Old 19th May 2012, 20:22   #1411
Endeavour333's Avatar
Thanked: 358 Times
Originally Posted by abheekg
Any idea what year were these tyres manufactured and what tyres are these. Google search is not giving me much info. I have picked these up for my upcoming monsoon explorations and as a standby set for my vehicles.
Dr. A Ghosh
Manufacture dates are found in markings like "DOT 5011" the first 2 digits of the number iste the week of the year and the last 2 digits are the year of manufacture. So this example tyres was manufactured in the 50th week of 2011. Find a similar DOT marking and you can tell when it was manufactured.
Endeavour333 is offline   Reply With Quote
Old 25th May 2012, 11:59   #1412
jeepbug's Avatar
Thanked: 71 Times
Default re: The Offroad Rims & Tyres Thread
Originally Posted by roy_libran View Post
^^^ I was targetting the 7.5x16 size only, as I said earlier. This Gurkha has earlier run on JK LT 4x4 in a 7.5x16 size, and it was just perfect.
The reason I brought up Speedways on this thread, is to understand what is the experience with these tyres w.r.t Braking On Road, Rubber Hardening, Rubber Cracking, Wear Off (Abration) Rates etc.
After all Tread Pattern isn't everything now. So, while we have talked about the NDMS-like tyre above, there are still these two:
1. How are the PK-303 Off the road?
2. Can the Gurkha handle R-1? Is it any good? I can consider moving to Alloys if it brings down the overall weight.
By the way, I am currently running on JK Elanzos (Highway Tyres - 6000 kms and around 10 OTR's). I have blown (and replaced) one of them due to a Sharp Rock penetrating the Sidewall. But, apart from that, they have performed decently, when brought down to about 20 psi.
Hi , i am using the r1 8.25 r 16 on ex army rims pcd 139 on my petrol cj3b and believe me it effortlessly climbs all heights and mountain sides which other diesels do with lot of howling and spinning.Rubber compound is not very hard , but is prone to cuts from rocks.you can get 750.16 r1 type for 4500 a piece and in my opinion you can take 2 for the front and use the same ones you have now on the rears with diffs.
jeepbug is offline   (1) Thanks Reply With Quote
Old 11th June 2012, 23:16   #1413
Thanked: 21 Times
Default Re: Bridgestone RD 703 Steel M+S
Originally Posted by abheekg View Post
What are the rivets for ?
Dr. A Ghosh
They look similar to what you get with winter cycling tyres.
bigman is offline   Reply With Quote
Old 13th June 2012, 23:32   #1414
Thanked: 57 Times
Originally Posted by jeepster View Post
PK-303 is rib type tyre. (similar to stock gypsy tyre)
R1 is R1 so check if your axles can take the additional load.
Military is NDMS pattern but very narrow design.
Attachment 909133
BTW some tyre retailers are not happy with speedways after sales service.
so think twice before buying.
rgds,
Nikhil
Hi Nikhil,
How much are the gripking plus for? Will they fit on our 550 army rims?
davids4x4mm550 is offline   Reply With Quote
Old 14th June 2012, 10:46   #1415
jeepster's Avatar
Thanked: 984 Times
Originally Posted by davids4x4mm550 View Post
Hi Nikhil,
yes,
7.50x16 will fit army rim.
but you will have to buy tyre + tube combo.
rgds,
Nikhil
http://www.team-bhp.com/forum/4x4-te...ml#post1493134 (The Offroad Rims & Tyres Thread)
jeepster is offline   (2) Thanks Reply With Quote
Old 14th June 2012, 11:14   #1416
Thanked: 762 Times
Gripking R-1 7.5x16 is for Rs. 3900/- if you order from company directly.
Nikhil - Thanks for posting pictures. Just love the way these tyres look, and the stance of your Jeep with these shoes is just brilliant.
Last edited by roy_libran : 14th June 2012 at 11:17. Reason: Merging Back to Back Posts
roy_libran is offline   Reply With Quote
Old 14th June 2012, 11:15   #1417
Thanked: 762 Times
Mods - Please delete Back to Back Post.
