Old 19th March 2008, 17:48   #16
Thanked: 655 Times
Good one. Seriously however I doubt if the guys from TATA who reply to queries even know what a transfer case is!
jyobeb is offline   Reply With Quote
Old 19th March 2008, 17:57   #17
Blue Thunder's Avatar
Thanked: 336 Times
Post
To some of them, "transfer case" probably means a box with which to move bottles of beer around
Anyway, as Ignazio has mentioned, you can probably try cleaning the electrical contacts : this may not require any major dismantling. I dont think it should be a problem in the tcase itself : I fell it is just some loose contact in the electrical/tronic circuit.
Blue Thunder is offline   Reply With Quote
Old 19th March 2008, 18:23   #18
Thanked: 655 Times
I removed the connectors, sprayed contact cleaner on them, reconnected and tried again with no luck. Now I need to decide if I want to try Ignazio's suggestion of removing the motor, or head out to the dealer.
Old 19th March 2008, 18:30   #19
Thanked: 336 Times
Post
then it is probably a better idea to go to the dealer.
Old 19th March 2008, 18:43   #20
Ignazio's Avatar
Hi
I'm sorry did not work... Take the motor down is not that complicate as it may appear, few bolts and it is off. The only electrical connection is the one you try to clean already. If save a bit on diy is your target, try, trust me! In the worst case scenario you can go to TATA dealer and by a new motor and replace it.
Bear in mind that you can drive the Safari without Tcase motor, no problem.
Some friends in Tata club Italia had the same problem, this was due to a position contact failure inside the motor gear. In Italy it is a very expensive part so some tryed to repair it.
A BIG GOOD LUCK!!!
Ciao Ciao
Ignazio
Ignazio is offline   Reply With Quote
Old 19th March 2008, 20:38   #21
susan3004's Avatar
Thanked: 124 Times
I am sure the vehicle is still under warranty of that sort. If DIY does not help, the company may make an issue out of it and put the blame on us.
I personally feel that it must be taken to a dealer.
susan3004 is offline   Reply With Quote
Old 20th March 2008, 00:09   #22
Thanked: 655 Times
Warranty is over, but dealer is a good friend.
Old 20th March 2008, 04:35   #23
DirtyDan's Avatar
Thanked: 785 Times
Default Oh???
Originally Posted by suman View Post
LOL, are you serious! You should send them a stinker for misleading you. By the way, you do have the sticker on your windshield glass, right? It clearly mentions "Do not march the vehicle till 4H/4L indicator stops blinking". And these guys are asking you to drive it in reverse till it engages? What are you supposed to do if you are actually in territory where you need 4L immediately - drive around till you hear it "engage". Man, this is unbelievable!
The same sticker also mentions asks you To Unlock/freewheeling 4L-4H-2H, Reverse (if moving forward) or Forward (if in Reverse). This is standard procedure for DISengaging that I always follow. Till date, I haven't needed to follow this for engaging. LOL
You could be right, the manual does mention that continuous blinking indicates electrical malfunction.
Jyobeb, eitherways, get it across to a service station at the earliest opportunity.
For 3 years I was a test driver for Dana-Spicer, one of the world's prime suppliers of four wheel drive components. I test drove many 4 wheel drive vehicles and many which were very difficult to get into and out of 4 wheel drive whether high or low. Our test books, written by design engineers, specifically and in detail instructed us to follow the procedure that you say is so ridiculous, going into reverse and then forward for a short distance etc.
This was not standard procedure but a troublshooting or emergency procedure.
Old 20th March 2008, 09:39   #24
suman's Avatar
Thanked: 265 Times
Dan, I know that you were with Dana Spicer, have read that on many an occasion. The point is, this is not supposed to happen while engaging 4wd, it is a necessity while disengaging. I would also assume that over time, mechanisms have become far more refined & I don't know how many of my 4x4 brethren face problems while engaging 4L. I haven't heard of too many cases.
As you have pointed out yourself, it cannot be a standard procedure for engaging because, in an emergency then, it would never engage. Lol
Old 20th March 2008, 10:29   #25
Thanked: 245 Times
More convenient on the fly, even if the vehicle is moving.
Mechanical ones need you to stop engage and then go.
Off-Topic, but why don't companies just stick with a mechanical transfer case rather than electric? More durable and reliable.
Old 20th March 2008, 10:41   #26
Alfa_Kilo's Avatar
Mechanical synchromesh TCases can shift on the move. The older constant mesh TCases require stopping.
Alfa_Kilo is offline   Reply With Quote
Old 20th March 2008, 10:48   #27
suman's Avatar
Thanked: 265 Times
In any case, for 4L, you need to stop & engage (whether transfer case is shift-on-the-fly or not) - at least, that's what's recommended on my Safari.
Old 20th March 2008, 13:08   #28
gd1418's Avatar
Thanked: 656 Times
My grandfather had a Willys 4x4 jeep. I did not know much about cars etc., at that time but what I remember very vividly was after crossing the Ganges by bridge into Ramnagar (Benares) there was an Ashram that we used to visit regularly, and it was total mud road with soft moist mud & slush all the way. As soon as the jeep used to get stuck at some point, the driver simply used to engage the 4x4 mechanism by using the other gear lever and the jeep used to lurch forward effortlessly.
That remained etched in mind. Based on that premise, a 4x4 should be functional in an emergency. You don't require it for day-to-day running. If the vehicle is stuck and your 4x4 mechanism, whether manual or on-the-fly, requires moving forward or backward to engage, then it is of no use. I bloody well get it towed for all that it matters.
My 2 cents..
Old 20th March 2008, 13:11   #29
suman's Avatar
Thanked: 265 Times
That was exactly the point I was trying to make. Thanks for reiterating GD
Old 20th March 2008, 13:42   #30
tsk1979's Avatar
Thanked: 16,459 Times
Gypsy had a mechanical transfer case, and you could shift to 4H on the fly.
for 4L you needed to stop the vehicle.
And Suman,GD, you are right. For Engaging 4H or 4L you do not need to do this circus. Its disengaging procedure which requires this.
Jyoyeb, go to the Tata dealer, hopefully there will be somebody there who is clued to this transfer case
My Maruti Wagon-R F10D: Beyond 10 Years & 239,000 kms paragsachania Long-Term Ownership Reviews 388 29th May 2018 14:04
Swift DZire 2009 Immobiliser Lock Light Flashing vigsom Technical Stuff 7 10th June 2012 22:52
Spotted : Black Subaru WRX StI. EDIT : Crashed and Now Fixed & Painted Orange varun_patra Super-Cars & Imports in India 321 8th July 2011 22:58
What is the red light flashing on alarm switch on Swift? NVI2112 Technical Stuff 4 19th May 2010 12:39
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
