Old 8th September 2010, 09:51   #1021
COUGAR's Avatar
Thanked: 83 Times
Originally Posted by beejay View Post
I think the same is available in Bangalore for 4800.
Yeah i got a quote for 4900/- here in Pune. Did you fit MT, HT or AT version? On the website i can see both MT and HT versions.
COUGAR is offline   Reply With Quote
Old 8th September 2010, 15:09   #1022
beejay's Avatar
Thanked: 109 Times
I have fit Geo AT. The website is confusing.
beejay is offline   Reply With Quote
Old 8th September 2010, 16:29   #1023
Desmosedici's Avatar
Thanked: 409 Times
Yoko Geo 215/75 AT in mumbai, dealers will quote 4800. Ask for a buyback on old tyres. your final price per tyre should be around 4300. Negotiate well with them. they will give in.
Desmosedici is offline   Reply With Quote
Old 10th September 2010, 10:42   #1024
Saptarshi B's Avatar
Thanked: 9 Times
Any suggestions between Yoko Geo 215/75 and Michelin Latitude cross 215/75 ? Also is the Michelin way more expensive than the Yoko Geo ?
Saptarshi B is offline   Reply With Quote
Old 10th September 2010, 11:02   #1025
ladak.imran's Avatar
The Michelins are a a couple thousand rupees more than the Yoko's IIRC..
If you want to more on-road comfort, go for Michelins.
If you want more off-road reliability (wrt punctures n all), go for Yoko's.
If you want most off-road reliability, go for BFG's!
ladak.imran is offline   Reply With Quote
Old 10th September 2010, 11:24   #1026
headers's Avatar
Thanked: 460 Times
I've used Michelins extensively in offroad and have found no disadvantage!! Yes they are expensive, but worth every penny!
BFGs are softer and flex better than the Michelins.
No experience with Yokos though!!
Vehicle: MG 413W Carb
Old 10th September 2010, 11:37   #1027
Samurai's Avatar
Thanked: 14,772 Times
Most Karnataka offroaders would find it otherwise because of the local terrain. BFG is useless in mud, while the self cleaning Yoko AT-S performs superbly in mud. BFG looks much better than Yoko, yet most of us end up buying for Yokos. In the Sharavathy OTR, except for Sreeni who had Michelin LTX AT, everybody else was running Yoko AT-S. If somebody wants better, MT is the way to go.
Old 10th September 2010, 14:15   #1028
Acha!
I was of the impression that the Michelins go flat relatively more often than the BFG's/Yoko's..
And ya - I've actually noticed that the lack of self cleaning tread in the BFG's, is quite a hindrance in slush - thanks for pointing it out.. My bad..
In Bombay, other than the monsoons, the terrain is dusty, than anything else.. Dusty and dry..
I'm referring to places like Sawarsi, Lonavla, and Mahape..
Old 10th September 2010, 14:27   #1029
Samurai's Avatar
Michelin's offroad reputation was made in LTX AT, which is not available any more. The new LTX AT2 is more of a HT tyre than AT tyre. I have that on my GV.
Old 15th September 2010, 20:15   #1030
fazalaliadil's Avatar
Thanked: 624 Times
Also known as Brazilian rims, can someone source 5 No.s in 16", for me? Regards,
fazalaliadil is offline   Reply With Quote
Old 19th September 2010, 19:26   #1031
Thanked: 31 Times
Can someone help me with the recommended tyre pressure for Maxxix Big Horn 31 X 10.5 X R15
Off Road and On Road
Cloud_Chaser is offline   Reply With Quote
Old 19th September 2010, 20:37   #1032
Tejas@perioimpl's Avatar
Thanked: 5,096 Times
28-30 on the road depending on the weight of your vehicle. Offroad depends. Generally 22. Can go down to 18 in muck and 12-15 in sand.
Tejas@perioimpl is offline   Reply With Quote
Old 20th September 2010, 11:54   #1033
Prithvi's Avatar
Thanked: 21 Times
Where can I get a BFG KM2 285/75/16 in Bangalore?
Prithvi is offline   Reply With Quote
Old 20th September 2010, 23:54   #1034
any idea how much the yoko geolanders A/T 205 are for?
saintsinner is offline   Reply With Quote
Old 21st September 2010, 14:22   #1035
harjeev's Avatar
Thanked: 256 Times
To all tyre Gurus:
I will have to change the tyres on my FJ cruiser early next year. The problem is that there are not many choices available inn 275/ 70/ 16
As those of you who have read my thread will know that I had a small hiccup at Navsari and had to purchase a tyre 235/ 70 R16 which I have recently exchanged for a 275/70/16 Michelin LTX AT. This tyre Michelin is a 2008 and as I will be using it just as a spare I did the exchange. I wanted to buy Michelin Latitude Cross but they are not available due to some import restriction for the time being.
Now coming to my main query. The other 4 tyres are of 2005 manufacturing year and have about 10k to max 15 k kms of life left in them. So as I have time what brand and type of tyre should be the most optimal replacement the vehicle.
harjeev is offline   Reply With Quote
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