Old 14th June 2012, 17:11   #1418
Thanked: 57 Times
yes,
rgds,
Nikhil
Cool Thanks Nikhil/Roy will look at picking them up. Any idea if they have a dealer in MH or somewhere in Bombay/pune which will be easy to go pick it up. Also what Ply Options would be the best 4/6 or 8
Old 14th June 2012, 17:53   #1419
jeepster's Avatar
Thanked: 984 Times
this is not my jeep.
i just posted pics for reference.
the link to the post is given in my post.
rgds,
Nikhil
jeepster is offline   Reply With Quote
Old 14th June 2012, 19:21   #1420
Thanked: 762 Times
IMHO lighter the better, so 4 ply should be fine. Higher ply is for load bearing applications.
Old 14th June 2012, 21:32   #1421
Thanked: 57 Times
Originally Posted by vishwaschettri View Post
A few months earlier i met a common friend who works in R&D department of a tire manufacturing company.
But since this guy got them specially made for me I couldn't refuse and coughed up the money.
- these are 8 ply agricultural tires meant to take a lot of side wall abuse.
cheers
vishwas
Hi Vishwas are these the same Tyres form Speedking?
How much did you end up paying for these?
Are they a perfect fit on the army rims and same size/hight as the sand grips 235 - 85 - r16?
Will th 4 ply ones be good?
Thanks n sorry for so many q's
Old 14th June 2012, 22:39   #1422
Thanked: 245 Times
Hi David,
I think I paid around 18K-20K for the tires. This was almost 3-4 yrs back. IIRC I mentioned it in one of my posts on this thread. I don't recall the brand-name but they have their factory down the road from my place. My friend is no longer working there, he has switched trade. They fit perfectly on the army rim. In fact they are the only OE tires for 550 beyond sandgrip & bullet that I have managed to trace. 7.50 - 16. I would recommend 8 ply only as these are soft compound agriculture tires and you need 8ply to take trail abuse. Though with 8ply the tires do become heavy and rob some of the top whack.
Thanks for reviving this trail. I will take the opportunity to post a long term ownership update.
I have driven these tires for almost 15k kms by now and I think they have 10k more left in them. In this time apart from regular OTR's and city runabout, I have taken my jeep to 2 long trips, one a 800km trip through rajasthan and other a 2500km trip through spiti valley. On both occasions I did some serious voluntary and involuntary offroading. It came out trumps on all occasions.
ON the whole totally satisfied with the performance. And now since I have a Gypsy also, I can easily manage one set of MT and one road tires and swap them whenever I want.
cheers
vishwas
vishwaschettri is offline   (1) Thanks Reply With Quote
Old 15th June 2012, 18:50   #1423
Thanked: 57 Times
Hi David,
cheers
vishwas
Thanks for the review,
Since my jeep is hardly used on road i think i might go for these.
what about -ve offset rims on these will they cause any problems?
PS. Put up some update pics of your jeep with them on. love the look
Old 15th June 2012, 18:58   #1424
headers's Avatar
Thanked: 457 Times
Negative offset rims are not recommended of you wanna do hard core offroad..
If you are a wannabe, then it's ok..
The negative offset rims affect the wheel bearings as well as suspension geometry..IMO..
Old 15th June 2012, 21:27   #1425
Thanked: 57 Times
hahahaha a wannabe with tractor tires on.... i dont think so .....
I was always of the opinion that a wider track works better off road.
davids4x4mm550 is offline   (1) Thanks Reply With Quote
Mumbai's Offroad Junkie goes international! Builds offroad track for Mercedes, Hong Kong GTO 4x4 Excursions 12 24th December 2015 14:01
Tubeless tyres on Steel rims RJK Tyre & Alloy wheel Section 185 18th June 2014 16:01
New Tyres and rims ... urgent bamboo Tyre & Alloy wheel Section 39 16th November 2007 20:58
