4x4 Technical Engines, Diff-locks, SPoA, Techniques and more
Thread Tools
Old 31st October 2009, 19:20   #616 (permalink)
kuttapan's Avatar
It is a huge difference compared to the wrong shocks experience. Now I have to remember how it felt a month before with the old shocks. Give me some time, now I can start doing some real test.
Samurai, Can we call them dampers, ? Somehow, shocks does not sound right, coming from you.
kuttapan is offline   Reply With Quote
Old 31st October 2009, 19:33   #617 (permalink)
Samurai's Avatar
Coming from me? But why? Shocks is a well accepted term. Check out the Bilstein website: Bilstein
__________________
Samurai
The only Super Car in my book -Bowler Wild Cat
Old 31st October 2009, 20:25   #618 (permalink)
DKG
DKG's Avatar
Don't you think that's purely relative to where you grow up? We've always called them shocks as an abbreviation for shock absorbers. No one will draw a blank across India when you say shocks. Chances are they will when you call them dampers
__________________
In changing yourself, you change your life
DKG is offline   Reply With Quote
Old 1st November 2009, 20:46   #619 (permalink)
kuttapan's Avatar
I thought you were a stickler for perfection, and I thought Damper is the correct term. The link just goes to show how little I know.. Should learn to keep my mouth shut.
Old 2nd November 2009, 21:25   #620 (permalink)
DirtyDan's Avatar
In most of the world, if you put pretty much the same thing, a shock absorber, on the steering arm it is then called a 'steering damper'. Go figure. Kuttapan, we all know you folk who live 'down under' have to do things bass ackwards. It has to do with all that living upside down like bats under the equator. That has to play hell with the circulation in your brain pans.
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
Old 2nd November 2009, 22:28   #621 (permalink)
SOME VERY IMPORTANT THOUGHTS:
Dear Sharath - I am very happy to read that your vehicle is running nicely after you have fitted the correct shock absorbers. A really nicely setup CL340 will corner at good speeds with good feedback from the suspension to the operator. This sets me thinking, and I have been thinking this for a long time - "because you got guided properly, your vehicle is now running properly". That said, my query is - "what happens to normal customers"? I request for comments from you / others also.
Dear Desert King - ref your post no 609 on wheel alignment, please note that as a design requirement, a suspension system should not necessarily need any attention at intervals even far exceeding 100000 kms. We have numerous vehicles doing 200000 kms in just more than a year without any suspension issue at all, with normal tyre life. Again, in a case-by-case basis where you are interacting with your vehicle at all times, your vehicle's behaviour will tell you not to interfere with it. Conversely, your vehicle's mis-behaviour (its behaviour will change suddenly one day), will tell you immediately when it is time to do something. If you analyse step-by-step, your vehicle will actually talk to you and tell you what you should be doing to it. For example, more than 70% of the "so-called wheel alignment" problems can be solved without putting the vehicle through the "so called" wheel alignment process. But, the trick is in - PINPOINTING EXACTLY WHAT TO DO TO SET THE CAR RIGHT!
Dear all - today I can state here with all humility that I HAPPEN TO HAVE THIS ALMOST UNIQUE ABILITY OF PINPOINTING EXACTLY WHAT TO DO TO SET THE CAR RIGHT (see Sharath's shock absorber example, even the best guys goof up / take incorrect actions). Therefore, please do write in with all your queries / suggestions, I will try and answer them to the best of my ability. Maybe we can have a thread for it. I don't know how it works. You guys may decide.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 3rd November 2009, 15:44   #622 (permalink)
kuttapan's Avatar
On a spherical object, kind of hard to figure out who is on top and who is 'down under', dont ya think? Been here for a few months only, so guess I have not been influenced much. Guess where I was for a year, before coming down under? The US of A !! Anyways, I prefer to call them dampers.
Old 3rd November 2009, 19:15   #623 (permalink)
sreerajunnithan's Avatar
Dear Sharath -This sets me thinking, and I have been thinking this for a long time - "because you got guided properly, your vehicle is now running properly". That said, my query is - "what happens to normal customers"? I request for comments from you / others also.
Even My vehicle is running Properly without any hitch. Regardless of not having the Luxury of your advise . It's not that i did not try for your advice, But "I was never guided properly" By you, or i would say "I was never Guided by you at all".
So what happens to the normal customers? Go to a spare parts shop, tell that you want a Shock Absorber for MM540 be specific on brands like Gabriel or any better ones (Gas filled ones are still better). Forget about shocks, i managed to find the oil pressure gauge switch (The electronic one) from a spare parts shop, where as, all of your so called "A.S.S" failed to find it, despite giving the exact part number.
Best regards,
Behram Dhabhar
This is an excellent idea!!! Moderators please suggest. This is important since you are a very Busy man and you may not be able to answer those tons of PMs.
--Sree--
__________________
Get Going, Go Jeepin...
sreerajunnithan is offline   Reply With Quote
Old 8th November 2009, 13:39   #624 (permalink)
swastikviji's Avatar
--Sree--
Hi Sree forget about A.S.S they don't have the courtesy of Asking a customer what you want, just by hearing the word 5** ,they say we don't have any thing.
