| 4x4 Technical Engines, Diff-locks, SPoA, Techniques and more |
| | Thread Tools |
| | #61 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Han:The Red Evo's yours Sean:What do u mean? H:U're representing me now...What did U think, I'm gonna let you roll in a hyundai? | |
| | #62 (permalink) |
| Distinguished - BHPian ![]() | I did notice a red Jeep dropped on its side being winched out sideways in some offroad trip here in India. Can't recall where it was. Do try it the next time you are out. At times you feel the co-passenger is almost sitting above you, its scary, but you love your vehicle when it does this without going into a downward slide, and worse a rollover .Oh BTW when you need to go up the very tall dunes you do this for considerable stretches as you climb. I think Vikid has posted some shots of his friends doing this.
__________________ In changing yourself, you change your life Last edited by DKG : 20th June 2008 at 17:51. |
| | #66 (permalink) | |
| Distinguished - BHPian ![]() | Quote: Thats a result of a jeeper's friend getting over-enthusiastic. It was after we finished the Palar in january 2007 . This dude drove the jeep fast without watching the track on the narrow path .This happened during transport. ![]()
| | #69 (permalink) |
| Senior - BHPian Join Date: Jul 2006 Location: Panaji - Goa/Bangalore - Karnataka
| I had a Operators Manual issued by Mahindra in 1992 for the CJ, NC, MM, FJ Series of vehicles with Diesel Engines. The below is an extract from it. I cant find the original but I had typed down all the details to a word file long back. Will look for the manual. Model: CJ - 340 DP 4 Wheel Drive Engine: 4-90 Diesel Curb Weight(4WD): 2640Lbs/1200kgs G.V.W:2500Lbs/1590kgs Axle Front: 4WD: Full floating hypoid type with 5.38 ratio Axle Rear: Semi floating hypoid type with 5.38 ratio Frame: Ladder type steel channel side members Brakes: Service Hydraulic internal expansion non-servo floating shoes, 279.4 mm (11") Parking: Mechanical operated on rear propellershaft Clutch:Single dry plate 23.5 cm(9 1/2") dia. Suspension:Semi-ellptic, leaf tyre springs with hydraulic double acting telescopic shock absorbers. Cooling:Radiator fin and tube type pressurised cap 0.63 kg/sq cm(9 psi) Fuel Tank:40 Litre capacity Electrical:12 Volt, 22 Amps Generator/35 Amps/ Alternator Instruments: Speedometer(km/h) Temperature & Fuel guages, indicators for charging oil pressure, high beam & turn signal Steering:Worm & roller type, right hand, Turning radius 5.3m(17-1/2') Transmission:4 forward and one reverse, 2nd 3rd & 4th synchromesh Gear ratios: 3.986:1, 1. 473:1, 1:1 Reverse: 5.315:1 Transfer Case:Two speeds with ratio 2.46:1 and 1:1 Wheels and Tyres:5 disc type 5-50x15 with F78x15 6 ply- highway/ Cross country Engine Specifications: Cylinder block:Cast Iron Cylinder Liner:Removable wet type Crankshaft:Forged steel, 5 bearing journal Connecting rods:Forged steel Main Bearings:Aluminium tin Pistons:Aluminium Cylinder head:Aluminium with turbulance chanbers Camshaft:Chilled casting, 3 bearing Valves:Overhead, rocker arm operated Timing:Gear operated Lubrication:Pressure Lubrication Cooling:By water Bore(mm):90 Stoke(mm):83 Cubic Capacity:2112 Compression ratio:22.4/1 Operating cycle:4-stroke(order 1-3-4-2) Cylinders:Inline arrangement Max BHP: 62 @ 4500rpm Max Torque:12.3 Kgm (89 lb.ft) @ 2000 rpm Someone here said the wheels were 16" and not 15" but this manual says 15" can anybody else verify? No the abve is not for the Classic but for the CJ340DP 4WD. Classic: CL340DP4WD Last edited by Spitfire : 20th June 2008 at 20:30. |
| | #71 (permalink) | |
| Team-BHP Support ![]() | Wow! Thanks a lot Spitfire, that's precious. Quote:
See the following series of photos: Front Axle: ![]() ![]() Rear Axle: ![]() ![]() ![]() They both appears as if the body is suspended on the ends of the leaf spring and the middle is supported by the live axle. Now, why is one called full floating and other semi-floating? BTW, for the uninitiated, live axle means an axle that has a differential. An axle without the differential is called dead axle, as in front axle of a 2WD Jeep. Next question, what is this apparatus under the driver seat? ![]() This fuel line looks dangerously dangling, is it safe in off-roading conditions? ![]() That's the rear drive shaft in the center (in focus) I suppose. ![]()
__________________ Samurai The only Super Car in my book -Bowler Wild Cat | |
| | #72 (permalink) |
| Team-BHP Support ![]() | This old vs new 4WD thread took away all attention. Can I get some answers to my above questions please... ![]() Just had a visit to the garage. After identifying multiple small leaks in the radiator core, we have decided to replace the radiator core, costs about 3K. Monday it will also receive a full flegded anti-rust treatment to withstand this humid monsoon.
