Old 19th December 2009, 22:01   #106
4x4addict's Avatar
Thanked: 2,668 Times
Samurai:
When you remove them and put them back, I think you need to set the locked/unlocked position correctly. If I recall this was something that I noticed when mine where being installed.
4x4addict is offline   Reply With Quote
Old 20th December 2009, 07:49   #107
Samurai's Avatar
Thanked: 15,770 Times
Now that is it is working fine, I hope I have nothing to worry about. Actually, I didn't unlock the hubs after that. Just left it in locked position.
Old 3rd January 2010, 09:02   #108
svsantosh's Avatar
Thanked: 1,444 Times
My CJ went for a small mechanical checkup yesterday. Since I live in a 2WD district, the mechanic had a tough time putting back the FWH's.
After a good 30mins he figured out how to fix them correctly... Anyways, I took the stock M&M hubs in case he decided to drop the idea of experimenting. It was not needed...
svsantosh is offline   Reply With Quote
Old 16th January 2010, 20:00   #109
Thanked: 28 Times
The Hub has to be in unlocked position before removing the cap and the fit again in the unlocked position.
Timson is offline   Reply With Quote
Old 19th March 2010, 10:47   #110
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
I got Lamda FWHs installed yesterday! The change in drive is very noticeable. Better pickup and cruising!
Questions:
How do you protect the Hubs? The old classic which had the hubs used to have a screw on type cap on it. Any such options or mods?
What if one hub is locked and one isn't and i drive with it (in 2WD)? Children in my building are notorious and may fiddle while playing hide n seek.
Tejas@perioimpl is offline   Reply With Quote
Old 19th March 2010, 21:03   #111
4x4addict's Avatar
Having one locked and one open will be equivalent of having both unlocked as power will find the path of least resistance which is the open one. I suggest rubbing chilli power on the hubs so when the kids rub their eyes after playing with your FWHubs it will teach them a lesson not to do it again.
4x4addict is offline   (1) Thanks Reply With Quote
Old 20th March 2010, 00:12   #112
star_aqua's Avatar
Thanked: 89 Times
It can have impact on spider gears when driven at high speeds. so don't drive with one hub locked and one open. Also the hub which is not locked can wear out soon as the relative free wheeling speed will double up as axle rotates in opposite direction to the wheel.
star_aqua is offline   (1) Thanks Reply With Quote
Old 20th March 2010, 00:22   #113
V-16's Avatar
Thanked: 862 Times
Originally Posted by U.B.Singh View Post
about engaging the locks atleast for a kilometer, once every month?
How about focusing on this very vital bottomline.
With you always............... UBS
Sir, can WD40 do the trick of easing stiff locks in emergencies? I usually have it in all my classics for emergencies and have found the little cans to be of tremendous use.
Doc, i didnt notice any instruction sticker in the box? I guess Prakashbhai should be asked why the important instruction sticker is missing?
How easy/difficult was it to fix?
I plan to run my Jeep for a few days without installing the Lambdas then will swap, just to know the difference. Will probably get it done at Milestone or under Behrambhai's supervision elsewhere.
V-16 is offline   Reply With Quote
Old 20th March 2010, 00:39   #114
star_aqua's Avatar
Thanked: 89 Times
Its very easy. Mr.DB is not required for this. Infact its a DIY job if you know how to remove a circlip and put it back using nose player. Even a road side mechanic will fix it. You just have to remind him to use the circlip.
and to feel the difference you can just lock the hubs and it is same as if you have not installed the FWH.
Old 13th April 2010, 19:24   #115
sreejeshmp's Avatar
Thanked: 576 Times
Please help me to install the free wheeling hub
I got the Lamda free wheeling hub. But my mechanic don't know how to fit that. So I have to do it myself. I am not able to get a clear picture of the installation from the Fitting Instructions from Lamda.
in the Instructions 4th point says "INSERT CIRCLIP on axle shaft" Do we have to buy new sirclip for that or it will be there inside the OEM front hub ?? Please help me
What are those align Marks (instruction no 7)? is they are inside the cover assembly ?
Sreejesh M.P
sreejeshmp is offline   Reply With Quote
Old 13th April 2010, 20:09   #116
DirtyDan's Avatar
Thanked: 776 Times
Originally Posted by sreejeshmp View Post
Sreejesh M.P
Make sure when you put them on that they are in the "FREE" position. I do not remember where the Circlip came from but it is dirt cheap, don't sweat it.
My mechanic had never installed them but he got it right on the second try. He had to align one of them again. So, it was trial and error and the 2nd trial did the trick. It is not hard for a mechanic. Get somebody with some guts to help you. The circlip needs to go on with a pair of thin-nosed, needle-nosed pliers as you have to compress this C-shaped steel clip around the axle at the hub. This is the hard part for people like me with no mechanical ability whatsoever.
If they are installed correctly you will be able to turn the selector switch from "free" to "lock" with little difficulty.
If you want to test your install, jack up both front wheels at the same time and put both hubs on "free". You should be able to rotate the front wheels by hand while observing that each axle does not rotate. Put the selector on "lock" and rotate both wheels. The axles should rotate.
DirtyDan is offline   (1) Thanks Reply With Quote
Old 5th May 2010, 17:01   #117
karizma9292's Avatar
Thanked: 210 Times
Default Which is better for gypsy : lambda free wheeling hubs or AISIN free wheeling hubs.
Hey guys , im planning to put free wheeling hubs for my gypsy . im confused whether to go for Lambda or AISIN free wheeling hubs.
karizma9292 is offline   Reply With Quote
Old 5th May 2010, 19:05   #118
Jaggu's Avatar
Thanked: 8,686 Times
AISIN if you get one in good condition or new.
Old 5th May 2010, 22:41   #119
Desmosedici's Avatar
Thanked: 410 Times
Mumbai Price for AISIN new one is 4600/-
Desmosedici is offline   Reply With Quote
Old 6th May 2010, 09:47   #120
Thanked: 210 Times
hmmm ok thanks jaggu sir. I will go for AISIN itself
Last edited by GTO : 21st May 2010 at 20:05. Reason: Please avoid typing with excessive dots..........like...........this..........Thanks
Painting wheel hubs- How do i do it? akshay_b Modifications & Accessories 36 10th April 2018 15:04
DIY: Service & Maintenance of Lambda Free-Wheeling-Hubs dhanushs 4x4 Technical 12 3rd September 2015 19:35
Mitsubishi Pajero - Free wheeling hub malfunction aresq 4x4 Technical 2 25th November 2014 11:21
O2 / Lamda sensor? What do they do ? paras211 Technical Stuff 10 8th March 2007 11:19
Lamda sensor and timer advancer Fl|rty Modifications & Accessories 5 12th September 2006 19:44
