Old 19th May 2010, 11:16   #826
R32_GTR's Avatar
Thanked: 173 Times
Originally Posted by ex670c View Post
Hi Prasad,
IIRC JONGA uses a 6 on 5.5 Wheel Disc.
If you can, please change the Rims if you are fitting bigger tyres.
Arka
Hi Arka,
Just one last question on Tyres / Wheels
What would be the ideal set-up if I go for 15" wheels (steel rims/nothing fancy) and tyres to compliment the 15" set up?
OR is this a definite NO NO!!
Thank you once again..
Prasad
R32_GTR is offline   Reply With Quote
Old 25th May 2010, 13:11   #827
ex670c's Avatar
Thanked: 1,799 Times
Default Over All Diameter
Originally Posted by R32_GTR View Post
Hi Arka,
Hi Prasad,
The JONGA runs 7.00X16 that is 30" Tall.
If you go for 15" then
1) Yoko MT 31-10.50-15
2) Maxxis 31-11.50-15
The question is where will you get a suitable rim and at what price?
Arka
Old 25th May 2010, 13:24   #828
R32_GTR's Avatar
Thanked: 173 Times
Hi Arka,
I think I might just stick to the 16" rims since changing the wheels looks like an extension to my troubles of finding the right set.
I have decided to source 16" Maxxis Bighorns (If I can find one)
Part # TL30205200 size:245 / 75 R16 - recommended wheel size is 7J (the Jonga is 5.5J)
Appreciate all the help so far..
I am still not in possession of the vehicle (should get it in about 7 - 10 days) - Just thought that I'd get a head start on tyres
Cheers..
Prasad
Old 25th May 2010, 13:33   #829
ex670c's Avatar
Default Wheel Arch
Hi Arka,
Hi Prasad,
Please check the rear Wheel Arch if the Wheels foul, trim the Rear Wheel Arch.
Arka
PS - I would suggest you pick up some Carbs/Distributors/Fuel Pump for the P-Series Engine
Old 28th May 2010, 11:30   #830
The Wolf's Avatar
Thanked: 58 Times
Originally Posted by Jaggu View Post
This will be perfect for your jeep M8060 Trepador Not perfect for onroad but the right compromise.
Wonderful, now what rims and tyre size? I m looking for something that gives decent driveability on tarmac and definitely better off it.
My alloys are 15inch-6Js hence I am looking to move to 16inch-8.5J rims with a tubed setup and sell away the alloys with the tyres... The alloys are in brilliant state and the B'stone Duelers may have around 6-8k tarmac life left on em. Anyone interested can PM me. Thank you.
Now, what rims would be suitable? Purpose and availability wise both. Once that is done, over to the diff ratio upgrade to suit new setup please
The Wolf is offline   Reply With Quote
Old 28th May 2010, 12:17   #831
ex670c's Avatar
Default 31" Tyre.
Hi Wolf,
Shahnawaz Khan's Setup 31-10.50-15 (Yoko MT)and his Rims will be superb on a MM540.
Otherwise the good old 7.50X16 Sand Grip or the JK LT4x4.
31/32" Tall Tyres will help improve the Ramp Over Angle of an MM540.
Arka
Old 28th May 2010, 13:05   #832
The Wolf's Avatar
Thanked: 58 Times
Hi Wolf,
Otherwise the good old 7.50X16 Sand Grip or the JK LT4x4. .
Hey thanks Arka... what would be your ideal setup for 80% tarmac + 20% OTR (slush biased, considering the onset of monsoon)?
1. 15nch gypsy rims + 31" Geolander?
2. 15inch gypsy rims + 31" Trepador?
3. 15/16inch any other rim + 31" any above tyre/ Sand Grip/ JK LT?
4. Any other set up?
I am not looking to spend too much doe to experiment on different setups ongoing so I wana get it as close as possible to the best combo at the first go...hence the above explicity
Yeah I'd need that, somethings gotta be done about those worshipped SWBs after all you see
Old 28th May 2010, 13:19   #833
Jaggu's Avatar
Thanked: 7,684 Times
Gypsy rims are 15" size though they are straight fit on jeeps. So you will have to check out different rims if you want 16".
Old 28th May 2010, 13:36   #834
The Wolf's Avatar
Thanked: 58 Times
Question
Thanks Jag...
Any clue of
1. where those army look alike (oval grooves) 16'' rims available in Blore and how much they cost?
2. Also, are they available in desired Js?
3. How do these non authentic army rims fare in taking OTR beatings?
p.s: what J is gypsy rim?
Old 28th May 2010, 14:58   #835
Jaggu's Avatar
1) Not aware of the same, though you should find some decent army rims in decent condition if you ask around. No idea of cost.
2) They are 5.5J IIRC.
3) Not aware of army look alike's.
Old 28th May 2010, 20:02   #836
The Wolf's Avatar
Thanked: 58 Times
Hi Jaggu,
7.00X16 NDMS (Super King) that is 30" Tall.
According to the info in their site the 7.00X16 Pattern 33 (NDMS in our lingo) is 31.3'' tall. This seems to be a better bet for a mm 540 that anything else for me suddenly coz it will work out under 20k for a set of 5 !!!
Old 29th May 2010, 09:10   #837
khan_sultan's Avatar
Thanked: 3,467 Times
Go for it -- NDMS tyres are the best performing tyres money can buy for jeeps. BTW, which rims you plan for these tyres? If I am not wrong, these are 16" tyres, so you would need rims also as your existing rims are 15".
Again, IIRC, army rims would cost you ~15K+ for a set of 5 depending on where you source them from. You can get them shipped from Mayapuri in NCR.
khan_sultan is offline   Reply With Quote
Old 29th May 2010, 09:17   #838
Samurai's Avatar
Thanked: 14,542 Times
The Army rims weigh 16Kg each compared to the 5Kg alloy rims. Better to keep that in mind.
Old 29th May 2010, 10:31   #839
The Wolf's Avatar
Thanked: 58 Times
Yeah I was told these army rims would be around 40% heavier! That additional weight can help in certain terrains but will definitely have negative implications in most if assessed technically. BTW, sir, the 15'' 6j alloys that I have, I dont think its less that 10-12kgs considering my stock 14" 5J OHC VTEC alloys (Enkei make) were around 9kgs each and were considered fairly light in the domestic racing world. Will check the exacts when I can and repost.
Also, any idea how much normal steel rims weigh, the non army ones??
Khan bhai: I am not too particular about army rims, the 16'' army look alike (oval grooves) are good enough for me I am guessing. I liked the rims on that light green 'PB' registered MM 540 that had come to the Pearl valley otr. I wouldnt mind those types...
Old 29th May 2010, 11:10   #840
Samurai's Avatar
The steel rims weigh about 9kgs. You have an alloy that weighs 10-12Kg...
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
