Old 20th August 2011, 07:17   #151
fazalaliadil's Avatar
Thanked: 624 Times
Default re: Lamda Free Wheeling Front Hubs for Jeeps
Vamsi,
Which dealer did you buy it from? I will try to get it returned or try to get someone who wants to install them on their Jeep. Call me on 98850 71025.
fazalaliadil is offline   Reply With Quote
Old 15th October 2011, 23:28   #152
Thanked: 116 Times
Today I went to Kashmiri Gate to buy Lamda FWH for my Gypsy. I went to Rajsthan Auto Parts - the authorized dealer for Lamda, and he told me Lamda hasn't delivered those to him since last 5 years. I called up Lamda and talked to somebody who understood only Kannada, no Hindi or English :-(
So I drove to Mayapuri and bought a pair of used Aisin hubs from Pali Motors. Though they were very dirty, mechanically looked very good without any apparent damage. He quoted 1800 for them plus 200 for cleaning and fitting.
I bought them, and after thorough cleaning they looked as good as new. But the locking/unlocking could be done only by pliers, not hands. Mechanic told me it'd ease up over time.
But the front propeller shaft is still rotating. I thought that since now the wheel isn't rotating the axle, the shaft too shouldn't rotate. I discussed this with mechanic and Jai of Pali Motors but they too weren't sure. It was already 7:30 PM; and being Karva Chauth, I had already got two howlers from wifey, so left.
Please tell me whether it is ok for the shaft to rotate even when the FWH is in free position? Or they aren't working at all?
Nitin
ntomer is offline   Reply With Quote
Old 16th October 2011, 07:57   #153
headers's Avatar
Thanked: 459 Times
Nitin
Hey Nitn, It appears that the FWH is defective! The front shaft should NOT Rotate when in 2WD mode and FWH in free mode!
Old 16th October 2011, 07:59   #154
Thanked: 116 Times
Yes, I thought so :-(
Is there any way I can find out which one of the two is defective?
\N
Old 16th October 2011, 08:32   #155
Thanked: 624 Times
\N
ntomer,
Lift/ jack the front two wheels enough to freely rotate.
Ensure: Engine off.
Gear position: 4H (Main GB in 4th , Aux in high ).
Hand rotate the wheel one by one to see which one is rotating the shaft.
If both wheels are rotating the shaft, both need replacement.
The rotation is not going to be free but it is enough to make the shaft move. The wheel that makes the shaft move has a faulty hub or fitting.
Make sure your arrows are green to green (free position).
Hope you have done each fitting as per procedure and secured it with the locking clip.
Spray WD40 inbetween the rotating disc on the hub as dirt inbetween it also makes them hard to rotate. Re engage and dis engage the aux. gear and see if it is still hard and needs a pliers.
Hope, finally the Karva Chauth went off well, and may you live very long.
You must explain that a Jeep is a guys 'year long Karva Chauth'.
Makes us skip many meals through the year, we to fast for our Jeeps don't we?.
fazalaliadil is offline   (1) Thanks Reply With Quote
Old 16th October 2011, 08:38   #156
Thanked: 116 Times
Originally Posted by fazalaliadil View Post
ntomer,
Ensure: Engine off.
Thanks.
Just curious - why I need to put it in 4H. I can check it even in neutral-2WD, no? Lift both the wheels on jack and check which one is rotating the shaft.
It did, and that's why I am still alive :-)
Nitin
Old 16th October 2011, 11:32   #157
Thanked: 624 Times
Thanks.
Nitin,
You are right!
Why engage in 4WD mode at all ?????
Guess its my 4WD fixation.
Sorry and Regards,
Old 18th October 2011, 23:22   #158
krishnathanthri's Avatar
Thanked: 41 Times
I bought a pair of lambda hub locks for my gypsy. Took it directly for the factory near hosur
krishnathanthri is offline   Reply With Quote
Old 19th October 2011, 09:40   #159
Blue Thunder's Avatar
Thanked: 330 Times
How much does it cost nowadays ? Were you able to fix and use it without any issues ?
Blue Thunder is offline   Reply With Quote
Old 19th October 2011, 15:59   #160
Thanked: 41 Times
3300rs for gypsy. He was not happy with we discussing the rates online.
Fixing is very easy. Within one hour it was fixed n works very well.
krishnathanthri is offline   (1) Thanks Reply With Quote
Old 19th October 2011, 16:21   #161
Thanked: 116 Times
Were they fixed after removing the cover, or it can be done without it's removal?
\N
Old 2nd January 2012, 21:38   #162
Scion's Avatar
Warn hub locks made for CJ series of Jeeps, would this fit for MM540's?
Scion is offline   Reply With Quote
Old 5th January 2012, 02:03   #163
Thanked: 62 Times
Where in NCR can a get a pair of free wheeling hubs for my MM540.My jeep restoration is in full swing and it needs only the front wheel drive gear lever and a nice pair of lambda free wheeling hubs preferably new ones
regards
Praveen singh
blueblooded is offline   Reply With Quote
Old 5th January 2012, 11:38   #164
mohang_j's Avatar
Thanked: 18 Times
regards
Praveen singh
You can contact their Bangalore office and they will ship the FWH to you.
mohang_j is offline   (1) Thanks Reply With Quote
Old 14th February 2012, 20:40   #165
Originally Posted by ramkya1 View Post
Just talked to Arun the price now with taxes net is 3773/- + courier charges. Mailed him, ordering it soon as I get his reply.
--Ramky
TVS Cochin is quoting Rs 5500 for the free wheel hubs to be put on Thar DI.Is that an inflated amount?
Ronnie Zach is offline   Reply With Quote
DIY: Service & Maintenance of Lambda Free-Wheeling-Hubs dhanushs 4x4 Technical 12 3rd September 2015 19:35
Mitsubishi Pajero - Free wheeling hub malfunction aresq 4x4 Technical 2 25th November 2014 11:21
Painting wheel hubs- How do i do it? akshay_b Modifications & Accessories 34 22nd April 2013 21:53
O2 / Lamda sensor? What do they do ? paras211 Technical Stuff 10 8th March 2007 11:19
Lamda sensor and timer advancer Fl|rty Modifications & Accessories 5 12th September 2006 19:44
