Old 12th August 2011, 17:09   #1306
darshan.ckm's Avatar
Thanked: 26 Times
Default re: The Offroad Rims & Tyres Thread
@ sreejeshmp:
i got the info from here: www.mrftyres.com/downloads/tyres_full.pdf
Checked with the local MRF dealer, he had no clue. He has asked a couple of days time to enquire and get back. If available, it looks like a good alternative.
darshan.ckm is offline   Reply With Quote
Old 17th August 2011, 01:20   #1307
Thanked: 7 Times
Hi friends,
Wanted your help in selecting the most suitable set of rims for Maxxis Bighorn 235/75R15LT tyres for my MM540 which will be used mostly for off-roading.
1. Would Gypsy rims give a negative offset and hence avoid the tyres touching the spring plates? Will this compromise the turning radius of the mm540?
2. Can we use Armada Rims with the same spec tyres ie 235/75R15? Does it have more or less negative offset? Is it better than the Gypsy rims?
3. Is there any other cost effective solution apart from Gypsy/Armada rims?
Need your expert views
Sanjay
shetsanju is offline   Reply With Quote
Old 17th August 2011, 07:53   #1308
jeepster's Avatar
Thanked: 1,024 Times
your only option is Gypsy rims or FC rims.
or costly alloys with 139.7 PCD.
or you can change the hubs to newer 160PCD & use safati/sumo/scprpio/trax/bolero/thar rims.
the tata rims (160 PCD) are with less positive offset than Mahindra. (thus axle track increases by 3inch)
jeepster is offline   Reply With Quote
Old 17th August 2011, 11:51   #1309
Thanked: 7 Times
Thanks Jeepster.
Pls correct me if I am wrong
Negative Offset = increased track width and hence less chances of the wider tyres touching the leaf springs/chassis
Positive Offset = vice versa
Standard mm540 rims have zero offset. Gypsy rims have negative offset (wider track). Can we mount a 235/75R15 comfortably on a Gypsy rim and fix it on a mm540 with no modifications required in the suspension set up and the steering lock-to-lock ratio. Another question is that would a 235/75 tyre make the steering of a mm540 too hard ?
Your specific inputs would be highly appreciated.
Thanks, once again.
Sanjay
Old 17th August 2011, 12:47   #1310
ladak.imran's Avatar
Hey Shetsanju,
How much are you paying for the bighorn tyres?
Last time I checked (about a couple of months ago), they were quoting more than 8k per tyre..
ladak.imran is offline   Reply With Quote
Old 17th August 2011, 15:30   #1311
Thanked: 7 Times
Originally Posted by ladak.imran View Post
Hey Shetsanju,
It is at 8200 INR per tyre. The dealer has last 4 in stock. Says some problems in import as Maxxis tyre are non ISO marked and blah blah.....
Even if I do buy the last 4, I am still one short........
Old 21st August 2011, 22:14   #1312
V-16's Avatar
Thanked: 855 Times
8200 is a great price. I think they are the 10.5x31x15". If they are then they are all above 10k now. I just bought Hankook Dynapro MTs for a friend for 9700/- Check the year of manufacture on these tyres. If its old better not to buy. But if you get four at this price and buy one at say 10k, the average cost comes to 8560/- which is also cheaper than the price in the market today. Id say if these are good tyres, pick them up ASAP!!
V-16 is offline   Reply With Quote
Old 24th August 2011, 19:05   #1313
karthik123's Avatar
Thanked: 35 Times
What is the usual price of jk sand cum highway tires ( mm550 ) , 7.50/16 size. I've been offered 7k per tyre, is it a good deal or I should negotiate ?
karthik123 is offline   Reply With Quote
Old 27th August 2011, 13:05   #1314
hamza's Avatar
Thanked: 71 Times
I was able to procure them for around 6k with apollo tubes. Try negotiating to 6500 atleast.
hamza is offline   Reply With Quote
Old 27th August 2011, 13:43   #1315
hamza's Avatar
Thanked: 71 Times
The cost also depends on your location, I was procured these in hyderabad.
Old 28th August 2011, 00:11   #1316
Thanked: 113 Times
In a recent discussion it was concluded that Gypsy rim offset is at least +10mm. See Post http://www.team-bhp.com/forum/4x4-te...ml#post2429181 (The Offroad Rims & Tyres Thread)
HTH
--Ragul
Ragul is offline   Reply With Quote
Old 31st August 2011, 23:54   #1317
Thanked: 32 Times
I find bounce levels on thar higher than my liking, especially on humps. Would reducing tyre pressure help? How is the bounce factor of AT-S geolander on city roads
vnambiar is offline   Reply With Quote
Old 1st September 2011, 06:37   #1318
headers's Avatar
Thanked: 464 Times
Changing the suspension setup will help! Adjust the IFS lower control arm - I'm told it has soft and hard settings that help change the front IFS settings. Playing with it will help control bounce as well as body roll
Experts could contribute better
Old 1st September 2011, 20:13   #1319
fazalaliadil's Avatar
Thanked: 625 Times
Originally Posted by hamza View Post
Needed help for procuring Apollo Bullet, MRF Sand grip tyres in Hyderabad. If someone has any information, and the current price estimate, please let me know. I'll be really grateful.
Hamza,
If you still require Apollo Bullet (5 no.'s) contact me on 98850 71025.
fazalaliadil is offline   Reply With Quote
Old 2nd September 2011, 18:13   #1320
DeClutch 4X4's Avatar
Thanked: 65 Times
'Insa Turbo Special Track'
I call these one's as Tyres with Attituide'
I am not sure about the performance, but the attitude this tyres throws with its appearence makes me stay inclined towards these tyres, though the tyres are reasonably priced, the culprits are the 'Cargo expenses and Customs duties' which makes it less affordable and finding it difficult to procure from UK.
Can Anyone help/provide some lead to buy these 'tyres with Attitude' from UK? I did get in touch with some export/import guys, but invain didnt help me much.
DeClutch 4X4 is offline   Reply With Quote
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
