4x4 Technical Engines, Diff-locks, SPoA, Techniques and more
Thread Tools
Old 1st December 2007, 19:31   #46 (permalink)
hillram's Avatar
Guys,
I have been using Pirelli Scorpion All Terrain Tubeless Tyres on my Sierra..Awesome performence on rural and terrains..
hillram is online now   Reply With Quote
Old 1st December 2007, 19:51   #47 (permalink)
Samurai's Avatar
Originally Posted by hillram View Post
Guys,
I have been using Pirelli Scorpion All Terrain Tubeless Tyres on my Sierra..Awesome performance on rural and terrains..
Holy cow! Is that the Scorpion ATR, that's supposedly the best A/T tyre. How much did it cost you, how is the tyre noise? My OE tyres are quite noisy, especially for rear seat passengers, today my son was complaining about that.
__________________
Samurai
The only Super Car in my book -Bowler Wild Cat
Old 1st December 2007, 20:27   #48 (permalink)
DirtyDan's Avatar
Default Sipes = edges
Sipes are the little cuts, little edges you see molded into the bigger lugs of the treads. In other countries when you buy a set of tyres, especially off-road or all purpose tyres, the bigger shops have special machines that will actually cut more sipes into the tread at evenly distributed places around the tread to give you more edges. More edges = more traction. Generally Michelin has a lot of sipes right out of production and Michelin is a great tyre. I have used the Goodyears and they are great for about 20,000k and then they develop scalping and cupping and the last 20,000k are not so pleasant. I have not tried Pirelli for awhile, having been disappointed by a set many years ago.
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
Old 1st December 2007, 21:06   #49 (permalink)
iraghava's Avatar
I will add my input to this thread tomorrow but remember this Samu, the more wider the pattern (with relation to the space in the grooves of the tyre & the size of the blocks) the more noisy it'll be on-road. Make sure that you do not choose a design which becomes painfully loud on the highway.
__________________
Reminds me of my safari in Africa.Somebody forgot the corkscrew and for several days we had to live on nothing but food and water.
Old 1st December 2007, 22:06   #50 (permalink)
Samurai's Avatar
That's why I want some first person feedback on noise.
__________________
Samurai
Old 3rd December 2007, 14:20   #51 (permalink)
Samurai's Avatar
Yow tyreman, where art thou?
__________________
Samurai
Old 3rd December 2007, 14:48   #52 (permalink)
iraghava's Avatar
Was busy with a friend's marriage. Will reply by today evening positively.
__________________
Old 6th December 2007, 17:00   #53 (permalink)
Samurai's Avatar
Bump .
__________________
Samurai
Old 6th December 2007, 17:30   #54 (permalink)
suman's Avatar
Bump .
Winter is setting in at NCR & weddings (that too friends weddings) take a while to get over - all that blood in the alchohol stream , I mean all that alchohol in the bloody stream, I mean.....hic, hic.......you know what I mean right
__________________
"Unborn TO-MORROW and dead YESTERDAY,
Why fret about them if TO-DAY be sweet!" - The Rubaiyat of Omar Khayyam
Old 6th December 2007, 17:43   #55 (permalink)
Alfa_Kilo's Avatar
@Samurai
You may want to see this page for some information on tyres.
I had 235/75R15 Bridgestone H/T tyres on my 4x2 MM540DP. They were quite good on the tarmac, but useless off it. I replaced them with the same size Michelin AT-X tubeless tyres. The ATs provide much better traction on lose surfaces and rocks. The grip on tarmac is lesser, I can feel the steering has become lighter, and it is now possible to kick the rear end out in a jeep! Tyre noise is considerable, and they often kick up small stones into the wheel arches. One also has to regularly dislodge pebbles from the treads. I haven’t driven them in mud yet, but ATs are not very good for mud. There you’ll need proper offroading M/Ts.
I feel you should avoid changing over to 235/70R16 as they will cause some under reading in your speedo and odo, and the ABS might cut in slightly early too. Instead go for 225/75R15 if you are willing to change the wheels too. It’s a common size and the higher profile will help on poor surfaces.
Alfa_Kilo is offline   Reply With Quote
Old 6th December 2007, 18:26   #56 (permalink)
Samurai's Avatar
We team-bhpians have a long relationship with that web site.
I have heard about these issues with AT tyres, that's why I am looking very carefully. I am looking for the best compromise. But the limited selection in India is making it difficult. My H/T tyre is quite noisy already.
I have checked already, it is only 1.9% which is very acceptable. But I didn't understand how ABS will cut-in early? Downgrading the wheels to 15", that's something Team-BHPians rarely do, I want to stick to 16" wheels.
__________________
Samurai
Old 7th December 2007, 17:53   #57 (permalink)
Alfa_Kilo's Avatar
ABS will cut in slightly early because the wheel speed sensor reading will be slightly lower with the new tyres wrt the linear G sensor when braking. Same case with TCS.
I prefer 15" because higher profile tyres on them are better on rough roads/no roads.
OT: Can one cut off ABS for off-roading in the GV?
Old 25th August 2008, 23:23   #58 (permalink)
khan_sultan's Avatar
Default Geolander M/T vs. Maxxis Mudzilla? Price/Where
Folks,
Have zeroed down on the following 2 as the next set of tyres for my Gypsy.
Maxxis Mudzilla:
Geolander Mud Terrain:
My requirements are:
Should perform GREAT in the following conditions (preference in descending order):
  • Mud
  • Rock
  • Jungle/Loose Gravel Trail
  • Sand
  • Street
I am currently running 215/75/15. Have decided to put in 30x9.50R15.
Questions folks:
Where in Bangalore would these be available and at what price points?
Personally, I am more inclined towards the Geolanders over Maxxis.
Cheers,
__________________
The best way to kill an idea is to take it to a meeting....
khan_sultan is offline   Reply With Quote
Old 26th August 2008, 13:11   #59 (permalink)
DKG
DKG's Avatar
Maxxis have advertised in car mags showing dealers only in Delhi and Bombay. If you need the Bombay number let me know
Shahnawaz my only concern with these tyres is the road noise and increased wear on highway. Ideally we should cart them to the offroad site, have our fun, put back the road radials and drive back in comfort. This becomes an issue when you have to drive for atleast 100 or 200 kms on highways at speeds above 100.
The price is approx Rs 8500 for a 275/70 R 16 Mudzilla
Are these Geolanders available here in India? Excuse my poor knowledge but is that a model from Michelin?
__________________
In changing yourself, you change your life
DKG is offline   Reply With Quote
Old 26th August 2008, 13:20   #60 (permalink)
Originally Posted by DKG View Post
... my only concern with these tyres is the road noise and increased wear on highway. Ideally we should cart them to the offroad site, have our fun, put back the road radials and drive back in comfort. This becomes an issue when you have to drive for atleast 100 or 200 kms on highways at speeds above 100.
That's an ideal scenario. I would be happy if I get ~30K kms from these tyres in total. That would mean say 4-5 years for me in OTR's.
I feel that if one loves off-roading then I have to be prepared for all the not so nice/comfortable aspects of it also :-)
Geolanders are a model/brand from Yokohoma.
__________________
Thread Tools
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 109 1st September 2009 16:15
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
Direzza Tyres And Rims? CaliforniaKnight Tyre & Alloy wheel Section 7 23rd October 2007 01:10
Looking for 15" rims and tyres Boom Shiva Tyre & Alloy wheel Section 5 19th May 2005 16:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
