Old 16th April 2008, 10:54   #61
Samurai's Avatar
Thanked: 15,776 Times
You not only have 3 diffs, but also have 3 diff locks. That makes a huge difference when you are stuck. Mine has 3 diffs, but only 1 diff lock (central). The front and rear open differentials can be a problem if one of the wheels lose traction, as I experienced lately.
Old 16th April 2008, 11:06   #62
Thanked: 253 Times
Couldn't quite understand this.
One wheel loses traction: how does this represent a problem?
Can you elaborate please?
Old 16th April 2008, 11:38   #63
Samurai's Avatar
I mean in each axle, I have mentioned front and rear in that sentence. One wheel spin in each axle will make my GV sitting duck. Hope this clarifies.
Old 16th April 2008, 12:15   #64
tsk1979's Avatar
Thanked: 16,422 Times
A safari has front and rear diff's no locks, but LSD.
Does this mean that if one wheel is in the air and is spinning freely, the other wheel on the same action will also spin(albeit at a slower speed?)
Old 16th April 2008, 12:55   #65
Samurai's Avatar
Actually it is better than having open diffs. If one wheel spins on the rear, it will force the other rear wheel to turn, therefore it won't get stuck.
But it also depends on the type of LSD. The viscous/clutch type LSD works as described above. But the torque sensitive LSD needs some torque on the spinning wheel. If one wheel is free-spinning, then there is no torque, then the other wheel has no torque either. Remember, torque is the minimum force required to make the wheel turn. In such cases, applying brakes on the spinning wheels can recover some torque.
Old 16th April 2008, 13:45   #66
tsk1979's Avatar
I don't think the Safari has a torque sensitive setup, its a viscous type LSD. I think some safari 4x4 experts can elaborate.
Italian boys.. any ideas?
Old 16th April 2008, 14:28   #67
Alfa_Kilo's Avatar
It has a clutch (ie friction) based LSD (only in 4x4) on the rear axle. It connects the two halfshafts through a slipping clutch. Its works in a manner similar to the main clutch, when partially engaged.
Alfa_Kilo is offline   Reply With Quote
Old 16th April 2008, 14:56   #68
tsk1979's Avatar
So front axle is open.
This means unless both rear wheels lose traction, you won't get stuck.
Old 17th April 2008, 03:21   #69
Ignazio's Avatar
as torque is splitted by transfer case to 50% front and 50% rear, if the two back wheels are spinning but the front are some how gripping to the ground you will not get stuck, front will pull you...
Safari, after 2000 TL and new Xenon, they all have cutch LSD at the back and open diff. at the front.
Mounting soon a diff lock on mine, when money permit... It's a '98, so just open diff front and rear but is climbing quite well!!!
I'll post some video soon!
Ciao
Ignazio
Ignazio is offline   Reply With Quote
Old 17th April 2008, 18:39   #70
Alfa_Kilo's Avatar
It can get stuck if one of the front and rear wheels hast lost purchase, and the other rear wheel is not being 'supplied' enought torque through the LSD to get things moving. Clutch based LSD have some 'lock' ratio, like say 30%. So the tyre with better traction will always recieve atleat 30% of maximum torque at the rear axle. Some clutch based LSDs tend to heat up quickly and degrade during heavy use.
Old 6th June 2008, 12:44   #71
headers's Avatar
Thanked: 464 Times
Originally Posted by gd1418 View Post
I encountered nearly 30 deg incline. I could be wrong but indeed it was a steep climb and I saw many a vehicle including a couple of lancers, omnis and a tavera going up a few distance and then loosing power and rolling back. I also tried in my safari in 2WD mode and midway the engine nearly stalled.
It was a metalled road and I had to engage 4H to climb up. When I returned back I went to garage get it checked for any damage to tranny & differential. There was none and I was assured that if at all one gets into a sticky situation 4WD can be used.
Like all others said it shouldn't be used over a long distance at a speed on metalled surfaces.
You will not damage the tranny and differential unless you drive in 4wd for a long time say 1000 kms or so on tar roads.. The gears are all hardened and tempered to without a fair amount of abuse.
This is a great technique even in 2wd when one gets stuck and both wheels are spinning. Apply brake gently until one of the wheels stop rotating and the vehicle will move forward!
Old 6th June 2008, 13:13   #72
Alfa_Kilo's Avatar
Have you done this Headers? To my understanding, this works only in vehicles with torsen type diffs or if the brakes can be selectively applied/brake bias is laterally unsymetrical.
Old 6th June 2008, 13:21   #73
Blue Thunder's Avatar
Thanked: 335 Times
this will work even in the standard diff., but as headers as mentioned, it has to be done in a certain way .
Blue Thunder is offline   Reply With Quote
Old 6th June 2008, 13:31   #74
tsk1979's Avatar
Well have tried it in the indica, and it does not work. Maybe it works in RWDs with drum brakes which are not as grippy as the discs.
Or maybe I need 100 horses more.
Old 6th June 2008, 13:54   #75
headers's Avatar
Thanked: 464 Times
Or maybe you need the right technique, Tanveer Sir!
Mahindra 4WD vs Modern 4WD Samurai 4x4 Technical 137 19th February 2012 19:46
CL340-4WD wish list - what you really want in your CL340-4WD? DHABHAR.BEHRAM 4x4 Technical 43 23rd December 2010 00:05
Armada Grand 4wd or Bolero 4wd? VEA 4x4 Vehicles 38 25th July 2010 01:50
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
