Old 31st December 2008, 10:05   #61
Samurai's Avatar
Thanked: 14,539 Times
Generally not much tougher than opening a mineral water bottle. Sometimes it can get tight if you have driven in 4WD on hard tarmac causing some transmission windup. Driving in 4WD on hard tramac puts pressure on the hub locks, and can eventually break it.
Old 27th February 2009, 11:53   #62
A-jay's Avatar
where can I get a free wheeling hub for a gypsy 410W
A-jay is offline   Reply With Quote
Old 27th February 2009, 14:08   #63
nofear9009's Avatar
Hello everyone,
The gears or the pattern on the shaft or rod on to which the hub locks fit are not the same for the mahindra and gypsy though they look alike from outside. i.e the gypsy hub locks would not fit on the MM540.
nofear9009 is offline   Reply With Quote
Old 27th February 2009, 16:56   #64
sreerajunnithan's Avatar
Lambda Bangalore. You can search in the forums for address and phone number
Originally Posted by nofear9009 View Post
Hello everyone,
Hub Locks are different for Gypsy and Jeep. You can source the hublocks for Gypsy from above mentioned company.
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 27th February 2009, 17:08   #65
DirtyDan's Avatar
Thanked: 747 Times
Some people do not think Lambda hubs are particularly good quality. Frankly, I do not know. Any opinions? Any alternatives?
Old 27th February 2009, 17:28   #66
gotzuk's Avatar
Thanked: 67 Times
A-jay,
Gypsy's came with Japanese made Aisin free wheeling hubs.
Try and source one from an old Gypsy or local workshops.
They are much better built than the Lambda hubs.
Altough the Aisin hubs are pretty much bulletproof, retain the stock axle flanges in the car as an added insurance in case the feewheeling hubs give up.
gotzuk is offline   Reply With Quote
Old 27th February 2009, 21:08   #67
Alfa_Kilo's Avatar
They aren't. The MM550XD I am rebuilding has manual locking hubs, and I did not find the locking mechanism very reassuring. It is prone to wear and quite sensitine to dirt.
If one manages to get dirt into them, the hubs tend to stick in the open position. Alway carry an allen key to open the cover just in case.
Alfa_Kilo is offline   Reply With Quote
Old 27th February 2009, 22:01   #68
harjeev's Avatar
Thanked: 256 Times
Originally Posted by gotzuk View Post
A-jay,
Hey Vaibhav
Long time no see, Did you go to the desert storm rally. How did it go??
BTW is it possible to install LSD's in the Gypsy?? If yes is it an easy or difficult modification??
harjeev is offline   Reply With Quote
Old 27th February 2009, 22:08   #69
4x4addict's Avatar
Thanked: 2,513 Times
DD, I am happy with mine and it has been a standard on all army MM540s and the earlier gypsys. A manual hub lock is a fairly basic mechanism. No fancy engineering involved. If you had a lathe you could build one your self. The only concern if anything at all would be the quality of the metal used which might cause the lock to break/snap. The mechanism itself is very simple..
Besides they are cheap and the only option available in India unless you want to import a Warn one which can fit the Mahindras.
4x4addict is offline   Reply With Quote
Old 28th February 2009, 23:02   #70
Thanked: 21 Times
Do army MM550's come with free wheeling front hubs ?
bigman is offline   Reply With Quote
Old 28th February 2009, 23:41   #71
harjeev's Avatar
Thanked: 256 Times
Yeah I saw FWH's in 1999, 2000 models. But they have been missing post 2001 models
dont know why???
Your jeep is a 2000 model, I think, so they should have FWH's
Old 1st March 2009, 16:23   #72
Thanked: 21 Times
dont know why???
Thanks.
I too thought it was a 2000 model but am now told it is 2001 model.
So I guess I can fit these Lambda FWH's or get some off a 1999/2000 army MM550 from Mayapuri.
Is it a simple 10 minute fitting job ?
Old 1st March 2009, 16:31   #73
4x4addict's Avatar
It is a bolt on job. Will take about 10 min each side.
Old 1st March 2009, 16:33   #74
Thanked: 21 Times
Thanks, is it RS2,750 for one or for the pair ?
Old 1st March 2009, 17:06   #75
4x4addict's Avatar
For the pair, (both sides).
DIY: Service & Maintenance of Lambda Free-Wheeling-Hubs dhanushs 4x4 Technical 12 3rd September 2015 19:35
Mitsubishi Pajero - Free wheeling hub malfunction aresq 4x4 Technical 2 25th November 2014 11:21
Painting wheel hubs- How do i do it? akshay_b Modifications & Accessories 34 22nd April 2013 21:53
O2 / Lamda sensor? What do they do ? paras211 Technical Stuff 10 8th March 2007 11:19
Lamda sensor and timer advancer Fl|rty Modifications & Accessories 5 12th September 2006 19:44
