4x4 Technical Engines, Diff-locks, SPoA, Techniques and more
Thread Tools
Old 24th July 2008, 23:03   #31 (permalink)
4x4addict's Avatar
Infractions: 0/1 (7)
Originally Posted by RedMM340 View Post
Unfortunately there is a very limited number of lockers available for Mahindra jeeps since we have the 10 spline inner axle. The only ones that I have found are the the Auburn LSD, which I am running in my red 340 and a Lock Rite full locker..
Really? I thought Mahindra's came with 19 spline? Arka, any thoughts?
I was just recalling a thread started by Ignazio about his Tata TL 4x4 and he mentioned that he was going to install the Auburn's Electronically Controlled Traction Enhancing Differential (ECTED) - Limited Slip Locking Differential.
It's essentially and LSD which can convert to a diff lock by just clicking a switch. i.e electronic, as opposed to hydraulic, mechanical or pneumatic. I haven't read too much into it, but seems like a good options since you get the benefit of an LSD and a selectable Locker without having to install compressors and mechanical linkages. Seems like you only need to wire the switch which is probably a lot easier to do.
ECTED - Limited Slip Locking Differential - 4Wheel & Off-Road Magazine
Leading Manufacturer of Traction Enchancing Differentials & Planetary Drives - Auburn Gear
4x4addict is offline   Reply With Quote
Old 24th July 2008, 23:44   #32 (permalink)
RedMM340's Avatar
Oops, you are right the Dana 44 uses a 19 spline on the inside.
Yes the ECTED and the Detroit Electrac are really nice units that give you LSD and full lock capability. But they only come in 30 spline. And are over a $1000. You would have to get custom made axles to go along with this locker. Custom axles run about $700 for a pair in the rear, and over a $1000 for the front.
I actually almost did this a couple of years back, but decided against the custom axles, because if one broke here in India, there would be no chance of a repair for months. This would be really bad if it happened halfway to Leh! I went with the Auburn LSD p/n 5420111 and they make a big difference in sand & mud.
RedMM340 is offline   Reply With Quote
Old 25th July 2008, 01:09   #33 (permalink)
4x4addict's Avatar
You are right, they make 30 spline. The Tata Dana 44 must be 30 spline then, since ignazio was planning to install in his Tata TL 4x4.
5420111 is for axle ratios 3.92:1 & Up. Do you have the stock 4.88 final drive ratio on your classic? I am doing a DI Turbo engine conversion so am converting the differentials to 11/47 (4.27), so I guess I can go with the same one as you.
For those who are planning to install on the newer Turbo DI engined vehicles, I think they changed the final drive ration to 3.73 so you will need part number 5420112. I don't know when Mahindra switched to 3.73 from 4.27 for the DI range so may want to check your specific vehicle before ordering.
Old 25th July 2008, 02:32   #34 (permalink)
RedMM340's Avatar
First of all my red jeep is NOT a Classic (no offense to GTO and other Classic owners). My jeep is the CL340 which is much closer to the original CJ3B. It came with 5.38:1 gearing, which is really good for off roading and acceleration.
I am currently running 4.27:1 which is better suited to the higher power of the current 2.6 turbo engine, and give more relaxed freeway cruising. With 30" tires, I max out at 125kph. Sometimes I wish that I could go to a 3.73 ratio.
The DI turbo has a lot of torque, so you may want to go to a lower r&p ratio if you run stock size tires and want relaxed cruising. But if you are going to run oversize tires maybe a 4.27 will work. It just all depends on your type of driving, tire size, etc.
Old 25th July 2008, 07:12   #35 (permalink)
4x4addict's Avatar
The stock MM540 tire 6.00X16 I think is about 27 inches. I was considering the 3.73 ratio, but I have 235/70/16 tires with are about 29 inches. In addition, I am also putting an NGT520 5-Speed Tranny which has an overdrive so I am hoping that 4.27 would be a good balance between top end speed without negatively impacting the acceleration. My concern with 3.73 was whether it would impact acceleration. I know that MM540 are never meant to do 0-60 times but I'd atleast like to be faster than the DI Turbo pickups delivering vegetables to Bangalore ;-)
Old 25th July 2008, 09:15   #36 (permalink)
FourWheelDrift's Avatar
All of you may know this already, but just in case ...
There are some online calculators that assist with studying the effects of tire size changes or gearing changes (engine rpm range, gearbox, t'case, final drive).
Using off road gearing calculator - Google Search= , I found the below :
4x4Calc - 4x4 Off Road Calculator
Albins off-road gear : Ratio Calculator
4Lo.com :: Final Gear Ratio, Crawl Ratio, Tire Size Calculators
Happy fourwheeling,
FourWheelDrift
FourWheelDrift is offline   Reply With Quote
Old 25th July 2008, 11:18   #37 (permalink)
ex670c's Avatar
Default Tata - Dana 44
Originally Posted by DKG View Post
Arka my 207 has a rear Dana 44. Don't know how many splines. Would you know what kind of LSD would fit it?
I dont know what spline configuration the TATA vehicles use.
Just pull out one axle and you will get the spline count.
Besides I would suggest DIFF-LOCKS, that is if you want-to-be a serious off-roader.
Arka
__________________
JEEPers speak - Engage Mind, before opening Mouth!!!!!
