Old 27th November 2009, 10:20   #91
Ramsagar's Avatar
Thanked: 46 Times
Infractions: 0/1 (4)
I've seen this thread now.
I was not even dreaming of having NOS in may car, but your jeep made me to think.
It seems to be you had spent lot money and time on the stuff. Great.
Ramsagar is offline   Reply With Quote
Old 9th December 2009, 19:48   #92
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Dear RedMM340- can you post some pictures showing the clearances between the leaf spring and the oil sump, also clearance between the front propeller shaft and the engine block gusset towards the RHS.
SPIKE ARRESTOR is offline   Reply With Quote
Old 13th February 2010, 12:55   #93
Default Cost of doing this
Guys I have a CJ3B willys in very bad condition, does any one have an idea how much will it cost to turn it into some thing like this, and is it possible to do it on willys, or am I better off in buying a mahindra.
4x4forever is offline   Reply With Quote
Old 25th December 2014, 04:59   #94
Endeavour333's Avatar
Thanked: 358 Times
Default Re: Highly Modified MM340 - Scorpio Powered Beast
Originally Posted by RedMM340 View Post
Threw in a set of Rancho 9000's, a K&N filter and proceeded to have a lot fun.
Cheers,
Gaurav
Hi Gaurav could you please let me know where you got your Rancho 9000s? Im planning to buy the same as well. Thanks a bunch.
Endeavour333 is offline   Reply With Quote
Old 25th December 2014, 06:28   #95
sudev's Avatar
Thanked: 2,433 Times
4x4forever... define bad. Engine, transmission, body?
sudev is offline   Reply With Quote
Old 25th December 2014, 12:58   #96
darxide's Avatar
Thanked: 27 Times
@ redmm340 hi, i have a 2008 bolero lx 4x4 with the xd3 engine and ba10 gear box. it's a used car that has 1.11 lac plus kms. on it. the engine is pretty much dead and sorely lacks power right from the day i bought it. as in the car lacks pick up and power and wont go up steep slopes unless its really revved up. my mechanics have checked and have seen that the engine has mild to medium blow-by (india - back pressure) , ie most probably worn piston rings and cylinder liners etc.. the estimated cost of an overhaul i've been told will be in the region of 30-50 k. i would like to use this bolero as my daily drive car and therefore am im not too keen on running an overhauled engine since ive had less than satisfactory performance results from rebuilt engines in the past.
i have heard from various jeep enthusiasts and owners that the scorpio sz2600 chain drive engine is a match for the ba10 gear box and fitting a used one would not require too many mods to the bolero. im looking out for the right information and tips on how to go about this engine swap if possible. looking forward to your advice and help thanks - nikhil
Sorry, but there is no drawing for the adapter plate. But if you are really interested, I could find out what it would cost to have the same machine shop make another one.
This multi quote feature is nice. Glad I figured it out after 160+ posts!
Thanks Abhijat. You know, most Jeep ethusiasts in the U.S. don't really consider the Patriot a real Jeep. The problem is that it has too much Chrysler mini van DNA. If you visit the U.S., try renting a Wrangler. A good number of car rental companies rent it.
I put some close ups of the front and rear anti sway bars on an earlier post. Please look for them and let me know if you want more detail.
Thanks, I will be putting put a post on my U.S. spec. Wrangler soon. Look for it in the International section of T-BHP.
NOS is for hill climbs, mud slogging, and other horsepower intensive tasks. Just remember, you can never have enough horsepower.
I have no idea how many man hours have gone into this project. But it has been a lot!
Highly Modified MM340 - Scorpio Powered Beast-10876580_909770462366901_1198157672_o.jpg
Highly Modified MM340 - Scorpio Powered Beast-1491369_286231088233344_3840776083110663100_o-1.jpg
Highly Modified MM340 - Scorpio Powered Beast-10834231_900896856587595_351502013_o.jpg
Last edited by Rudra Sen : 25th December 2014 at 15:26. Reason: Back to back posts merged
darxide is offline   Reply With Quote
Old 25th December 2014, 16:37   #97
nanju's Avatar
Thanked: 152 Times
Crazy Build brother.. hats of to you.. Playing with a diesel engine is no joke and on top of it all you have managed to plonk in a dry nito.. Interested to know more about the boost controller.. can I have you number via PM??
nanju is offline   Reply With Quote
Old 26th December 2014, 16:29   #98
sammyaulakh's Avatar
Thanked: 21 Times
RedMM340, it's a fantastic job you have done. Can you please let me know from where did you get the adaptor plate made and how much did it cost.Also can a scorpio 2.6 engine be mated to a cj 3 speed gearbox. Thanks.
sammyaulakh is offline   Reply With Quote
Old 26th December 2014, 17:28   #99
Thanked: 381 Times
O.k. folks, here is write up on my MM340.
1995 original jeep
2.6 turbo Scorpio motor
Cheers,
Gaurav
Just came across this amazing thread , I was checking out the pictures , one noob question from my side . Why do I see 4 gear levers. I have seen a maximum of 2 gear levers on all 4wd jeeps.
girimajiananth is offline   Reply With Quote
Old 26th December 2014, 18:35   #100
Thanked: 44 Times
Redmm340 replied to the same question earlier.
"Regarding the gear levers, you are asking a good question and I am glad you spotted that detail. The 4x4 on this transfer box has 2 levers. One is the 4x4 on and off. The other is 2H, 4H, 4L. The extra lever is actually a Warn overdrive gearbox that gives a 1:1 ratio on the low setting and a 25% high ration on the high setting. This will give more relaxed engine rpm at highway speed and a higher top speed. I guess I forgot to put this on the list of modifications."
zaveed is offline   (1) Thanks Reply With Quote
Xtreme Power does a Scorpio Powered MM550 xtreme power 4x4 Vehicles 80 2nd September 2013 12:55
MM340 Upgrades autopsyche 4x4 Technical 25 6th May 2009 05:44
Powered ORVM's for the older scorpio's jags_bhandary Modifications & Accessories 2 20th March 2009 20:47
Chennai to vizag (1928 kms) on my new Beast! (EDIT: Beast=Fiesta 1.6 zxi Petrol) gopal.putrevu Travelogues 19 18th April 2008 13:35
