Old 24th March 2011, 19:15   #106
Thanked: 16 Times
Default Re: Grand Vitara gets custom made skid plates
Interesting discussion and fabulous work by both Sudev and Samurai- Hats off to you guys.
@ MexXxentric: what if we were to invert the chequered plate Im sure you would still get the strength as well as the smooth surface on the outer side.
@ Sudev, Samurai & allExperts: Please comment on my above observation.
regards
salil
scphanse is offline   Reply With Quote
Old 30th June 2014, 13:57   #107
rattanw's Avatar
Thanked: 102 Times
Mr. Sudev - I just came across this 5 year old thread. I am also looking to get some underbody protection for my GV. I notice you have mentioned details of Motor Craft - Sahibabad and Noida. My questions are as below
- What is the total cost of protecting the underbody through custom built aluminium checkered plates (identical to the job done for your car)
- Where will you recommend I get it done from, Sahibabad or Noida
- Any other points I need to be careful about while getting this bit of customization done. Again I am looking for exact same specifications as for your car, unless you have made any more changes recently.
thanks
rattanw is offline   Reply With Quote
Old 11th October 2016, 10:47   #108
Tanmay K's Avatar
Thanked: 182 Times
Originally Posted by sudev View Post
Go with chequered plates and not plain aluminium sheet. Former are much more resistant to bending. IMHO 3mm should be good.
Sir, I'm planning on installing skid plates on my GV too. Work will be done at a FNG most likely. Do you happen to know what type of aluminum alloy (5182 or 5754 or 6061 etc.) was used in your vehicle in these checkered sheets?
I'm in touch with an aluminum sheets supplier and have to decide what kind of strength will I need.
Tanmay K is offline   Reply With Quote
IND-style Number Plates : Movell Captain Slow Other Cities 72 21st July 2018 14:44
Basic Swift touring mods in Delhi (HID, skid plates, GPS mount) - what else? phamilyman Modifications & Accessories 36 7th November 2013 12:06
CS gets the "indigo" look, diesel gets beige interiors, XL grand discontinued sidindica The Indian Car Scene 18 19th February 2009 17:11
Where can customized license plates be made in Pune city? InternetUser Modifications & Accessories 2 14th March 2008 14:36