__________________
The great pleasure in life is doing what people say you cannot do.....
swastikviji is offline   Reply With Quote
Old 8th November 2009, 13:53   #625 (permalink)
I agree! Most dealers and *** centres have no idea what to do when they see a 540/550. They actually treat us with disdain as they much rather prefer the Scorpio customer. I am sure most of us here are technically sounder than half the idiot mechanics in the Mahindra service centres.
The dealer in madurai, "SUSEE", stocks no 540 parts and is the least interested in procuring it either.
__________________
Live Life King Size!
jyobeb is offline   Reply With Quote
Old 8th November 2009, 18:05   #626 (permalink)
Originally Posted by jyobeb View Post
I agree! Most dealers The dealer in madurai, "SUSEE", stocks no 540 parts and is the least interested in procuring it either.
Ya i agree with you, here in Bangalore other than India garage no A,S,S, has..... forget about Spares they already thrown 5** Parts catalog to dustbin.
Even they don't know 1st generation of Boleros has the Same engine and Gear Box as 550.
__________________
Old 8th November 2009, 21:06   #627 (permalink)
Rehaan's Avatar
Even My vehicle is running Properly without any hitch. Regardless of not having the Luxury of your advise . It's not that i did not try for your advice, But "I was never guided properly" By you, or i would say "I was never Guided by you at all". ...
Sreerajunnithan,
Just so that there are no misunderstandings i want to point this out :
Firstly, whatever DHABHAR.BEHRAM does here is of his personal desire to help members out. Lets not even for a second think that he is required to help anyone out for any reason at all.
He does what he can, when he can. Sometimes people have the luxury and good-fortune of his advice (and they should be happy), and other times, I'm sure he has important matters he needs to attend to elsewhere (and members should understand this too).
Secondly, his interactions in these threads have been entirely in a personal capacity so far. He is not officially representing or acting on behalf of any manufacturer (therefore comments like "your so called A.S.S. failed to find it" might not be correctly addressed in this situation).
Please don't take this post in the wrong way - i just wanted to make sure everyone was on the same page here
....Therefore, please do write in with all your queries / suggestions, I will try and answer them to the best of my ability. Maybe we can have a thread for it....
BD,
I think the current set-up (ie different threads for each major issue/s) works better than one consolidated thread, as it makes finding specific issues easier for readers and also allows more in-depth and uninterrupted discussion per topic/problem/thread.
cya
R
__________________
The memory of you will ride by our side forever.
Old 9th November 2009, 12:31   #628 (permalink)
Dear Rehhan,
I agree on some of your points. But not all.
That's how any public discussion forum works, nothing wrong here. BUT, in that case, B_D never should ask anyone to PM him See this, http://www.team-bhp.com/forum/4x4-ve...ml#post1553950 (Need advise on 4X4) He can deny help, only if the question is been asked in public. But i personally think that, its is not right to deny the response to some one, in case if you ask him to PM. This is just like, not replying to an email, Ph Call or SMS. I have no doubt that every one will agree with me on this. If you ask someone to PM you, then you "Required" to answer it. Period.
We are on the same page here, i know he is a Busy man, hence supporting the seperate thread idea.
This response is not only for this thread, But B_D always advice all of us to go to Mahindra "A.S.S", if he is not acting on behalf of any Manufacture then he should not insist anyone to go "Authorised" Mahindra workshop only. I know, anyone will advice you to go to an "A.S.S" But, B_D tells the same in a "Strong" way. again, i don't want this thread to be a Battle ground. so Over and Out
--Sree--
__________________
Old 9th November 2009, 20:51   #629 (permalink)
Hi guys, sorry if iam hijacking the thread.I need help with my MM 540. Its been belching blue smoke after being started. The problem was less initially but nowadays its quite a lot. 2 mechanics told me that the diesel pump has some work. any thoughts on what could be wrong. Iam getting a mileage of about 8kms/lt or so. Also bangalore guys, if any of you can help by suggesting a good jeep mechanic or so, it would be nice. Iam fed up of driving in town with "smokey"
__________________
CAUTION: Jeeper Ahead........ Dont get me wild....
1995 MM 540 XD 4x4
2003 Alto Lxi
princezahed is offline   Reply With Quote
Old 9th November 2009, 21:42   #630 (permalink)
Zahed,
Your mechanics could be right. Think about a Pump calibration. But before this, clean your fuel lines and change your diesel filter if you haven't done it already. Are you feeling some power lose?
BTW tried calling you but your mobile is switched off.
--Sree--
__________________
Thread Tools
1990 M&m Cj340 svsantosh 4x4 Vehicles 83 15th October 2009 10:18
Jeep -Cj340. Heart over Mind beejay 4x4 Vehicles 75 13th October 2009 19:19
Using MM540 axles in CJ340 Samurai 4x4 Technical 50 30th June 2009 03:04
Diff between a CLASSIC and a CJ340 bhoise 4x4 Technical 54 27th April 2009 13:08
Upgrading brakes on CJ340 Samurai Modifications & Accessories 54 18th June 2008 09:25
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