| | #73 (permalink) |
| BHPian Join Date: Apr 2007 Location: Jaipur
| The front and rear axles (axle is the entire beam) look similar because they have common diffs (the hump in the middlr, 10 spline Dana 44). The front axle, obviously has steerable ends. The reason why the rear is called semi floating is because the rear wheel is supported partially by the driveshaft and a taper roller bearing. The driveshaft (or sometimes called the halfshaft, the link between the diff and the wheel) provides torque, supports the weight of the vehicle and the cornering, accelerating and braking forces. At the front end, the wheel is supported entirely by two opposed taper roller bearings. The front driveshafts just provide the torque. So it is called a full floating axle. Full floating and semi floating has nothing to do with leaf springs (ie the suspension) That bracket under the driver's seat, on the outside of the chassis long member supports the pivot for the brake pedal and the brake master cylinder ( seen towards the right in the pic). There is a split pin which hold things in place over there. Keep an eye on that, as it tends to wear away and snap. You should get your fuel lines routed properly, try to replace them with SS braided ones. |
| | #74 (permalink) |
| Senior - BHPian Join Date: Jul 2007 Location: Dharamsala
| Full floating axle: The axle does not support the weight of the vehicle. It only transmits power to the wheels from the differential. The wheel in this case is attached to the axle housing upon which it spins freely and it will do so whether the axle is there or not. The axle housing supports the weight of the vehicle via the wheel. Semi floating axle: The axle supports the weight of the vehicle AND transmits power to the wheel from the differential. The wheel is attached to the axle only. Take out the axle and the wheel goes too and will not, of course, spin with movement of the vehicle. At least, that is what I THINK it is. If I muffed it, somebody please scourge me severely.
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi |
| | #75 (permalink) |
| Distinguished - BHPian ![]() | To add to what the others have correctly stated I think the full floaters on the rear are also easily recognizable by lockable hubs. While technically this is not essential I think a good full floater would provide this feature so that when you break the axle you can unlock the hubs and still tow the vehicle. I should think most military spec vehicles would come with such full floaters.
__________________ In changing yourself, you change your life |
| Thread Tools | |
Similar Threads | ||||
| 1990 M&m Cj340 | svsantosh | 4x4 Vehicles | 83 | 15th October 2009 10:18 |
| Jeep -Cj340. Heart over Mind | beejay | 4x4 Vehicles | 75 | 13th October 2009 19:19 |
| Using MM540 axles in CJ340 | Samurai | 4x4 Technical | 50 | 30th June 2009 03:04 |
| Diff between a CLASSIC and a CJ340 | bhoise | 4x4 Technical | 54 | 27th April 2009 13:08 |
| Upgrading brakes on CJ340 | Samurai | Modifications & Accessories | 54 | 18th June 2008 09:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
where did this happen nitrous?
