4x4 Technical Engines, Diff-locks, SPoA, Techniques and more
LinkBack Thread Tools
Old 10th June 2008, 21:25   #16 (permalink)
DKG
DKG's Avatar
PLEASE USE ONLY RAMSEY WINCH RATED @ MINIMUM 8000 LBS. Believe me, I know. We have pulled around 25 vehicles up a 15 degree or so of slope at > 30 ft long range out of knee deep mud in pouring rain in a span of about 6 hours by using one winch only (with additional chains).
Thanks for the feedback. Do we have dealers for the brand in India? Any idea as to how much the 8000 lb unit costs?
__________________
Help Save AP's Forests and Wildlife
DKG is offline   Reply With Quote
Old 10th June 2008, 23:01   #17 (permalink)
iceman91's Avatar
Prices of that in India if available through parallel imports
__________________
Hypocrisy.. sadly the way of Life
iceman91 is offline   Reply With Quote
Old 11th June 2008, 07:47   #18 (permalink)
pdev29's Avatar
we bought one warn 8000 lbs for some 65k. if anyone wanna buy i can get the exact information on it.
__________________
Devang.....
***CaLl oF nAtUrE***
Gypsy 4*4
pdev29 is online now   Reply With Quote
Old 11th June 2008, 08:29   #19 (permalink)
iceman91's Avatar
65k is a good price for a warn in India, is that afetr customs, transportation etc. etc.?
__________________
Old 11th June 2008, 09:11   #20 (permalink)
DKG
DKG's Avatar
Would really appreciate any details you can share. Kindly mention the model you picked up
__________________
Old 11th June 2008, 10:42   #21 (permalink)
pdev29's Avatar
it was sourced from banglore costed around 65k, its 30mts long. dont know the model number will have to get it from my friend.
__________________
Devang.....
Gypsy 4*4
Old 11th June 2008, 10:54   #22 (permalink)
Was just curious about the security of the winch? Do you weld it on to the Jeep chassis? In a city like Bombay, there is almost a 100% chance of it getting flicked.
Considering that good winches are so expensive, how do we prevent theft?
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 11th June 2008, 11:06   #23 (permalink)
iceman91's Avatar
As far as I know GTO you can weld if you want to but other wise they come with standard bolts.
i do know friends in OZ who used one time bolts, they have to be cut if you want to remove the winch. Sort of like rivets
__________________
Old 11th June 2008, 11:30   #24 (permalink)
pdev29's Avatar
winch is bolted on chassis, i have not seen anyone welding it so far but its tough to remove it.
__________________
Devang.....
Gypsy 4*4
Old 11th June 2008, 11:48   #25 (permalink)
ex670c's Avatar
Default Winch Criteria
Hi Guys,
The first Criteria is the rated pull of the winch i.e 8000lbs, 12000lbs etc.
1) The rated pull is on the first layer of the drum (total 4 layer)e.g on the 4th layer a 12000lbs winch will have a pull of 8500lbs.
2) Calculate the max rated pull for a vehicle
a) MG410/413--1000kgsX2.2 =2200lbsX2.5/3.5(winching factor)=5500/7700lbs
b) CJ3B/CJ340 1100kgsX2.2=2420lbsX2.5/3.5(winching factor)=6050/8470lbs
c)
MM540/MM550--1400kgsX2.2=3080lbsX2.5/3.5(winching factor)=7700/10780lbs
3) The Winching Factor
multiplies the pull required in OTR conditions.
muddy inclines and vehicle stuck upto the axles.
From the above information you can decide (keeping #1 rated pull in mind)
what capacity winch can pull what vehicle.
Arka
__________________
JEEPers speak - Engage Mind, before opening Mouth!!!!!
ex670c is online now   Reply With Quote
Old 11th June 2008, 12:09   #26 (permalink)
ex670c's Avatar
Default My Experience with Chinese 12000lbs Winch
Hi Guys,
1) 12000lbs
2) 6.6Hp motor
I have deliberately abused my winch to see it durabilty and was quite pleased.
1) exposed it to seawater/brackish water and rains.
2) smashed it against a truck
The Winch Motor was clogged with salt and other deposits which I have cleaned and re-lubricated. The motor is quite well built and the winch is very uncomplicated.
Arka
Pics#1 - My MM540XD at TPC2007
Pics#2-4 - Patrick's CJ3B (with the same winch) at Kelambakkam.
__________________
Old 11th June 2008, 12:40   #27 (permalink)
Adventure One in Bangalore behind India Garage (ST Mark's Road) has a whole bunch of Warn winches, driving lights, Old Man Emu suspension setups, ARB Bull bars (with built in winch points), extraction kits etc for off roading. The rates seem high but if you take the customs and freight etc and the fact that all these are premium products it's not too bad.
