Old 20th March 2008, 16:02   #31
Thanked: 245 Times
OT: Experts suggest to engage the 4WD before you enter such territory and not once you are in the soup of it.
Originally Posted by gd1418 View Post
As soon as the jeep used to get stuck at some point, the driver simply used to engage the 4x4 mechanism by using the other gear lever and the jeep used to lurch forward effortlessly.
I have driven the earlier gypsies and IIRC you had to get down the lock the front wheels before any of the 4L/H could be engaged and I had to use it once, but gypsy is so light that it kept on skidding sideways on that rainy day
I think that was changed in the later versions.
Gypsy had a mechanical transfer case, and you could shift to 4H on the fly.
for 4L you needed to stop the vehicle.
Old 20th March 2008, 16:05   #32
suman's Avatar
Thanked: 257 Times
Even so, imagine having to go back & forth at the mouth of such territory for 15 minutes to try & "engage" 4L
And there are times when you realize that 4H may not do the trick & you need 4L - so you're almost in the middle of it & then you again go back & forth.......Lol, I'm feeling dizzy even thinking about it
Old 20th March 2008, 16:27   #33
Thanked: 245 Times
I dont disagree with this, although as Dan said it should be tried only as a makeshift solution.
Old 20th March 2008, 16:31   #34
Thanked: 1,506 Times
Based on that premise, a 4x4 should be functional in an emergency. You don't require it for day-to-day running. If the vehicle is stuck and your 4x4 mechanism, whether manual or on-the-fly, requires moving forward or backward to engage, then it is of no use. I bloody well get it towed for all that it matters.
My 2 cents..
Invaluable 2 cents, Guruji!
I agree - if it isnt available in an emergency, it is decorative.
Steeroid is offline   Reply With Quote
Old 20th March 2008, 18:55   #35
Thanked: 647 Times
OK an update. Today I went to the service sentre. Over there, we removed the motor of the transfer case, as suggested by Ignazio. A very simple and straightforward procedure. The finger of the transfer case shift was exposed.
I then manually shifted to 4H and moved the car. Then manually shifted to 4L and moved the car. Both times it worked just fine. Thus ruled out a defective transfer case.
Then reconnected the connecter on the exposed motor and put 4H on the swith. The motor moved to its correct location. However it stayed in the same place even when I shifted to 4L.
After that we checked all the wires for continuity and ruled out any problems with the wires.
Then as per the manual, we connected a wire with a 2 watt bulb, with one end connected to the ignition and the other connected to pin 22 of the borg & warner ecm. This should have made the 4WD light indicators flash in a particular manner which could have let us identify the fault from the sequence of flashes. However the 4wd indicator remained unlit.
Now a report has been sent to TATA motors, who will let me know what the next step is. My car is however, back with me.
Ignazio, any more suggestions please?
I did not remove the sensor cover on the motor as I don't know what to expect. Is it a straight forward removal like the motor?
4L light keeps flashing in Safari Dicor Edit: now fixed-20032008009.jpg
4L light keeps flashing in Safari Dicor Edit: now fixed-20032008004.jpg
4L light keeps flashing in Safari Dicor Edit: now fixed-20032008002.jpg
jyobeb is offline   Reply With Quote
Old 20th March 2008, 22:07   #36
Ignazio's Avatar
Hi all,
Well done mate! I told you it is easy!
Ok, we now know that it can only be a faulty motor or a faulty ecm. On average, ecm is not likely to be responsible of the problem.
Have a cup of tea, sit on a table, take your patience and open the motor. You likely will find a piece of plastic broken, take some pictures (well done for the first ones!) and show us. I think, that once opened you can find the trouble.
Ideally will be to have another equal motor to be tested before opening yours... Any friends with Safari, Sumo or TL 4x4?
Ask meanwhile of what parts and at what price are available at TATA. Maybe just worth to replace the faulty motor...
Hope this help!
