| 4x4 Technical Engines, Diff-locks, SPoA, Techniques and more |
| | Thread Tools |
| | #16 (permalink) |
| Distinguished - BHPian ![]() | Great thread Samurai. I have just been inducted to the Jeep owners club. The Jeep is a vehicle that is as alien to me, as it is to you but getting hold of one ia my childhood dream come true. Your thread here will help people like me to get to know their vehicles better without asking too many basic questions. Im providing a link to the thread I started about my Jeep. Ill be glued on to this thread. Cant tell you how helpful it has been to me. Thanks. http://www.team-bhp.com/forum/4x4-of...-now-what.html
__________________ PARANOID: Having A Rear-View Mirror On Your Exercise Bike |
| | #18 (permalink) |
| BHPian Join Date: Apr 2007 Location: Jaipur
| #18 is the tie rod. As you said, it helps bot wheels steer together. The Jeep steering mechanism has MANY balljoints in it, and is prone to develope freeplay. The tie rod is also prone to bending if a the vehicle is abused off-road, but it can be fixed by adjusting the length of its ends. |
| | #19 (permalink) | |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| Quote:
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #20 (permalink) | |
| Senior - BHPian Join Date: May 2006 Location: Chennai
| Quote:
Yeah it is coolant and sharat has already answered that point I'd guess!
__________________ Only a V8 will do! Only a V8 | |
| | #21 (permalink) |
| Team-BHP Support ![]() | The radiator problem is not exactly solved. Last Friday I again had to fill 2lt of water. I even saw some leakage when the engine was left on. At that time I had filled the radiator to the brim. But I haven't seen any leakage since then, not sure how it could self-heal like that. Yesterday I drove it twice, after both drives I checked below the radiator, no leak. It has been suggested that I should just replace the radiator with a new one. How much does a new CJ340 radiator cost?
__________________ Samurai The only Super Car in my book -Bowler Wild Cat |
| | #22 (permalink) |
| Senior - BHPian Join Date: Jun 2007 Location: Kochi
| Before you replace the radiator - there are people who fix radiators - they will identify leaks and fix them using molten zinc. Look out for places with old radiators on display - like tyre repair shops displaying useless tyres. Asking a taxi / jeep near you will give some pointers to an exact location. A radiator is basically two tanks at top and bottom with several channels containing coolant / water running vertically, and horizontal fins to help dissipate heat. The channels and tank bocdy will be copper. So, you should be able to get at least 1/3 of the value of a new radiator as scrap value for the old radiator. In certain cases like accident damage to the vertical channels the radiator repair guy will simply close the channel, and I am told that a radiator will work (depends on vahicle) even with 5% of the channels blocked. In certain cases, the channels / channel assembly along need be replaced, without replacing the entire radiator (ie. you re-use the tanks). Have done this on a Ashok Leyland bus. About 10 channels were closed. the radiatory repair guy had said that on trucks which had the same ALM 370 entine, they cannot block more than 3 channels. :-) Of course, your jeep being a vehicle intended for serious off roading, you may be happier replacing the entire radiator. Yet another alternative for you will be to identify the equivalent of "Chor bazar" for your locality and find a radiator from a dismantled vehicle for your jeep. Again, these radiator repair guys will have them handy.
__________________ ɹǝʌıɹpʇɐǝsʞɔɐq |
| | #23 (permalink) |
| Team-BHP Support ![]() | Even without a leak, old Jeeps *drink* up radiator water pretty fast. Samurai : Check the condition of your fan and shroud too.
__________________ GTO Work backward from your imagination, not forward from the past!
| | #24 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
If it's overheating (temperature 20% more than normal), you will need to do something about the radiator. As Backseatdriver mentioned ,you can replace the 'core' alone with a new one and re-use the existing top and bottom tanks in it. You might get some value for the old 'core'. This is the simple solution. There is a more advanced solution.But, we won't go there since we don't need to,right now.
__________________ Han:The Red Evo's yours Sean:What do u mean? H:U're representing me now...What did U think, I'm gonna let you roll in a hyundai? | |
| | #25 (permalink) |
| More advanced solution - Open the radiator cap - drive - fill up water whenever engine temp touches 110 or 100 C, fill water again and keep going. Just ensure you dont blow the head gasket! Pl dont put back the radiator cap! An electric fan in front of the radiator also helps in keeping your engine temp at check!
| | #26 (permalink) | |
| Team-BHP Support ![]() | Quote:
Actually, I have been told to keep the temp below 90C for this Peugeot 2.1 engine, it will seize very fast at higher temps.
__________________ Samurai The only Super Car in my book -Bowler Wild Cat | |
| | #27 (permalink) | |
| Senior - BHPian Join Date: Jan 2008 Location: Faridabad
| This is indeed getting interesting and Samurai you have way of putting your posts and descriptions to pull in all readers...keep it up. Link bar? Quote:
| | #28 (permalink) | |
| Quote:
The engine will not seize if one keeps topping water every 10 kms or so. Trust me I've done this before! On a Peugeot Engine as well as a 796cc 3 cylinder one!
| | #29 (permalink) | |
| Senior - BHPian Join Date: Jul 2006 Location: Panaji - Goa/Bangalore - Karnataka
| Quote:
Replace/repair the radiator before the engine siezes. This engine dosent take too well to heat. Also check oil consumption. | |
| | #30 (permalink) | |
| Quote:
That method is only to get you from point A to point B in an emergency situation. I agree, one should watch out the engine temp before it seizes. but a slow drive say 40 - 60 kmph will not seize the engine!
| Thread Tools | |
Similar Threads | ||||
| 1990 M&m Cj340 | svsantosh | 4x4 Vehicles | 83 | 15th October 2009 10:18 |
| Jeep -Cj340. Heart over Mind | beejay | 4x4 Vehicles | 75 | 13th October 2009 19:19 |
| Using MM540 axles in CJ340 | Samurai | 4x4 Technical | 50 | 30th June 2009 03:04 |
| Diff between a CLASSIC and a CJ340 | bhoise | 4x4 Technical | 54 | 27th April 2009 13:08 |
| Upgrading brakes on CJ340 | Samurai | Modifications & Accessories | 54 | 18th June 2008 09:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
