Old 22nd April 2008, 08:10   #1
Thanked: 253 Times
Default What type of 4x4 in Scorpio?
I wonder is the Scorpio 4x4 available easily?
If going for 4x2, the Innova is a better bet because its more reliable than both safari and Scorpio.
If going for 4x4, then safari makes more sense as it comes with a LSD, which can be a boon in tricky situations
The 4X4 is made to order - about 2 months waiting period for delivery.
And AFAIK, LSD is standard on Scorpio too.
anupmathur is online now   Reply With Quote
Old 22nd April 2008, 08:44   #2
tsk1979's Avatar
Thanked: 16,422 Times
I doubt, coz I once saw a video of a scorpio 4x4 with one wheel spinning. You have a scorpio 4x4 right?
Could you check in the manual. It will be clearly specified.
Old 22nd April 2008, 09:32   #3
.anshuman's Avatar
Thanked: 9,160 Times
ive read the manual it states it has automatic locking hubs.
Old 22nd April 2008, 10:19   #4
tsk1979's Avatar
Hmm, any more details about the 4x4 system of scorpio Anshuman?
What exactly is automatically locking hub?
Old 22nd April 2008, 11:40   #5
Samurai's Avatar
Thanked: 15,777 Times
Obvious explanation would be it engages and disengages as you switch in and out of 4WD. You don't have to get down in muck to do that manually. But you still have to move backward or forward I suppose.
Old 22nd April 2008, 11:51   #6
DirtyDan's Avatar
Thanked: 776 Times
I have owned several vehicles with auto locking hubs that do not have any manual option. These are common in N.America on small 4x4 pickup trucks. Works good. No Back and Forward necessary.
Old 22nd April 2008, 11:56   #7
ex670c's Avatar
Thanked: 1,821 Times
Default SCORPIO 4x4
Front Axle - IFS Torsion bar Full- Floating with Auto Locking Hubs (M35 Diff)
Rear Axle - Rigid Live Axle on Coil Springs - Semi-Floating (NO LSD)
Gearbox
- NGT530
Transfer Case - Part-Time Borg-Warner 2 Speed electronically actuated.
Old 22nd April 2008, 12:08   #8
tsk1979's Avatar
Ok, this means that the front two wheels will always spin together.
So that means unless you have 3 wheels out of action, the SUV will move ahead, right?
Old 22nd April 2008, 13:28   #9
Thanked: 253 Times
Sounds logical.
Strangely, M&M do not mention the kind of diffs used - neither in the Manual, nor on the website.
For engaging 4WD, there is no need to stop - it is possible on the fly. And there is no need to depress the clutch either, for engaging/disengaging 4WD HIGH.
For 4WD LOW, vehicle should be brought to a standstill AND the clutch pedal should be depressed.
To dis-engage the 'automatic' front hubs, the car needs to be reversed for about one metre distance.
Old 22nd April 2008, 13:34   #10
.anshuman's Avatar
Sounds logical.
Ill confirm it from the manual,i am not sure but its dana44 or something.
Old 22nd April 2008, 14:03   #11
Thanked: 253 Times
Seeing a wheel spinning on a 4WD does not convey anything about the circumstances - was the wheel on the other side (which you could not see) also spinning? Was the vehicle in 4WD mode at that point?
The Manual does not say anything about the differentials at all! Nor does the website.
Old 22nd April 2008, 14:10   #12
tsk1979's Avatar
It was a youtube video with front wheel spinning. It was an older model maybe?
I wonder why companies in India are so tight lipped about what kind of 4x4 sits in their cars.
Arka has given the exact information.
Was Scorpio 4x4 always with this kind of config?
Old 22nd April 2008, 15:37   #13
.anshuman's Avatar
even i have seen a similar video on youtube of white scorpio with all the wheels spinning.
Old 22nd April 2008, 16:20   #14
Thanked: 253 Times
Tells us little about the kind of diffs!
I'm lost.
Where and what?
Old 22nd April 2008, 16:22   #15
tsk1979's Avatar
Actually the video has a white scorpio and you can just see the right side.
The front wheel is spinning, and you can't see the other side.
Type of Box for Alpine Type R Woofer Akshay1234 In-Car Entertainment 15 10th August 2011 15:24
Swift Type 1 and Type 2 Vajo The Indian Car Scene 19 15th January 2010 18:18
Difference between Type 1 and Type 2 Honda 1.5 gameonrwind The Indian Car Scene 7 8th August 2008 10:54
Modifiction of Type I M800 to Type II sathyaprakash Modifications & Accessories 17 3rd July 2007 21:56
esteem type 2 instrumentation in type 1 rdkarthik Modifications & Accessories 3 3rd February 2006 14:43