Old 25th July 2008, 12:41   #38 (permalink)
DKG
DKG's Avatar
Arka
For serious offroading I would be getting the Gurkha, the LSD I need for the 207 as it will lug a camper on trails
__________________
In changing yourself, you change your life
DKG is offline   Reply With Quote
Old 25th July 2008, 22:24   #39 (permalink)
Monster_BHP's Avatar
Well most online write ups and reviews seem to favor the differential locks over the LSD but in my opinion when it comes to human mind Vs technology then the human mind is far inferior to technology, i mean you could be dreaming of a bikini babe in honolulu under the water falls or trying to impress your friends wife while carelessly pressing on the accelerator over a slope while losing traction and toppling the vehicle over, so in most cases the LSD suits us folks well and gives us the time to day dream safely.
But for the serious dude who is intent on listening to the sound of tyre and ground battling beneath for supremacy the natural instinct of the body out strips anything else on the planet, just like Sachin Tendulkar instinctively ducks his head at a 150km/hr bouncer from Shoib Akthar, which requires absolutely no thought but a gut instinct for self-preservation and it cant be replaced by any technology now or ever and thats what most serious off-roading trips mean. We all know LSD acts after the wheel loses traction but when your dam sure the other few centimeters is not going to hold good is it better to wait for the LSD to kick in after a slip up or would you rather want something to be done before? I am guessing that most serious off-roaders would want the control in their hands if not for gut instincts sake then atleast for the fun of it.
Even gold is not worth anything in the wrong hands, same way you cant blame the diff locks for our own short comings. I am not here to trash the LSD either, its loads of fun if you want to trash your way quickly or your just a tourist dune bashing in Dubai for the first time. These things where invented for the mass public exactly for that, to have a safe and fun ride without bothering about details but it will never be good enough for a guy who likes the smell of Diesel and doesn't mind getting his hands all greased up over a days drive. In other words the worth of diff locks is purely measured by the person who is driving the vehicle and his experience with off-roading. So in many ways its better to learn how to off-road with a Diff-lock and find out what mistakes have been done rather than something that keeps its secrets to itself and does not educate the driver.
__________________
Thanks....
Monster_BHP is offline   Reply With Quote
Old 25th July 2008, 23:07   #40 (permalink)
DKG
DKG's Avatar
Wow Monster BHP Wow. In all the time I've been at TBHP this is the first time I've come across someone who so succintly nailed an arguement. Fantastic! You just separated the men from the toy boys!!!!
__________________
Old 26th July 2008, 02:21   #41 (permalink)
RedMM340's Avatar
Monster BHP,
That is really deep. Nothing like some serious alcohol to really bring out the zen of 4 wheeling. Just don't try some off roading right now!
I just had a few myself.
Cheers,
Old 7th August 2008, 17:53   #42 (permalink)
Roshun's Avatar
This may be a bit but here's a cheaper experiment that I'm willing to try out at some point. Don't know if anyone here has tried it yet.
To get the effect of a LSD, with an open diff, it is theoretically possible to rig up two handbrake cables and levers to each of the rear wheels independently, instead of one regular handbrake that pulls on both rear wheels equally.
What this set up would do is, in case you have one spinning wheel and the other mired in slush on the rear axle, you could pull the handbrake on the spinning wheel and slowly give the jeep some throttle. This may force the differential into transmitting power to the other stuck wheel if it perceives that as having least traction at some point.
Do you suppose this would work? In theory I think so. If nothing it would set you up with temporary 3-wheel drive .
Cheers,
__________________
Roshun
"Evolution: From all fours to four-wheel drive"
2002 Wagon R Lxi
2006 Scorpio CRDe 4WD
Roshun is offline   Reply With Quote
Old 7th August 2008, 20:54   #43 (permalink)
4x4addict's Avatar
Roshun,
The Mercedes M-Class and some other newer SUVs with Full Time 4x4 Sytems do use this method. The M-Class applies the brakes on the spinning wheel and there by transferring the power to the wheel with traction.
However, if extreme 4x4 situations and constant use of this method could end up with your brakes over-heating and failing.
Old 7th August 2008, 23:21   #44 (permalink)
DKG
DKG's Avatar
Roshun its so darn uncanny that just a few weeks back I figured just this for my 207. Its so unreal that you have thought of the same thing. Wow
You bet it will work. Plus it would be the cheapest way to solve the problem.
Infact traction control systems employ this same principle
__________________
Old 8th August 2008, 10:31   #45 (permalink)
khan_sultan's Avatar
@ Roshun & DKG. I have a question on the above method.
I have no doubt on the 'theory' of what you have mentioned and agree that traction control and some new 4x4 may be using this method but have questions on implementation via rigging cables to each wheel from handbrakes.
Wouldn't these 'newer tech' 4x4/etc be using some form of EBD, computer controlled programs to decide the braking intensity and when to release the brake etc?
Can we get the 'same' effect in reality through the implementation method mentiioned above? Want to get some pro's and con's of this?
__________________
The best way to kill an idea is to take it to a meeting....
khan_sultan is offline   Reply With Quote
Thread Tools
Mahindra Major 4x4 jeep- A/C & Power Steering, Diff. locks, Snorkel amit kumar Accessory/Part Reviews 3 10th November 2009 21:09
Center Differential and LSD in SUVs Sawyer 4x4 Technical 104 26th October 2009 18:26
Cobra Locks me out married2speed Technical Stuff 26 31st March 2009 19:00
Friction Modifier for LSD suman Technical Stuff 10 8th September 2008 13:31
Question about safari Limited Slip Diffrential (LSD) tsk1979 4x4 Technical 44 1st March 2008 19:31
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
