Old 4th August 2008, 16:21   #76
sudev's Avatar
Thanked: 2,433 Times
Good point about oil change holes. BUT having learned from rallying experience I feel it is better to take out the plate by loosening four bolts than risk leaving a hole. But in any case the car is on way to Leh as we discuss. So what ever we will know once they are back.
sudev is offline   Reply With Quote
Old 13th September 2008, 10:32   #77
Samurai's Avatar
Thanked: 14,538 Times
Originally Posted by sudev View Post
This vehicle (with four adults and luggage) is going do Delhi-Manali-Leh-Srinagar-Delhi route starting tomorrow and the owner was particular about getting this done as last time in the Raid his only ostensible reason (as if he needed one) to drop about was citing a punctured tank - despite having a tank guard on his Baleno. I know Raid is tough and the member felt cheated of not having made it to night halt where the raid was ultimately aborted.
So once he is back I would post some more pictures. And i am sure he has read this too - as he is amember here - so drive safely. ;-)
Sudev, you never posted the reviews for this skid plates job, how did it perform on the Leh trip?
Old 13th September 2008, 11:26   #78
sudev's Avatar
Apologies...will collect pictures and post.
Verbally i was told that GV survived (in hands of a rather punishing driver who is also on these forums I believe) the trip and he was rather thankful that he had the skid plates else...
Old 15th September 2008, 12:48   #79
NIP
NIP's Avatar
Thanked: 81 Times
i somehow missed this thread completely !!! amazing effort and fantastic job samurai ! gotta hand it to you and your enthusiasm true off roader you are !
NIP is offline   Reply With Quote
Old 17th September 2008, 12:34   #81
tsk1979's Avatar
Thanked: 15,684 Times
sudev, forum software does provide for inline commentry. Look at all travelogues!
All you have to do is remember the sequence you posted the attachments in.
The announcements section clearly describes how to do this
Old 28th September 2008, 13:54   #82
sudev's Avatar
Since I was heading out to Leh next week I also got under body protection fitted on my GRV.
Surprisingly the lowest ground clearance is from the exhaust but this is not protected as I feel at worst I will get some holes in the system but will not be a car grounding event. No difference in the GC under the engine vis the original plastic cover.
sudev is offline   (1) Thanks Reply With Quote
Old 28th September 2008, 23:47   #83
Samurai's Avatar
Sudev, looks like you are using 3mm checkered aluminium sheets. The fit and finish is much better than mine, may be because the 3mm sheet is easy to bend.
What about the transfer case, I don't see protection for transfer case. Can I get close up shots of the rear plates.
Old 29th September 2008, 07:54   #84
sudev's Avatar
@Samurai - The pictures of the first GV show that the transfer case is protected by the engine plate itself. I will post my vehicle pictures but that may be after I am back from Raid-De-Himalaya.
Old 30th September 2008, 17:12   #85
Shakensoul's Avatar
Thanked: 221 Times
@sudev - Is it possible to get some basic skid plates installed in a WagonR ?
Planning on a Leh trip next year, so was thinking of getting some underbody protection. Would appreciate if you can throw some light and the approx cost.
Shakensoul is online now   Reply With Quote
Old 9th October 2008, 18:24   #86
sudev's Avatar
@Shakensoul : Why not. I got mine done at MotorCraft, Sahibabad. Or you can head for Performance in Sec2 NOIDA.
Old 9th October 2008, 21:30   #87
Shakensoul's Avatar
Thanked: 221 Times
Thanks. Performance Auto as in below ?
http://www.performanceauto.in/intro.asp
Which one do you recommend for a cost effective solution ?
Old 25th October 2008, 11:12   #88
gd1418's Avatar
Thanked: 656 Times
Scorpio has only one skid plate made of hard plastic. I spoke to my FNG and was told that one in iron sheet of 18" or 20" gauge can be fabricated.
Your take on this and any other input??
Old 25th October 2008, 12:32   #89
sudev's Avatar
@Samurai: Chequered are not easier in bending but due to surface patter generally have more strength and resist distorting.
@gd1418: I would advise against iron sheet. Too much weight and 18 gauge (I think it is <2mm) would be too thin. Aluminum is lighter and relatively easier to bend and manipulate. One or more depends on your intended use and vehicles "weak" points that you would like covered. Plastics sheets are more for wind and noise reduction than protection.
Old 26th October 2008, 10:13   #90
RedMM340's Avatar
Thanked: 23 Times
The fitup quality of your skidplates look really good. The installer did a very professional job.
Can you post an address and contact number for MotorCraft, Sahibabad.
Thanks.
RedMM340 is offline   Reply With Quote
IND-style Number Plates : Movell Captain Slow Other Cities 46 22nd December 2017 15:19
Basic Swift touring mods in Delhi (HID, skid plates, GPS mount) - what else? phamilyman Modifications & Accessories 36 7th November 2013 12:06
CS gets the "indigo" look, diesel gets beige interiors, XL grand discontinued sidindica The Indian Car Scene 18 19th February 2009 17:11
Where can customized license plates be made in Pune city? InternetUser Modifications & Accessories 2 14th March 2008 14:36