Ciao Ciao
cheers:
Ignazio
Ignazio is offline   Reply With Quote
Old 21st March 2008, 03:57   #37
DirtyDan's Avatar
Thanked: 747 Times
Default And which?
And which would all you "experts" like to try first, this or simply backing up and going forward?
DirtyDan is online now   Reply With Quote
Old 21st March 2008, 10:55   #38
DKG
DKG's Avatar
Thanked: 929 Times
Perhaps of interest to some, the procedure of reversing and moving forward was recommended by Toyota on their Landcruiser GXR (which I had) to disengage free wheeling hubs. It was not for disengaging four wheel drive. That you did purely by shifting into 2 wd
After a session of 4 wd even when you shifted out of 4 wd the front axles spun along with the hub creating unnecessary drag (consume more fuel)
After you shift out of 4wd you had to stop, reverse a few meters and then move forward. As you did that you heard a clicking sound disengaging the front hubs/axles rendering the vehicle pure 2 wd
Just some info
DKG is offline   Reply With Quote
Old 21st March 2008, 11:19   #39
vinod_nookala's Avatar
Thanked: 411 Times
Best thing to do is to wait for TATA motors to get back to you. If the ECm is faulty let them get it replaced under warranty. It costs a bomb beyond warranty. What ever please donot open it on your own. Same goes with the motor. You can learn every bit of it at the dealers point while getting opened. Electric shift trnasfer cases have such problems and specially so with TATA. Keep in touch with TATA's local area office.
best regards
vinod_nookala is offline   Reply With Quote
Old 21st March 2008, 12:25   #40
FlyingSpur's Avatar
Thanked: 1,331 Times
The car begs you to take it off-road? :-)
FlyingSpur is offline   Reply With Quote
Old 21st March 2008, 14:23   #41
Out of interest, have you checked the connections to the Transfer Case ECM? You have 2 ECMs on the 4x4s, one regular ECM that is found on all Safari's (under one of the seats) and the other for the 4x4 (under the other seat). I cannot remember which one is under the driver's seat and which one under the passenger seat, but it may be possible that one of the connectors has been dislodged.
Old 21st March 2008, 15:11   #42
Ignazio's Avatar
Hi all
Just some info
Same is for the Tata vehicles equipped with automatic free wheel hub...
Also, if you are in danger situation and need 4wd in reversing, they disengage causing a trouble!
That is why if you are going offroad, for business or fun it is always better to have permanent lock hubs, or manual lock/unlock. This will avoid any reverse engage disengage problem!
Ciao Ciao!
cheers:
Ignazio
Old 21st March 2008, 17:10   #43
Thanked: 647 Times
Yup, checked the ecm. The 4X4 ecm is under the drivers seat.
Old 22nd March 2008, 17:08   #44
Thanked: 647 Times
Default FIXED! Yipee Yay
Guys, just an update to let you know that the problem has been fixed.
The culprit was a small humble safety switch fitted to the clutch pedal (much like the brake light switch)
I got a call from TATA Pune from an engineer who advised me to check the switch. I removed the switch connector, shorted it and voila, my 4L is back in action. Now all I need to do is order the switch. Costs all of Rs 42/-!!!!!!
Mods please edit title, to "Now fixed".
Old 22nd March 2008, 17:20   #45
Ignazio's Avatar
Bravo Bravo!!!
Well done mate!
Ciao ciao
cheers:
Ignazio
My Maruti Wagon-R F10D: Beyond 10 Years & 239,000 kms paragsachania Long-Term Ownership Reviews 383 19th January 2018 13:37
Swift DZire 2009 Immobiliser Lock Light Flashing vigsom Technical Stuff 7 10th June 2012 22:52
Spotted : Black Subaru WRX StI. EDIT : Crashed and Now Fixed & Painted Orange varun_patra Super-Cars & Imports in India 321 8th July 2011 22:58
What is the red light flashing on alarm switch on Swift? NVI2112 Technical Stuff 4 19th May 2010 12:39
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
