| 4x4 Technical Engines, Diff-locks, SPoA, Techniques and more |
| | LinkBack | Thread Tools |
| | #481 (permalink) |
| Senior - BHPian Join Date: Jul 2007 Location: MUMBAI
| Dear Alfa Kilo - you are absolutely correct. Dear Sharath - please tell Richie's workshop to check for centralization of parts and correct as per workshop manual instructions, your vehicle will become OK. By the way, who canged the tie rods? Richie's guys will not make such a mistake. Best regards, Behram Dhabhar |
| | #482 (permalink) |
| Team-BHP Support ![]() | No, it wasn't the M&M workshop. Since it was a simple task, I gave it to my neighbourhood workshop. He generally does a decent job, this is a little surprising. Alfa_Kilo, I have posted the bellcrank end of it. I need a wider lens to get the whole part, will do that later.
__________________ Samurai Bureaucracy defends the status quo long past the time when the quo has lost its status |
| | #484 (permalink) | |
| BHPian | Quote:
Here's what I can best suggest. 1> Go to your mechanic's( the guy who fitted it) 2> Call me and give him the phone . 3> Will discuss and instruct him based on what he has done in the first place. 4> Have him explain to you ,the corrections he will carry out 5> Other wise we would need pics of the the following. a> Steering box assembly with drop arm in wheels centred position. b> Steering stoppers with wheels turned to full in each direction. Cheers Jammy | |
| | #487 (permalink) |
| BHPian Join Date: Apr 2007 Location: Jaipur
| I cant see anything wrong in the pics. Does yout steering have ball joints similar to the tie rod ends at the end of the longitudinal tie rod between the steering box and the bellcrank? If it has, then a grease nipple could be hitting the right damper top mount when the bell crank arm moves forward as you turn left. There are variations in the sizes of grease nipples and tie rod ends between different vendors. Check if the bell crank arm can move above the shock absorber mount freely. PS: Some of the split pins for the tie rod ends are not bent, and the grease nipples are not alinged properly. Did the mechanics use hammers to remove the old ball joints?
__________________ A 4x4 is born... Last edited by Alfa_Kilo : 8th April 2009 at 03:42. |
| | #488 (permalink) |
| Team-BHP Support ![]() | Today I called the Mechanic, and 10 minutes later he was at office to pick up the Jeep. [I know some of you may be rolling your eyes, but that's small town advantage for you. ]Before I reached the parking lot he had already replicated the problem. There is also a khatak sound when twisting the steering. He opened the hood and watched the steering box when I turned the steering lock-to-lock. The steering box actually moves up and down, he blamed it on a loose screw. Here is a video, notice the sound at 38th and 48th second. I also gave the printout of Behram's instructions to him. He read it carefully and then took the Jeep away.
| | #490 (permalink) |
| Team-BHP Support ![]() | Just 20 minutes back I remembered the Jeep. As I was thinking about calling, I get a call from the reception saying my Jeep is back. A bolt on the steering box was almost broken, that was replaced, that took care of the khatak sound problem and the movement in the steering box. Regarding the turning problem, he is not very sure. He says he had placed the bell crank exactly like the previous one, going by a marking. So he feels centralization is not the issue. He also suspected the alignment guys overdoing something. They had turned the tie-rod during the alignment, see the scratch in the center in the horizontal tie-rod. He turned the front tie-rod couple extra turns and adjusted couple of nuts and has improved the turning radius. By how much is still a question. It feels much better, but I still need to check it by turning in and out of my home. He charged 60 bucks for the work, pickup and drop complimentary. ![]() If the problem persists, I'll have to take it to Mahindra Workshop. That means 250 bucks just for the auto charges to go up and down. In addition the labour charges are much higher. Now you know why I use the local mechanic for small works.
__________________ Samurai Bureaucracy defends the status quo long past the time when the quo has lost its status Last edited by Samurai : 8th April 2009 at 19:40. |
| | #491 (permalink) | |
| BHPian Join Date: Oct 2008 Location: Kolkata
| Quote:
| | #492 (permalink) | |
| Senior - BHPian Join Date: Jun 2007 Location: Kochi
| Quote:
Fuel filter filters fuel flowing into the ifuel pump. It is located between the tank and the fuel pump. Depending on the make and system, there would be two filters with three filter elements between them. First has the pre filter and filter "elements", together making an assembley, and another "micro" filter near the fuel pump.
__________________ ɹǝʌıɹpʇɐǝsʞɔɐq | |
| | #493 (permalink) |
| Team-BHP Support ![]() | Yesterday while I was talking to Vinay Thomas, he wondered why the tie-rods appear to be so close to the drums. Even I am little confused, somehow I can't remember how close it was before. ![]()
| | #494 (permalink) | |
| BHPian Join Date: Nov 2007 Location: Chandigarh
| Quote:
Then as far as the oil filteration system is concerned, again there are very few "Indian engines" that use a secondary micro filter along with the main primary one. Infact, it is in dusty conditions like in our country that the mirco filter is the most necessary. Only the engines designed and licence sold by foreign companies like detroit diesel(powers the hyndai line, maybe others too), or toyotas, and some more motors have these things, although i'am not sure that even they have it in all their engines.
__________________ NO ONE IS COMPLETELY WORHTLESS THEY CAN ALWAYS SERVE AS A BAD EXAMPLE | |
| | #495 (permalink) | |
| Senior - BHPian Join Date: Jul 2007 Location: Dharamsala
| Quote:
In North America the big name in after market secondary filter systems is Amsoil. Amsoil also makes synthetic oil. I think they may be in India now, I am not sure. Here is an interesting link on their products. AMSOIL - Ea By-Pass Oil Filters (EaBP) Some people have fabbed similar systems on their own using toilet paper rolls as the filter. No joke. I am not sure whether they go for 1 ply or 2 ply, scented or unscented.
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi | |
| Thread Tools | |
Similar Threads | ||||
| Jeep -Cj340. Heart over Mind | beejay | 4x4 Vehicles | 101 | 2nd March 2010 10:31 |
| 1990 M&m Cj340 | svsantosh | 4x4 Vehicles | 112 | 6th February 2010 19:41 |
| Using MM540 axles in CJ340 | Samurai | 4x4 Technical | 50 | 30th June 2009 02:04 |
| CJ340 conquers the hill... | Samurai | 4x4 Excursions | 29 | 11th August 2008 22:06 |
| Upgrading brakes on CJ340 | Samurai | Modifications & Accessories | 54 | 18th June 2008 08:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652
