Old 20th March 2008, 16:50   #46
Thanked: 245 Times
A salute to the conceiver, executer and the whole team involved in this. A very well planned task.
You got good support from the A.S.S too. What a bunch of enthusiasts!!!.
btw, did you check how much weight did the whole thing add to the GV.
Old 20th March 2008, 16:54   #47
Thanked: 20 Times
A well planned, executed project. Nothing else gives as much satisfaction as it does.
Great work and even better explanation of it, Samurai. Enjoy your offroad experiences.
Jeep is offline   Reply With Quote
Old 20th March 2008, 20:02   #48
rjstyles69's Avatar
Thanked: 795 Times
Super cool job there my friend, missed this thread somehow.
Now we all know where to head in case something like this is needed .
Old 20th March 2008, 20:35   #49
Technocrat's Avatar
Thanked: 2,589 Times
Excellant Pictorial Samurai.
This looks great,I am sure you must be feeling much more confidant off roading with these plates.
Congratulations
Old 20th March 2008, 23:02   #50
munishsurendra's Avatar
Fantastic work and a great discription with pics.Congrats and enjoy your ride.
Well, Wats the total cost involved?
munishsurendra is offline   Reply With Quote
Old 20th March 2008, 23:19   #51
hkanitkar's Avatar
Thanked: 30 Times
Holy shmuks... we are really a mad bunch of car lovers here !
Awesome work Samurai san ! Hats off !!
hkanitkar is offline   Reply With Quote
Old 21st March 2008, 13:13   #52
Samurai's Avatar
Thanked: 15,755 Times
Thanks for all the overwhelming feedback. I am still awaiting the bills.
As expected, the GC has decreased. It used to be 200mm at the transfer case near the center of the wheel base, which was the lowest hanging and vulnerable part. After the skid plates, the GC is down to 170mm, but can take hard hits.
No, it doesn't hit big speedbumps, I have lots of them around. Even if it hits the speedbump, I don't need to worry, not at the low speeds one crosses big speedbumps...
Old 21st March 2008, 19:01   #53
vivekiny2k's Avatar
Thanked: 184 Times
I have a weird feeling you are scouting for lift kits now cheers:
Edit: Good job by the way, I prefer getting bare minimum cars/bikes and adding pieces of my own choice. My interior upgrade is pending for my Quest.
vivekiny2k is offline   Reply With Quote
Old 22nd March 2008, 01:21   #54
aah78's Avatar
Thanked: 1,746 Times
Thumbs up air bag
Originally Posted by vivekiny2k View Post
lift kits
Are you talking about the air-bag kits - the ones which can lower and raise your car/SUV?
They're nice but the costs can be around a lakh of Rupees, or more.
aah78 is offline   Reply With Quote
Old 24th March 2008, 10:35   #55
Samurai's Avatar
I did some mud-plugging on my birthday to see the efficiency of the skid plates.
The plates definite provide bullet proof protection, but it also got me into trouble, more than once. The front two plates are fine, but the three rear plates mounted on brackets are reducing the GC royally and I couldn't get over certain obstacles because of them. I think I should not keep the rear plates permanently mounted, but use them only when going on rocky road safaris.
Old 24th March 2008, 11:53   #56
nitrous's Avatar
Thanked: 285 Times
6mm is a big difference in GC?
nitrous is online now   Reply With Quote
Old 24th March 2008, 12:56   #57
smsrini's Avatar
Thanked: 272 Times
Default Kudos on this effort
Kudos on the effort. Ingenious thinking and brilliant execution.
Normally the underside of a car is designed for two purposes : Cooling and aero dynamics. The grooves or channels in the stock skid plates are supposed to achieve this. To some extent the wind noise as well.
It would be interesting to see how this modification affects the two parameters.
Agree Aluminium can be a good heat sink if fabricated properly. I say this since the heat sinks I've seen are typically with a lot of 'fins' that aid to dissipate the heat rather than a flat surface.
smsrini is offline   Reply With Quote
Old 24th March 2008, 13:25   #58
Rehaan's Avatar
Thanked: 25,037 Times
6mm is only the thickness of the sheet.
The sheet is in fairly flat peices and does not conform to the underside as a perfect/glove-like fit, therefore the increase is a lot more than 6mm. Add to that the additional drop in clearance due to the mounting brackets etc.
cya
R
Old 24th March 2008, 13:47   #59
Blue Thunder's Avatar
Thanked: 335 Times
Post
Samurai mentioned a loss of GC to the extent of 30mm.
...As expected, the GC has decreased. It used to be 200mm ... After the skid plates, the GC is down to 170mm, ...
Blue Thunder is offline   Reply With Quote
Old 24th March 2008, 19:26   #60
nitrous's Avatar
Thanked: 285 Times
30mm difference is too much.
Calls for a redesign at the mounts,Sharath Power ji
IND-style Number Plates : Movell Captain Slow Other Cities 71 29th May 2018 08:35
Basic Swift touring mods in Delhi (HID, skid plates, GPS mount) - what else? phamilyman Modifications & Accessories 36 7th November 2013 12:06
CS gets the "indigo" look, diesel gets beige interiors, XL grand discontinued sidindica The Indian Car Scene 18 19th February 2009 17:11
Where can customized license plates be made in Pune city? InternetUser Modifications & Accessories 2 14th March 2008 14:36
