Old 7th November 2008, 10:24   #106
Tejas@perioimpl's Avatar
Thanked: 5,058 Times
i had pirelli scorpios M&S on both my gypsy and safari. Awesome tyres. Good and silent ride on road too.
Tejas@perioimpl is offline   Reply With Quote
Old 7th November 2008, 11:08   #107
fazalaliadil's Avatar
Thanked: 624 Times
Although the army rims look really cool, one draw back is that they are very heavy.
Addict,
They are heavy but we dont need to carry them all the time.
Originally Posted by deepgautam_qa View Post
I am thinking about the commanding driving position these tyres provide.
Cheers!!!
Gautam,
You bet they do.
Originally Posted by rranjith_kum View Post
Nice rubber !!
You are not going to fit them to your Matiz anytime and convert it into a monster truck, would you ?
Ranjit,
No, matiz does not the power to drive them, even if I wanted to.The other set of 5 are for my other jeep.
fazalaliadil is offline   Reply With Quote
Old 7th November 2008, 12:46   #108
Kandisa's Avatar
Thanked: 425 Times
Originally Posted by fazalaliadil View Post
Happened to take off the spare from my Jeep for sizes of bracket to fit on the other Jeep, the weight is a whopping about 32 kgs, so be careful reg the tailgate, I tore one from the top middle before learning how not to rip the other. For scale you can see the tyre in and leaning on my Matiz.
Now only I can imagine how huge this can be. Was not so visibly monsterous while fitted in the jeep! Please share some techniques to properly reinforce the tailgate to carry such a huge load
Kandisa is offline   Reply With Quote
Old 7th November 2008, 15:16   #109
Thanked: 91,623 Times
Running Michelin A/Ts on my Classic since a while now. Very satisfied with its on / off road performance.
Old 7th November 2008, 16:07   #110
4x4addict's Avatar
Thanked: 2,513 Times
Addict,
I was referring to the effect of the heavy tire wheel combo on the jeep and steering components, etc..
Looking at the latest pictures of Army 550s posted by parm, it seems that army is now using the Bolero camper style rims for now. They have two holes together a gap and then two holes. Different from the earlier ones in this jeep.
4x4addict is offline   Reply With Quote
Old 7th November 2008, 17:06   #111
Thanked: 226 Times
GTO,
Thanks for your input. I am zeroeing on Michelin A/Ts for my Gypsy.
Warm regards,
Dwarak
dwaraka is offline   Reply With Quote
Old 7th November 2008, 18:53   #112
Thanked: 624 Times
Addict,
2005 onwards, MM550's supplied to army by Mahindra came with disc brakes. That is the reason the new redesigned rims with 5 pairs of 2 holes each, as compared to oval 10 holes individually placed, on earlier drum brake model rims. (marked by red arrow in both pics.)
The disc brake rims dont fit on older drum brake 540/550 models due to the fact that the the holes (marked by yellow arrow in both pics.) do not match, in the latest rims the 5 stud holes are wider apart, compatible only to disc brake models. rest of the sizes are same for 7.50-16 tyres.
However if you wish to still have these rims on your older 540/550 model the way out is, remove all present drums and change to Bolero drums, as Bolero came with discs.
Old 7th November 2008, 19:39   #113
kittigadu's Avatar
Thanked: 105 Times
well,
This is how it is on my vehicle.
regards
Krishna.
kittigadu is offline   Reply With Quote
Old 7th November 2008, 20:14   #114
Thanked: 68 Times
Originally Posted by kittigadu View Post
well,
regards
Krishna.
Hi Krishna,
Can you pls post more pictures of the tail gate in your jeep?
I found this Bestop oversize tire carrier installation manual while searching for oversize tire carrier mods. Though it is meant for Jeep Wrangler, i thought it will give some ideas for DIY. Hope this is of some help.61960.pdf
Cheers!
-Vaspro
vaspro is offline   Reply With Quote
Old 7th November 2008, 20:29   #115
kittigadu's Avatar
Thanked: 105 Times
vaspro,
Thats the only snap i have of the tail.
Shall take a few more this weekend and post.
krishna
Old 8th November 2008, 00:08   #116
Thanked: 624 Times
well,
Attachment 67743
regards
Krishna.
Krishna,
The spare on your tailgate is original, as yours is a army model. Heavy hinges, tubular bracket and all.
Guys like me with older tailgate models have problems of tearing tailgates. For all in the forum with problem I encountered and how I overcame it.
1. welded a 6mm ms sheet to 3/4th rear of the tailgate
2. Inserted a heavy guage pipe full length through the existing pipelike fold on the top part of the tailgate.
3. A Boler damper is (bolted on the tailgate) between the tyre and tailgate positioned where the lower centre of the tyre gets huge support, thus evenly distributing the outward pressure on the tailgate.
4. Additional support comes from the tyre positioned right above the rear tow hook, this takes care of swing due to heavy jerks and bumps.
Trial and error my friends.
Old 8th November 2008, 11:34   #117
Thanked: 647 Times
May I know how the MRF Sandgrips performs on the road. The treads don't seem to inspire any confidence for moderate to high speeds (Within 100kmph)
jyobeb is offline   Reply With Quote
Old 8th November 2008, 12:47   #118
ex670c's Avatar
Thanked: 1,799 Times
Default Mm550xd
Hi Guys,
A few clarifications about the MM550XD
1) They were introduced in 1997(c) with Disc-Brake in the front on 51" Track Width Axles
2) They were fitted with LSD in the rear semi floating axle, 51" Track Width.
3) In 2004 the NGCS MM550XD was introduced with
a) Box-Section Chassis
b) Wider Leaf Springs (Bolero/Maxx-Pikup/Marshal 2000)
c) Full -Floating Rear Axle with LSD with 53" Track Width
d) Open Knuckle Front Axles with new PCD (Scorpio/Bolero) and 57" Track Width.
To Support the Tyre weight you can reinforce the door with a full height plate/vertically orient and weld a U-Channel behind the Tyre Bracket and add 2 L-Shaped Angles under the door, where the hinges for the drop type tailgate were fitted.
Arka
Old 8th November 2008, 14:24   #119
Samurai's Avatar
Thanked: 14,526 Times
When I heard Army rim weigh 16Kgs when compared to regular 9Kg steel rim, I gave up all thoughts on Army rims. That's too much unsprung weight to add to the civilian model I feel.
Old 9th November 2008, 08:22   #120
Thanked: 624 Times
Samurai,
You are very right about the unsprung weight but there is any difference in the body and chasis specifications of the army or civilian 550?
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
