Old 16th March 2008, 18:41   #16
narayan's Avatar
Thanked: 1,217 Times
wow ..Great install
the first few pictures also shows clearly the uniqueness of the GV CHASSIS - which marries a monocoque and ladder frames inbuilt in the monocoque.. ( i wonder whether this is only used in GV or in any other "soft roader " also )..
Samurai - does the ride become very noisy over pebbled roads ? with those pebbles banging against the sheets (im sure that must be music to your ears ) but still is it too annoying or within limits ?
narayan is offline   Reply With Quote
Old 16th March 2008, 19:42   #17
Thanked: 64 Times
Amazing narration of the complete install. You will indeed prove to the naysayers that GV is a true off-roader
hondadude is offline   Reply With Quote
Old 16th March 2008, 22:00   #18
theMAG's Avatar
Thanked: 1,492 Times
Samurai,
Any problems of resonance vibrations with the metal plates??
Old 17th March 2008, 00:42   #19
IronWolf's Avatar
Thanked: 36 Times
Congrads Samurai. You said you never did any modifications? This job looks like you have about 10 years of experience doing Skid plates.
Most impressed with the U-shaped steel bracket to mount the rear skid plates. Looks like a part from a parts catalog.
I feel like I know nothing about cars when I read such posts :(
Brilliant job, Sam.
IronWolf is offline   Reply With Quote
Old 17th March 2008, 08:06   #20
hellstar's Avatar
Thanked: 17 Times
Amazing example of ingenuity , way to go Samurai !
Congrats on you all terrain ready GV ! Happy Off roading
hellstar is offline   Reply With Quote
Old 17th March 2008, 09:10   #21
vikram_d's Avatar
Thanked: 937 Times
In my opinion you should have used SS checkered plates for this as they are much stronger and also will not corrode. The down side of them is they weigh 3 times as much.
PS: Just found out that aluminium checkered plate is also available. This plate 2.5 times stronger than a normal plate with about 10% more weight.
Old 17th March 2008, 09:25   #22
Samurai's Avatar
Thanked: 14,536 Times
Thanks guys.
I haven't driven it around in various road and off-road conditions yet. You'll have to wait for this data.
But, I didn't do the work, it was those couple gentlemen from the local M.A.S.S.
We had so much trouble bending this sheet, how are we supposed to bend a sheet 2.5 times stronger? As I mentioned before, we needed a good compromise between strength and flexibility. The sheet should be flexible enough to let the chassis twist as required.
Old 17th March 2008, 09:30   #23
esteem_lover's Avatar
Thanked: 447 Times
Nicely done samurai. Also great to know that your local maruti garage has taken so much interest in this project, makes it a first of its kind. I guess it is time to bring the GV to kelambakkam.
Old 17th March 2008, 09:43   #24
hydrashok's Avatar
Congrats, Samurai! Now you've got an off-roader you can drive anywhere and back!
You're lucky to have such dedicated (and interested) folks at your A.S.S..
And thanks for that great pictorial. Now I too know what skidplates are, and what they are for
All the best with stage 2
Old 17th March 2008, 09:52   #25
vikram_d's Avatar
Thanked: 937 Times
It will be easy to bend if you heat the sheet using a blow torch. Makes life a lot easier.
Old 17th March 2008, 09:55   #26
Prithvi's Avatar
Thanked: 21 Times
Congrats to you on the excellent job. My hats off to the guys at Maruthi for doing this for you. They really need to be appreciated for going out of their way to do this. Maybe other GV owners can get their cars done at the same place and Maruthi charge them a small premium for doing a fantastic job.
Prithvi is offline   Reply With Quote
Old 17th March 2008, 10:00   #27
blueraven316's Avatar
WOW!! looks like a neat job and a good upgrade for the underbelly.
Happy offroading !
blueraven316 is offline   Reply With Quote
Old 17th March 2008, 10:10   #28
razor4077's Avatar
Thanked: 252 Times
Very nice job Samurai. I must say it was very nice of the MUL folks to help like they did. I wish the A.S.S's I deal with (pun intended? ) were half as accommodating and professional.
Happy off-roading! Now you can drive with impunity like those Jeeps!
razor4077 is offline   Reply With Quote
Old 17th March 2008, 11:04   #29
Su-47's Avatar
Thanked: 91 Times
Congrats Samurai.
That sounds like a good tip. Thanks!
Su-47 is offline   Reply With Quote
Old 17th March 2008, 11:05   #30
viper's Avatar
Hi Samurai,
Excellent narration and pics. Very nicely executed job.
I second that but anyways its already done. You will now have to see how the skid plates take on abuse from rocks as mud is a different ground. All the best to you.
Viper
viper is offline   Reply With Quote
IND-style Number Plates : Movell Captain Slow Other Cities 46 22nd December 2017 15:19
Basic Swift touring mods in Delhi (HID, skid plates, GPS mount) - what else? phamilyman Modifications & Accessories 36 7th November 2013 12:06
CS gets the "indigo" look, diesel gets beige interiors, XL grand discontinued sidindica The Indian Car Scene 18 19th February 2009 17:11
Where can customized license plates be made in Pune city? InternetUser Modifications & Accessories 2 14th March 2008 14:36
