Old 20th October 2015, 23:34   #121
tsk1979's Avatar
Thanked: 15,682 Times
Default Re: Diff-Locks vs LSD
And snow chains and studs are normally banned on proper roads for the same reason.
My reason for asking you was because you have snowchains, have you ever used them in mud, and if so, your comments.
Sutripta
No, I have only used them in snow. Never in mud. I have ventured in mud only once, and got royally stuck. Never tried again.
Old 26th August 2017, 11:27   #122
Thanked: 113 Times
Folks
I've decided to put an LSD in my Gypsy. Is the Eaton Helical gear Truetrac suitable for the rear axle? The product literature only mentions Chrysler, GM, Toyota etc but no Suzuki.
R
Ragul is offline   Reply With Quote
Old 2nd September 2017, 13:37   #123
headers's Avatar
Thanked: 457 Times
You could go for powertrax better than Eaton and some of us have used it.
Old 26th September 2017, 06:47   #124
Thanked: 113 Times
Thanks. This doesn't look like an LSD - it is a fully locking diff.
I was looking at this - http://www.tractionconcepts.com/Suzu.../tcxsz4528.htm
Seems to be friction plate type. There are allegations this was earlier known by the brand name "Phantom Grip" and that it has destroyed many Axles.
This is an old thread and a lot of good stuff has already been discussed in this thread. Moving away from generics and fundamentals already explained - I would like to weigh the pros and cons of this design before I go for it.
Ragul
Old 2nd October 2017, 07:57   #125
headers's Avatar
Thanked: 457 Times
Personally I'd prefer a full locker than a LSD as there is positive traction at all times. Setting up the locker correctly is the key to proper operation!!😋
Mahindra Pik-up / Getaway - Export version with Diff Locks Parm 4x4 Vehicles 6 22nd April 2014 15:41
Do Diff locks compensate for lack of articulation? tsk1979 4x4 Technical 86 3rd April 2010 12:35
Mahindra Major 4x4 jeep- A/C & Power Steering, Diff. locks, Snorkel amit kumar 4x4 Technical 5 24th December 2009 10:22
Question about safari Limited Slip Diffrential (LSD) tsk1979 4x4 Technical 44 1st March 2008 19:31
