Old 25th April 2008, 02:16   #31
1100D's Avatar
Thanked: 2,512 Times
What if I want to encounter a steep hill climb under full load, I would need the High ratio but would like to have the hublocks open to prevent stressing out the drivetrain.
With Autohublock can we manually disengage the hub locks?
1100D is offline   Reply With Quote
Old 25th April 2008, 07:43   #32
Thanked: 253 Times
You probably mean you'd need the Low Ratio, but without being in 4WD mode.
This would not be possible on the auto hublock vehicles.
anupmathur is online now   Reply With Quote
Old 25th April 2008, 09:43   #33
Alfa_Kilo's Avatar
With a vehicle with the power and torque similar to the scorpio, you will not need low ratio for climbing a steep paved road. One is likely to run out of traction before power, so 4WD H/L may be engaged as required.
Alfa_Kilo is offline   Reply With Quote
Old 25th April 2008, 19:27   #34
DirtyDan's Avatar
Thanked: 776 Times
Go ahead and stress the h*ll out of it. That is what it was made for. Even if you break something you can always fix it. ANd, you probably won't break it anyway.
Old 25th April 2008, 19:55   #35
Thanked: 253 Times
Oh DirtyDan, you don't know how right you are!
Many years ago, (on the same premise that I'll have it fixed when it breaks), I used my Gypsy in 4WD Low for hundreds of kms on mountain roads, lot of it on dry and hard pavement.
I never managed to break anything!
Old 26th April 2008, 17:00   #36
Thanked: 660 Times
I guess 4x4 on scorpio is made by Borgwarner. correct me if i am wrong.
Old 28th April 2008, 13:22   #37
shankar.balan's Avatar
Thanked: 5,350 Times
correct
it is a shift on the fly electrically operated borg warner unit
this is what the dealer says when asked and what I remember reading some time back when the scorp first came out
Last edited by shankar.balan : 28th April 2008 at 13:22. Reason: add electrically operated
Old 28th April 2008, 15:00   #38
Thanked: 253 Times
correct
And the same was used in the Armada Grand before the Scorpio.
Also being used on the Safari for many years.
Old 28th April 2008, 15:09   #39
yes as also the Bolero 4wd version GLX which first came out and of course it continues to do duty in the newer Bolero 4wds- this was really the first step up for both tata and mahindra, from the old type 4wd stick shift selectors with low and high etc.
On the Safari it worked very well - I ve driven the old 1948 cc Turbo Safari with 4wd many times.
Old 28th April 2008, 19:31   #40
4x4addict's Avatar
Thanked: 2,669 Times
When it comes to four-wheel drive systems, I still prefer the good old lever that is still u used in many of the modern 4x4s. I don't want any electrical motor/contacts coming in between me and the obstacle. Besides, I don't know how well the electical components in the Safari/Scorpio are water and dustproofed in the transfer case.
4x4addict is offline   Reply With Quote
Old 8th May 2008, 16:25   #41
there is nothing quite like clicking your vehicle manually into 4WD, I agree.
Theres a certain psychological satisfaction in simply hearing those clicks and knowing that the ratchets are firmly slotted into each other - now show me the MUD!
Old 8th May 2008, 17:03   #42
Thanked: 253 Times
I also agree that the lever thingy is more confidence-inspiring, but I'm also enjoying the selector 'switch' immensely! Having done large distances on bad terrain and many water crossings, it is working well so far.
The disconcerting trait about these electric shifts is that they do not engage instantly. A few seconds elapse before 4WD gets engaged and you hear the reassuring clicks; same for Low Ratio.
Old 8th May 2008, 17:15   #43
.anshuman's Avatar
Thanked: 9,160 Times
Testdrove the Endeavour thunder+ this week,i prefer manual selector to the electronic switch.Endeavour has a unlocking button on the console so the procedure of reversing is not required for unlocking hubs.
Old 8th May 2008, 17:22   #44
Thanked: 253 Times
Now that's a useful feature!
However, the Endy is way out of budget for me.
Old 8th May 2008, 18:13   #45
gd1418's Avatar
Thanked: 656 Times
And so for the most of others as well..
Type of Box for Alpine Type R Woofer Akshay1234 In-Car Entertainment 15 10th August 2011 15:24
Swift Type 1 and Type 2 Vajo The Indian Car Scene 19 15th January 2010 18:18
Difference between Type 1 and Type 2 Honda 1.5 gameonrwind The Indian Car Scene 7 8th August 2008 10:54
Modifiction of Type I M800 to Type II sathyaprakash Modifications & Accessories 17 3rd July 2007 21:56
esteem type 2 instrumentation in type 1 rdkarthik Modifications & Accessories 3 3rd February 2006 14:43
