Old 21st August 2008, 21:23   #46
madbullram's Avatar
Thanked: 76 Times
I know Khan, i tried some 15 diff colours before finalizing this. I was sad but now I looking forward to building the engine and get it back on road
Mods: Can we rename the Thread as CJ3B - Wanderlust - Rebuild?
madbullram is offline   Reply With Quote
Old 21st August 2008, 21:34   #47
khan_sultan's Avatar
Thanked: 3,872 Times
Originally Posted by madbullram View Post
...but now I looking forward to building the engine and get it back on road
That's the spirit buddy. Keep it going. cheers:.
Wishing you all the best.
Cheers,
khan_sultan is offline   Reply With Quote
Old 21st August 2008, 21:43   #48
simply_sunny001's Avatar
Thanked: 16 Times
Indeed very nice looking Jeep @MAdbullRam
We all will be waiting and glued to this thread for updates.
All the best
simply_sunny001 is offline   Reply With Quote
Old 21st August 2008, 23:24   #49
4x4addict's Avatar
Thanked: 2,672 Times
Madbull
Where did you get the power steering installed? Is it done well? I want to install PS on my MM540.
4x4addict is offline   Reply With Quote
Old 22nd August 2008, 01:42   #50
nitrous's Avatar
Thanked: 285 Times
Who's doing the Jeep work in Chennai,Ram?
Old 22nd August 2008, 06:51   #51
madbullram's Avatar
Thanked: 76 Times
4X4: It was done in Trivandrum by my friend. There is a small problem with the steering and we need to fix it. The PS is def good but let me wait till the problem is fixed before I pass my judgement. Also, I found the Aramada steering assembly awesome. Actually I wanted to setup the Armada one but we got this setup cheap so went with that.
Nitrous: Thats not yet decided. Currently, the Jeep is in Ramesh's shed. He is in Velachery near to the bridge. His dad has been working on Jeeps for the last 40 years and he also has been with Jeep and they service a lot of government jeeps. Plus I hear that this is not a compliecated engine. I am hearing good things about Popoular Automobiles who specialize in engine rebuilds. So still thinking.
Yesterday got the quote from the Mechanic:
Labour: 10,000 Rs
Lathe Work : 5,000 Rs
Spares Required:
Required List:
Main Bearing 10size 1set
Connect Rod bearing 10 size 1set
Connect rod 1 number
Main bearing trust washer 1 set
piston rings 1set 1st oversize
timing chain
timing chain tensioner
wall tapet
cam shaft bush (optional)
main bearing robe (made in france)
Head gaskit 3rd oversize (option 1 sympson=Rs.400, option2 mahindra=Rs.2100 both are good)
Radiator top and bottom hose
Oil filter
COST: 7,400 Rs (This was the quote from RK Automobiles in Chennai)
Optional List:
Clutch plate
Clutch bearing
clutch Disk
COST: 4,000 Rs
Engine oil 71/2 liter
Summary Cost for Engine Buildup:
1. Mechanic Charge = 10000
2. Lathe work = 5000
3. Required Parts = 7,400 (+ head gasket either sympson or OE)
4. Option Parts = 4,000
5. Engine Oil = 800 (Approx)
TOTAL = 27,200 Rs
So looking at a 30K budget.
Old 22nd August 2008, 09:37   #52
Thanked: 4,751 Times
Dear Madbullram - From all posts that I have read so far, I understand that the car is now in Chennai (please correct me if I am wrong). My recommendation is to please get the work done by M&M Chennai dealer. Please PM me. I will guide you in totality. Any other route will not give desired results.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 22nd August 2008, 10:33   #53
madbullram's Avatar
Thanked: 76 Times
Hi Behram,
Thanks a lot. I did approach Mahindra dealers but the attitude was really bad. They treated me like unwanted fellow trying to rob their precious time from the Scorpio and other big customers. Also, since the Jeep also has Tata Seira components they said they will have to think about it. The guy was also saying they havent worked on such vehicles and have to think of taking it or see if they have anyone who has the experience.
I have sent a PM. Hope it would help!
Old 22nd August 2008, 10:48   #54
Please see my PM to you. Don't worry, you will have a turnaround experience soon.
Best regards,
Behram Dhabhar
Old 23rd August 2008, 23:22   #55
madbullram's Avatar
Thanked: 76 Times
Default Engine Pics
Went to the garage and did a thorough inspection. Still have decided on whom to hit the rebuild. I have my mechanic who seems to be honest and was straight forward. Has good experience and is a authorised government jeep technician.
Then I have Mahindra Garage OE guys who I am sure will do a very good job but will cost me twice which is little difficult situation for me considering my personal financial situation. Still thinking.
The current analysis:
  • the Piston is fine and only rings needs to be changed
  • One connecting rod is badly burnt and others are fine, still micron test has to be done. So need to buy one rod alone
  • Once done all might be 10 oversize and worst case would the bad one will be 20 oversize and the others 10 oversize
Now pics:
This is the badly affected one and also you can see the connecting rod that was burnt in the pics below.
The first one is the burnt one and the next is the normal one which will be retained.
Old 23rd August 2008, 23:28   #56
madbullram's Avatar
Thanked: 76 Times
Pics continued:
Pistons, the analysis is that they are good and only the rings need to be changed.
The leaking PS Unit, the analysis is to change the metal tube to the bolero type rubber ones.
Pour in your thoughts pls
Old 28th October 2008, 09:00   #57
headers's Avatar
Thanked: 464 Times
What does he mean by con rod burnt? Can you elaborate please? Generally, if one opens the engine, it is necessary to replace rings and in some cases bearings as well!
Old 22nd January 2009, 11:10   #58
fk7
fk7's Avatar
Thanked: 142 Times
so ram,
what happened to your wanderlust? has it been rebuilt?
FK
fk7 is offline   Reply With Quote
Old 19th March 2009, 22:11   #59
Infractions: 0/1 (5)
These 3 pics tells you how we loaded the Jeep on the truck using a small mud mount and with help of locals . All they wanted was a cup of tea for this.I saw the difference between City Folks and Village Folks. Unadulterated life.
Attachment 40973
I should say that bit of luck was with you to get such a sandhead at the middle of nowhere
4x4 loaded is offline   Reply With Quote
Old 11th June 2009, 09:08   #60
Ramsagar's Avatar
Thanked: 63 Times
madbullram:Long time no see for almost 3 months.what had happend to the rebuild?
seriously waiting for the update.
Ramsagar is offline   Reply With Quote
Wanderlust traveller - 350 kms away & 700 years back - Bangalore to Hampi mpksuhas Travelogues 19 12th December 2013 12:45
25,000 kms of wanderlust with my trusted comrade Hyundai i20 Magna athanedar Long-Term Ownership Reviews 2 18th November 2011 08:23
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
