Old 18th May 2010, 09:42   #811
ex670c's Avatar
Thanked: 1,838 Times
Originally Posted by R32_GTR View Post
Hi redliner,
Assuming that this question was for me
I recently picked up a Jonga and am not 100% sure of the current NDMS's on it.. they looked pretty worn out.
I"ll be using the Jonga only for OTR's and it'll spend most of its time offroad.. I am not too keen on getting a set of NDMS's and eventually change them to some offroad tires (I'm not a big fan of NDMS's and I'm look for a much beefier set of tires).
Once I've taken possession of the vehicle, I'll start a thread on the same (In about a week).
Thank you.
Hi R32,
The JONGA (P60N) runs on 16" Rims, you you will have to choose a 16" tyre.
I would suggest Maxxis Mudzilla 31-11.50-16.
Arka
Old 18th May 2010, 11:45   #812
Tejas@perioimpl's Avatar
Thanked: 5,490 Times
Originally Posted by Red Liner View Post
Nope, its more expensive (prior to negotiation).
Why did you go for a straight stock upgrade? No 7.00 x 16 available?
The official Maxxis dealer quoted me 6800 for the same and on hard bargaining came down to 6100. These were got to me by my local dealer for 5250.
I went for stock upgrade (width was the only upsize: 215 to 235) since i did not want to play around with dif ratios, body lifts, etc.
Tejas@perioimpl is offline   Reply With Quote
Old 18th May 2010, 13:13   #813
R32_GTR's Avatar
Thanked: 184 Times
Originally Posted by ex670c View Post
Hi R32,
Arka
Hi Arka,
Thank you for the suggestion.
Will the suggested spec fit on the Stock Jonga rims?
Secondly, will this make the steering heavy?
Lastly, any idea on how much it would cost per Tyre?
Thank you once again..
Prasad
R32_GTR is offline   Reply With Quote
Old 18th May 2010, 13:47   #814
motocamp's Avatar
Thanked: 99 Times
i just changed the tires on Alfa Kilos 550 from 235 michelin ltx to maxxis bighorn 31x10.5x15.
The tires have a very aggressive tread pattern and fit perfectly on the 7j alloys.
The steering has got noticeably lighter compared to the michelins. i guess it's because of less rubber actually in contact with the road due to the large tread void.
Let's see how they perform on the next recce.
motocamp is offline   Reply With Quote
Old 18th May 2010, 13:53   #815
R32_GTR's Avatar
Thanked: 184 Times
Hi Kunal,
What a coincidence...I just got off the phone with a tyre dealer in Bombay and he said that he has Maxxis' bighorn in 285/75/16 @ around Rs. 9500!!
Can you PM me your details?
Thx
Prasad
Old 18th May 2010, 14:08   #816
ex670c's Avatar
Default Fit
Hi Arka,
Prasad
Hi Prasad,
The Mudzilla will definitely fit on the JONGA rim. (5.5-16)
The ideal Rim size for the above tyre is 8.5-10" width. so the sidewall will bulge and its not advisable to do very high speeds and deflate below 15 psi.
The Steering will definitely become heavy as compared to the 7.00X16.
Arka
Old 18th May 2010, 14:26   #817
R32_GTR's Avatar
Thanked: 184 Times
Hi Prasad,
Arka
Hi Arka,
Do you recommend that I change the wheels as well? Any recommendations on stock rims from other 4x4's?
This is why I wanted to know the PCD for the Jonga wheels.
Thank you ever so much!!
Prasad
Old 18th May 2010, 14:28   #818
Thanked: 97 Times
guys , I have bought Bighorns 32x10.5 r15
urgently need 10j rims
please PM me asap.
any design will do, only specification is 10J.
garrett_t16 is offline   Reply With Quote
Old 18th May 2010, 17:43   #819
ex670c's Avatar
Default Pcd
Hi Arka,
Prasad
Hi Prasad,
IIRC JONGA uses a 6 on 5.5 Wheel Disc.
If you can, please change the Rims if you are fitting bigger tyres.
Arka
Old 18th May 2010, 19:45   #820
Samurai's Avatar
Thanked: 15,932 Times
please PM me asap.
Manan, the ideal rim width for a 10.5 tyre is from 7.5 inch to 9 inch. Why would you want 10j rims for a 10.5 tyre? This is for the GV?
Old 18th May 2010, 20:27   #821
Thanked: 97 Times
sorry sir made a mistake !
the tyres are 32x11.5 r 15
no , dont worry !. not for the GV.
they are for a jeep i am building -
http://www.team-bhp.com/forum/4x4-ve...mix-match.html (my new baby A 4X4 JEEP !!!(no specific model because its all mix and match))
Old 18th May 2010, 20:34   #822
Samurai's Avatar
Even for this, the size should be between 8" to 9.5", at 10J the tyre will not have sufficient flex, and could cause problems when you under-inflate. Better stick to 8.5 or 9 inch rims.
Phew! You had me worried for a while.
Old 18th May 2010, 23:28   #823
Thanked: 97 Times
ok sir but there is a problem, all the dealers seem to have 8.5J but no-one possibly has 9J,believe me on that as i have visited half a dozen tyre shops and dealers in the hunt for the 10J rims.
any good designs or suggestions ?
i had seen 8.5J RALLY rims. they good enough?
i dont think they will look good on a '52 MB?
opinions?
Old 18th May 2010, 23:32   #824
Samurai's Avatar
Please stop calling me sir. You are really better off using 8.5J than 10J, which can be dangerous for a 11.5 tyre. Then you have all the choice.
Old 19th May 2010, 00:18   #825
Thanked: 97 Times
Thanks Mr.samurai !
will hunt for a good design !
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
