 17:05   #499
Alfa_Kilo's Avatar
16" army rims are to narrow for most radial tyres and they will need valve seat adaptors too. You should go for alloys and tubeless tyres if the budget permits.
Alfa_Kilo is offline   Reply With Quote
Old 4th April 2009, 16:54   #500
khan_sultan's Avatar
Thanked: 3,872 Times
Asking a basic question -- just to be sure for some of the calculations required for one of my mods
Q: If we increase the rim size from say 5.5J to 7J, then the track width of the vehicle would increase by 1.5" effectively? (assuming 0 off-set)?
khan_sultan is offline   Reply With Quote
Old 4th April 2009, 21:28   #501
Alfa_Kilo's Avatar
Track will not change as long as the offset of the two rims is the same. Track is measured from the centerline of the wheel.
Old 6th April 2009, 18:11   #502
testdrive's Avatar
Default Valve Seat Adaptors
Alfa, Can you please explain what is a Valve Seat Adapter and its application? Why is it important to use it? Is it easily available in the market? I am planning to fit 255/65R16 Geolander ATs with a tube on MM550 army rims.
testdrive is offline   Reply With Quote
Old 6th April 2009, 18:14   #503
Good that clarifies it for my calculations.
Now for just general awareness, if the track width doesn't increase, then where does that extra 1.5" go when we go from 5.5J to 7J? (again assuming 0 offset)
Old 6th April 2009, 19:11   #504
Blue Thunder's Avatar
Thanked: 332 Times
...Now for just general awareness, if the track width doesn't increase, then where does that extra 1.5" go when we go from 5.5J to 7J? (again assuming 0 offset)
It just increases the contact area of the tyres with the ground.
Blue Thunder is offline   Reply With Quote
Old 6th April 2009, 21:15   #505
Alfa_Kilo's Avatar
The wheel extends 0.75" on either side of the mounting face. So if installed with wider tyres, the inner clearance will reduce, which may cause tyre fouling when cross axled. The turning circle may increase too.
Old 9th April 2009, 15:51   #506
Ym-enjn's Avatar
Thanked: 55 Times
Any views or reviews about Goodyear Wrangler AT'S 255/70/R15. 2008 made are available for 5000 each tubeless. Ithink one of the NIOC Jeeper in Red Classic has these tyres. How is the performance?
Also if we buy alloys with negetive offset for them then do they fit without any other alteration.
My another question is are 235 R15 available in 80 or 85 hight?
Old 9th April 2009, 22:22   #507
Alfa_Kilo's Avatar
*5 section are only availabe in 16" as far as I am aware. Wide tyres (255) on a light vehicle like yours will be quite useless except on soft sand. You should look for narrow and tall tyres.
Old 19th April 2009, 21:53   #508
randeep04's Avatar
Thanked: 16 Times
Default My Jeep tyres
Hi everyone,
Well finally yesterday i got the time to drop my tyres off at the workshop in Jaipur and also see them fitted for the first time.
Here are some pics of the same.
Cheers !!!!!!!!
randeep04 is offline   Reply With Quote
Old 19th April 2009, 23:32   #509
gbanavar's Avatar
Originally Posted by testdrive View Post
3. Since 550/540s are 139 PCD, you cannot find matching 16" alloys/rims that are wider. You have the option of going for 15" alloys or changing the PCD of the jeep hubs to 160 PCD. I am been told by 4x4addict (on t-bhp) that you can get the Bolero 4x4 hubs put on the jeep to make it 160 PCD. See pic below of 4x4addict's jeep with 235/70R16 on Scorpio rims (using bolero hubs).
Guys - Let me know if any of the above info is not correct. Hope this is helpful is clearing any confusion.
Hello,
Can someone explain if this can be done on a CJ3B? If so, how should I go about it? Which parts will I have to replace? Hub, brake drum, etc..
I would really like to keep 16" wheels and change to 160 PCD for a better choice in alloys.
gbanavar is offline   Reply With Quote
Old 20th April 2009, 11:01   #510
randeep04's Avatar
Thanked: 16 Times
Originally Posted by gbanavar View Post
Hello,
Need not change any part. Just get a spacer made. I too have done the same thing, got 1" spacers made it gets fitted on the original Jeep hub and the tyres get fitted on the new 160 pcd bolts.
Cheers !!!!!!
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