Rgds
indianrunner is offline   Reply With Quote
Old 11th June 2008, 12:53   #28 (permalink)
RedMM340's Avatar
Originally Posted by DKG View Post
Pls excuse my going but interestingly I too am researching winches and am presently zeroed in to a Warn 8274-50 8000 lb winch. Sadly the India dealer in Bangalore is a ripoff quoting 1.1 lacs. Its available for 1100 USD. Even with shipping, taxes, and VAT it shouldn't cost that much. Will get someone to buy it there and send it. Would you know if the Warn winches are available in Bombay? I guess Ramsey should be of similar quality?
The Warn 8274-50 is one of the best winches made, with a very fast pull speed. It is very popular with hard core off roaders that need to do frequent pulls. It is also one of the most expensive winches on the market, and unless you really can use and need that type of performance, there are much lower cost alternatives that will work very well.
For most Jeeps, an 8k winch is totally sufficient. A Gypsy can do with a 6k winch. There is a tendancy to go for a higher pull rating for safety factor, but often this is just overkill and the net effect is that you are just carrying extra weight on you front bumper. Keep in mind that the motor for a 6k winch is typically the same as a 9.5k winch, and the only difference is the gearing. This means that if you get a Warn 6k winch, it will have a faster pull speed than the 9.5k. 12k winches are even slower.
Warn, and Ramsey are probably the 2 best winches on the market today. There is also Tmax from Australia. Milemarker is lower cost than Warn/Ramsey and has decent quality, which gives you the best value for money. You can get a milemarker PE8000 from costco.com for $340. This unit will work for 99.9% of winch requirements with a typical Jeep, etc.
I have a Ramsey 9500 on my CJ340, and have used it some really difficult situations, and it has worked great. I bought this winch in the U.S., disassembled it into the drum, motor, gearbox, electricals, and brought the pieces over in different suitcases. Then proceeded to reassemble in Delhi. Worked great, and paid no duty.
Most winches have a standard 10x4.5 bolt pattern, and all manufacturers sell standard winch mounting plates. This is highly recommended for safety. I tack welded the mounting plate to my vehicle frame for added strength and security from theft. I then put a security cable lock around the winch drum and front bumper.
RedMM340 is offline   Reply With Quote
Old 11th June 2008, 15:41   #29 (permalink)
DKG
DKG's Avatar
Perhaps we could use security nuts like those used for expensive alloy wheels?
Originally Posted by ex670c View Post
Hi Guys,
1) The rated pull...
Thanks Arka, was hoping someone would throw more light on the subject. I gather with each wind on the drum the rated load strength decreases by 10%
The winching factor some winch sites claim as 1.5, I noticed you mentioned 2.5 or 3.5.
Nice to know the chinese brand you bought has fared well.
Originally Posted by indianrunner View Post
I had a colleague check it out today. I believe the 8274-50 is Rs 107800 lowest. He's working on a margin of atleast 30k which is ridiculous. You don't make that kind of money selling Honda City's!
Despite the higher cost I'd be more comfortable with something that has a worldwide reputation for reliability so a Warn it will be for me. I think like you I'll pick it up in the US and have it sent down someway.
The idea of the cable lock is good for securing the winch
One last point on winch installation is apparently it should be ideally anchored to the chassis (in line with it too to prevent the frame from bending) So unless the bumper is heavyduty like the old Jeeps it might be dicey to fix it onto a flimsy metal bumper as it might just rip the whole bumper off.
Also the electicals is something that is very critical. The 8000lb winches require anywhere from 450+ amp of juice to crank. You need 2 guage wire and preferably earthed to the engine directly. Also it is recommended to run a parallel setup with a dual battery rated for atleast 600 amps. You would need to upgrade the alternater to handle charging two batteries.
__________________
Old 12th June 2008, 09:44   #30 (permalink)
VJ_MAVRICK's Avatar
Deepak,
One of my friend Kishan had got his winch from Bangkok. I aint sure about the dealers and prices here. However, the info for the Bangkok dealer is as below
VVP 4X4 Center co Ltd . You can send a mail to (sales@vvp4x4.com)
According to my friend Kishan, you can get the winch as a personal luggage as he has done it and could save on logistics (for transfer).
__________________
SUCCESS is not FINAL and FAILURE is not FATAL,its the COURAGE to CONTINUE that COUNTS!
VJ_MAVRICK is offline   Reply With Quote
Thread Tools
A Winch Test Samurai 4x4 Technical 30 19th December 2009 10:20
Winch- Is this doable? beejay 4x4 Technical 26 16th September 2009 20:54
Top Gear 2006 Survey : Fiat zooms into top 10, Honda, Skoda top list. amit The International Automotive Scene 10 8th March 2007 11:31
CRAP? The new JD Quality Study - 9 American car makers in top 15 GTO The International Automotive Scene 10 12th August 2006 09:21
Top Gear Tests, Rallies, High quality motorcycle videos. highwayblaze Shifting gears 5 11th July 2005 08:56
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653
