Old 8th August 2008, 11:29   #46
.anshuman's Avatar
Thanked: 9,158 Times
Originally Posted by DKG View Post
You could explore getting self locking hubs like what my Landcruiser GXR had. Whenever I engaged 4wd they locked automatically. Once out of offroad terrain, all I needed to do after shifting into 2wd was stop, reverse a few meters, and move forward. You heard a clicking sound as the front hubs got unlocked. They are worth it as the 2wd with front drive train immobolised is much smoother on tarmac not to mention better fuel economy. That monster of a SUV gave me 6 kms to a litre on a 4.5 litre engine!
The process you have mentioned here is to lock and unlock the center differential to split 50:50 torque on front and rear,The procedure to unlock it is same in safari and scorpio but on endeavour there is a switch near steering to unlock it.
Old 8th August 2008, 11:34   #47
DKG
DKG's Avatar
Thanked: 966 Times
No Anshuman to the best of my knowledge there was no centre diff on the part time 4wd of the Landcruiser GXR. This procedure is to free the hubs once you are done with 4wd use.
Central diff appear on full time 4wds like the VXR series or the Lexus 4wd. Those have a electronic centre diff lock.
DKG is offline   Reply With Quote
Old 8th August 2008, 11:49   #48
Samurai's Avatar
Thanked: 15,755 Times
Originally Posted by maddy42 View Post
@4x4addict pictures please. You promised us of your free wheeling hubs
Here is a close-up look:
Samurai is offline   (2) Thanks Reply With Quote
Old 8th August 2008, 21:19   #49
Thanked: 28 Times
Hi Samurai..... Pls note it looks like 1 of the 6 bolts that hold the free wheel hub is missing .... replace if so....
Chengappa
Note from the Team-BHP Support : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
Timson is offline   Reply With Quote
Old 8th August 2008, 23:49   #50
Samurai's Avatar
Chengappa, I am aware of it, thanks. I am not able to find that exact bolt.
Old 9th August 2008, 05:54   #51
4x4addict's Avatar
Thanked: 2,667 Times
That bold doesn't come with the hub locks. It's the standard one fitted on the jeep so you can buy it from the dealer.
4x4addict is offline   Reply With Quote
Old 9th August 2008, 10:38   #52
Thanked: 28 Times
samurai, mahindra part no A-760,
(Bolt Size-3/8inch, pitch-16, length -1.5inch) or remove 1 bolt take it to a hardware shop and ask for the same steel bolt.
Chengappa
Old 13th September 2008, 21:19   #53
Thanked: 31 Times
After searching high and low at all the India Garage's for the lamda hubs i got fed up and just landed up at the lamda manufacturing unit after electronic city.The price difference is too much.In India Garage i was quoted Rs 4600 for a set of hubs whereas i purchased the same at the unit for Rs 2750 plus taxes.
@4x4addict: I mentioned about you to Mr Arun but he could'nt recall meeting you.
One more good news.While I was talking to Mr Arun he mentioned that Lamda has started making winches and currently has a 5ton hydraulic winch.the cost he said was around 45000 rs.He said the same had been displayed at the recently concluded Palar Challenge in Hyderabad.Apparently they were able to lift a scorpio completely in the air using the winch.He also said that they were in the process of coming out with an electric winch and it should'nt cost more than 60000 rs hopefully.
princezahed is offline   Reply With Quote
Old 14th September 2008, 20:48   #54
shams's Avatar
Originally Posted by princezahed View Post
...the same had been displayed at the recently concluded Palar Challenge in Hyderabad...
Lamda Products were displayed at Jeep Thrills Mitsubishi Monsoon Challenge 2008 in Hyderabad and were received extremely well by 4x4 enthusiasts in the city.
Lamda had showcased
  • Manual Free Wheeling Hubs
  • Automatic Free Wheeling Hubs
  • 5000 Kg Hydraulic Winch
Visitors to their pavilion were impressed by the fact that the high quality indigenous products were priced economically as compared to the imported gear available in the market, making the buy excellent VFM. There is also a feeling of reliability as these products are made for Indian vehicles by people who know them very well and they relate to our conditions.
For Technical queries call Azeez at Lamda on 09343090546; azeez.lamda@gmail.com
shams is offline   Reply With Quote
Old 14th September 2008, 22:23   #55
khan_sultan's Avatar
Thanked: 3,872 Times
Anyone wanting to get a hold of Automatic Free Wheeling Hubs, please be careful. They were installed in 1 Mahindra and we did an OTR this weekend and they just did not work.
Will post a detailed report later after getting the full report from the Mahindra driver.
PS: This is just a heads-up.
khan_sultan is offline   Reply With Quote
Old 14th September 2008, 23:02   #56
Thanked: 31 Times
Lamda had showcased
I was told it was at the Palar Challenge. Anyways hardly makes a difference.Ya even i like the products.and compared to the other stuff in the market its VFM
Old 17th September 2008, 10:36   #57
sreerajunnithan's Avatar
One of them was Sreeni's Armada. He had a tough time. The hubs were slipping repeatedly, hence no traction on front wheels. Finally he replaced it with Manual free wheeling hubs. But then, it was a testing fixment from Lambda.
Read This for more info http://www.team-bhp.com/forum/4x4-of...13th-sept.html
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 18th September 2008, 02:46   #58
MM440's Avatar
Thanked: 37 Times
The jeep thrills Palar challenge is not held at hyderabad but on the dried river bank of Palar closer to Chennai.
cheers
Jammy
Note from Support: Please quote only what is required and not the whole post. Thanks
MM440 is offline   (1) Thanks Reply With Quote
Old 19th September 2008, 17:18   #59
Thanked: 31 Times
cheers
Jammy
[/b]
my bad.i dint pay attention.and it dint strike me aso that palar is near chennai and now hyderabad.
Old 31st December 2008, 03:46   #60
Scion's Avatar
Default Free wheeling hubs
Hey Guys,
Hopefully I'm not hijacking this thread...had questions on manual free wheeling hubs, how hard is the manual effort of engaging and disengaging the wheels from drive shaft? Can we do this real quick? What are the chances of breakage?
Scion is offline   Reply With Quote
Painting wheel hubs- How do i do it? akshay_b Modifications & Accessories 36 10th April 2018 15:04
DIY: Service & Maintenance of Lambda Free-Wheeling-Hubs dhanushs 4x4 Technical 12 3rd September 2015 19:35
Mitsubishi Pajero - Free wheeling hub malfunction aresq 4x4 Technical 2 25th November 2014 11:21
O2 / Lamda sensor? What do they do ? paras211 Technical Stuff 10 8th March 2007 11:19
Lamda sensor and timer advancer Fl|rty Modifications & Accessories 5 12th September 2006 19:44
