Old 27th April 2011, 18:27   #1171
harjeev's Avatar
Thanked: 256 Times
Default re: The Offroad Rims & Tyres Thread
Originally Posted by DirtyDan View Post
What is the tallest good off road tyre you can get in India? I need instant ground clearance. Is there anything around 33"?
Hey Dan
A friend of mine is using 33" Yokohama MT's on his CJ3B. Here his a pic of the tyres on his vehicle
Hope it helps. He bought it from a Dealer in New Delhi.
harjeev is offline   Reply With Quote
Old 27th April 2011, 18:29   #1172
ex670c's Avatar
Thanked: 1,799 Times
Hi DD,
I guess you are running 235/75/16 in that case 31-10.50-15 or 245/75/16 or 235/85/16 will give you 10-25mm increase in GC.
31-10.50-15 is a very common size.
Arka
Old 27th April 2011, 21:37   #1173
DirtyDan's Avatar
Thanked: 747 Times
Originally Posted by AVR View Post
I believe you can get even more than 33". Have seen 35" Nitto Grapplers on a mod'ed Red Endy on this forum.
Nitto is a very good tyre. I have had several sets of them in other countries. They approach Michelin in build quality and to my mind that is high praise. I did not know you could get them in India.
Originally Posted by harjeev View Post
Hey Dan
Thanks, H-man. Those look good.
Originally Posted by ex670c View Post
Hi DD,
Arka
Yes, I've got 235/75/16s (BFGoodrich ATs) on my Invader. I am considering doing extensive upgrades to it or buying a Bolero Camper with the idea of outfitting a vehicle specifically to do long range trekking in the Himalayas. That means getting some good GC for starters. 33" may be about right. I will have to change the diff ratios and test out the handling. Might want PS for this, too. More on this later when I have a better idea of how to proceed.
Old 28th April 2011, 10:48   #1174
AVR
AVR's Avatar
Thanked: 511 Times
The right size is actually 235/70R16. I feel the 235/85R16 is an ideal size it has a height which is slightly more than 31" without any increase in the width unlike the 31x10.5R15 and the likes thereby not impacting the steering effort.
Only issue is that last when I heard about Coopers going in that size they were 12-13K a piece which is way higher than a Bighorn 31" which is roughly 8.5-9K.
AVR is offline   Reply With Quote
Old 28th April 2011, 16:27   #1175
4x4addict's Avatar
Thanked: 2,513 Times
You can go with 33 or 35 with revised gearing. Attaching pic of my jeep with 35".
4x4addict is offline   (2) Thanks Reply With Quote
Old 28th April 2011, 17:11   #1176
DirtyDan's Avatar
Thanked: 747 Times
Hi Tini. What brand-type tyres are those? What price? Are you happy with them?
Old 28th April 2011, 17:52   #1177
4x4addict's Avatar
@Dan:
These are Maxix Trepedors. They give great ground clearance but even with a 125 bhp Isuzu Powertrain, the power/torque is compromised. So altering gearing is a must. I am planning to go with 4.88 but with DI Turbo, you may need to go with 5.3 gearing to get the best out of the 35". 33 maybe a good balanced option.
35" Maxis Trepadors are about 17K Rupees each.
4x4addict is offline   (1) Thanks Reply With Quote
Old 28th April 2011, 18:04   #1178
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
^^ Tini, any idea how much does this tyre + rim combo weigh? Anxious to know this data.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 28th April 2011, 20:33   #1179
DirtyDan's Avatar
Thanked: 747 Times
OOPs! My BFG ATs ARE in fact 235/70/R16s. 6000rs per tyre, I paid.
Tini, with the 35" at that price I may opt for extensive skid plates instead.
Old 28th April 2011, 20:45   #1180
AVR
AVR's Avatar
Thanked: 511 Times
@DirtyDan,
The Coopers that I mentioned in 235/85R16 are the tyres on the Jeep next to the one with the 35" in the pic put up by 4x4addict. IIRC the exact model is the Cooper Discoverer STT.
Cheers,
Adi
Old 30th April 2011, 21:07   #1181
jeepster's Avatar
Thanked: 985 Times
any issues with axle bearings?
with 35" tyres the axle shafts, prop shafts, Propeller Shaft Cross etc will be under more torque than they are designed for.
jeepster is offline   Reply With Quote
Old 30th April 2011, 21:56   #1182
Thanked: 757 Times
Nikhil why do you think so? Do share your views.
I asked a relevant question above, waiting for the answer from Tini.
Spike
Old 30th April 2011, 22:49   #1183
jeepster's Avatar
Thanked: 985 Times
AFAIK in international offroading scene DANA 44 are upgraded with stronger axle shafts, prop shaft cross, bearings,etc for using bigger tyres.
if the mm axles can take 35" tyres then i have some ideas 34" tyres. (something like BFGoodrich Mud-Terrain T/Aź KM2)
Old 1st May 2011, 17:47   #1184
jeepster's Avatar
Thanked: 985 Times
i am planing to use Neo Claw with ATF sand-grip tyre.
(because M.A.S.S. quoted me 16" Scorpio steel rim set at 20K & i am getting alloy set at 25K )
the size of alloy wheel is 16" 6.5j with 160 PCD.
the standard wheel width for sand-grip is 5.5j.
should i do it?
Old 1st May 2011, 19:00   #1185
Tejas@perioimpl's Avatar
Thanked: 5,060 Times
I also want to know if what axles you are using. What about articulation? In the pics, it looks there there is hardly any space.
Tejas@perioimpl is offline   Reply With Quote
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
