| 4x4 Technical Engines, Diff-locks, SPoA, Techniques and more |
| | Thread Tools |
| | #76 (permalink) |
| Team-BHP Support ![]() | Ok, I am still not getting it correctly. Can someone post couple of images that can clearly illustrate the difference between full-floating and semi-floating, may be a cross section of the drive shaft. Meanwhile, I removed the soft top today so that I can give it for anti-rust painting on Monday. Checkout the beauty without the soft top.
__________________ Samurai The only Super Car in my book -Bowler Wild Cat |
| | #77 (permalink) | |
| Senior - BHPian Join Date: Jul 2007 Location: Dharamsala
| Quote:
I will try again. To float or not to float, that is the question. What is "floating", or not, is the axle. Imagine your ball point pen is your axle structure. Outside is the plastic housing, inside is the metal ink cartridge. The ink cartridge is the axle and the plastic housing is the axle housing. If it is floating then the wheel is connected via bearings to the plastic housing, the outside of the pen. The axle housing then bears the weight of the vehicle. If it is semi floating then the wheel is connected to the ink cartridge, the axle, via lugs and the axle rides on bearings AND ALSO SUPPORTS the weight of the vehicle. Because full floating axles do not have to support the weight of the vehicle they are stronger, usually, and this extra strength gives you a more robust off-roader.
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi | |
| | #78 (permalink) |
| Team-BHP Support ![]() | Thanks Dan, your pen analogy helped a lot. I was thinking that the whole thing including the housing as axle. Now it makes sense. When people say axle break, they don't mean housing, just the rotating part inside. In case of semi-floating, if the inside axle breaks the wheel will come out then. In full floating the wheel will stay intact, but no torque will be delivered to it. The front wheels can still take you home.
| | #80 (permalink) | |
| Team-BHP Support ![]() | Quote:
![]() Today the Jeep got the full diesel wash treatment before I handed it over for some work at the neighbourhood garage. 1) Radiator core to be changed. 2) Full body anti-rust treatment. 3) New key cylinder, old one is quite worn out. I can remove the key straight out and engine will be still running. 4) Rims and bumper going black. 5) The aluminium border work riveted to the body is a problem. Thinking of covering it with black vinyl beading work.
__________________ Samurai The only Super Car in my book -Bowler Wild Cat | |
| | #81 (permalink) |
| BHPian | Saumrai your jeep looks lovely without the top. So its a two seater or has it got the rear seats also? Hows the comfort level with the bucket seats?
__________________ You get shot in one EYE you shoot BOTH the EYES. This is the only way peace can prevail. |
| | #83 (permalink) | |
| | #84 (permalink) |
| BHPian | Awesome thread Samurai, my Jeep has been restored and waiting for me in Kerala. Would be back in India by July 15th and would get her to Chennai next weekend. Two things pending are a good canvas soft top and Roll Cage. Learnt so much from the thread, have to now practically see it once I get the jeep. Once again, great delineated thread ![]() |
| | #85 (permalink) | ||
| Senior - BHPian Join Date: May 2006 Location: Chennai
| Quote:
Quote: ![]()
__________________ Only a V8 will do! Only a V8 | ||
| | #88 (permalink) |
| BHPian Join Date: Jul 2007 Location: MUMBAI
| Dear Samurai - ref your post no 76 above on your axle shaft query, your CL340 is equipped with the original design semifloating axle. Nothing will ever happen to it. Just put new oil (SAE90EP) till filler plug level and you will be OK. There is no load on the axle (the vehicle is too tiny to load the axle), so factor of safety is very high. Best regards, Behram Dhabhar |
| | #89 (permalink) | |
| BHPian Join Date: Apr 2008 Location: on the move
| Quote:
But keep in mind that the quality of the axle is very important, and you should use Mahindra genuine axles. Other aftermarket or "local" axles are made of very low grade material that will shear very easily. Needless to say, upgrading to full float rear axles is not a solution to this type of failure. Regards, Gaurav | |
| | #90 (permalink) |
| Team-BHP Support ![]() | How do I know whether I have original axle, any identification mark? Meanwhile, I went to pickup my Jeep yesterday and the mechanic was concerned about my battery. He had removed the battery and placed in his office so that it won't get stolen. When he put the battery back after 3 days of non-use, it wouldn't start. He had to jump start it. He showed me one more thing, when he pressed the A-pedal hard, the battery indicator (ammeter?) hardly moved. He said something is wrong with the battery or the connector, one connector was loose but couldn't be removed due to rusty nut. So I left the Jeep so that he can take the battery to Udupi and get it checked with an auto-electrician.
| Thread Tools | |
Similar Threads | ||||
| 1990 M&m Cj340 | svsantosh | 4x4 Vehicles | 83 | 15th October 2009 10:18 |
| Jeep -Cj340. Heart over Mind | beejay | 4x4 Vehicles | 75 | 13th October 2009 19:19 |
| Using MM540 axles in CJ340 | Samurai | 4x4 Technical | 50 | 30th June 2009 03:04 |
| Diff between a CLASSIC and a CJ340 | bhoise | 4x4 Technical | 54 | 27th April 2009 13:08 |
| Upgrading brakes on CJ340 | Samurai | Modifications & Accessories | 54 | 18th June 2008 09:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
where did this happen nitrous?
