Old 4th August 2008, 22:52   #46
DirtyDan's Avatar
Thanked: 747 Times
Is the fan belt set at the correct tension? Could the belt be loose and slipping thereby not turning the fan fast enough to provide optimal cooling?
Same question for the water pump, is the belt slipping and allowing the pump to NOT turn optimally?
Above, if a bearing is going bad in the pump it will resist turning and the belt will slip. It will not pump enough water.
Are the radiator vanes all bent up or corroded on the outside so as to not allow good airflow? Similarly, is the outside of the radiator caked with dirt, crud, restricting airflow?
Does the coolant in the overflow tank go back into the radiator automatically after the engine cools down? If not, there is perhaps a leak somewhere in your cooling system.
Old 4th August 2008, 23:28   #47
Samurai's Avatar
Thanked: 14,539 Times
The fan belt is new, it is not slack, many Jeepers at Coorg OTR checked and confirmed it.
Same belt right?
Mechanic says water pump is fine.
The radiator core is new, I had it installed recently.
Yes, it does.
The engine stays at 80C while ripping at 70-80kmph on a level road under hot afternoon sun for hours. But, it rises to 100C climbing uphill for just 10-15 minutes in pouring rain. Could this be a coolant system problem?
Old 4th August 2008, 23:51   #48
tsk1979's Avatar
Thanked: 15,684 Times
Samurai, just a hunch.
1. PArk you car and idle for 15 minutes in sun and see what happens
2. If everything is okay, then park your car such that front wheels are atleast 1-1.5 feet higher than rear wheels, and then idle. See if she overheats
Old 5th August 2008, 03:44   #49
DirtyDan's Avatar
Thanked: 747 Times
Great idea! But, if it does overheat, what does this indicate and what does he do about it? Massive rear tyres and wheels are probably not an option. My guess is that if this clever test yields an overheat then it is still the water pump that is not moving enough coolant.
The only other thing I can think of is an obstruction within the engine water jacket itself and I can not imagine how that would happen except by long disuse and massive corrosion inside. This is unlikely. My bet is the water pump.
Samurai, my comments on your radiator were focused on the outside of it, the air flow, not the interior core.
Old 5th August 2008, 09:49   #50
DKG
DKG's Avatar
Thanked: 929 Times
Samurai
I was surprised to notice your thread hasn't progressed beyond the cooling issue!
Please go about it methodically and solve it. Two elements constitute cooling efficiency in an engine. Water/coolant flow and air excavation through radiator fins.
Poor water pump function, jammed thermostat, scaling of cylinders hamper effective circulation and contact with cylinders
Inadequate radiator size and fan hamper cooling of the water.
Check the following in sequence
1. Does the radiator on your Jeep match the engine it has? Sometimes when bigger displacement diesels are slotted in and the old smaller radiators left in this can happen.
2. Is the fan of the correct size and blades? Also is it at the correct distance from the radiator
3. If the system has a water flow control thermostat, have it taken out. You don't need these in non-snow climate conditions
4. Heavy scaling. As most people in India have traditionally used tap water for coolant a lot of scaling occurs around cylinder liners. Use some industrial grade descaling agents and see if that helps.
5. On petrol engines when the timing is retarded engines heat up. I don't know much about diesels but have your injector pump set for correct timing (unless it already is) and ensure the engine is not too retarded. At this stage also do a compression test to see if the engine is worn out.
Last but not the least if the engine on your Jeep is a modern lean burn engine then you require a pressurised radiator system as these engines run hotter and pressurizing reduces the boiling point of the coolant and maintains the quantum of coolant in the system even at close to boiling temps.
DKG is offline   (1) Thanks Reply With Quote
Old 5th August 2008, 10:19   #51
DKG
DKG's Avatar
Thanked: 929 Times
How has he concluded this? Without opening it? In which case all he checked was if the bearing was fine and there were no leakages. The culprit can also be a ineffective impeller which could either be of a smaller size or one thats come loose on the shaft.
Unhook the hose that inlets into the radiator and adding water through the cap inlet start the engine and see if the water pump output is fine. As you rev it should increase the water flow output.
DKG is offline   Reply With Quote
Old 5th August 2008, 11:24   #52
Samurai's Avatar
That sounds so interesting, I have to try it. First I need to find two really big bricks to stop it from rolling back.
Well, it is turning out to be an elusive problem. I live in a tiny town/village, don't have access to top mechanics who can feel out the problem.
The engine is original, the new radiator occupying all the room available.
Who can judge this? My mechanic thinks it looks fine.
There is no thermostat.
I mentioned this to the mechanic, I got a puzzled look back. I don't want him to do something he doesn't understand. Do Mahindra service centers do this routinely?
That is on the cards.
The 2.1 Liter XDP 4.90 Peugeot Diesel is well known, I don't know whether it is lean burn or not.
I guess I have to talk to him again.
Old 5th August 2008, 11:41   #53
DKG
DKG's Avatar
Thanked: 929 Times
Measure the fan distance to radiator on any other standard Mahindra with this same engine which doesn't have a cooling problem to rule this out. Also verify if the fan and pulleys are correct for the above engine
As I don't know much about these engines check if it requires the pressurised coolant system and if that is fine too then do a flow test. The Shop Manual should give details of litres/minute @ a certain rpm for water pump efficiency. If the water pump tests fine then the problem is either scaling or a retarded engine (also weak compression), which you can eventually ascertain through a compression test.
Barring the undoing of the water inlet hose at the radiator to check on the flow test all the other checks do not require dismantling anything and you can do this at home if you have access to a Shop Manual. A compression test you can do at any garage with the meter
As a general rule for anyone maintaining an old vehicle I strongly recommend acquiring a Shop Manual and a Parts Catalogue as both are invaluable resource materials. Apart from their value in getting it right the first time you also avoid expensive mistakes while ordering parts.
Old 5th August 2008, 14:05   #54
Spitfire's Avatar
Thanked: 692 Times
Infractions: 0/1 (7)
The engine needs a overhaul.
Spitfire is offline   Reply With Quote
Old 6th August 2008, 08:45   #55
headers's Avatar
Thanked: 459 Times
How do you say that? Nowhere does it indicate that his engine is consuming oil and loosing power.
One does not just overhaul an engine for a mild overheating issue!
Old 6th August 2008, 11:20   #56
Spitfire's Avatar
Thanked: 692 Times
Ok fine. Samurai, hope you get it sorted asap.
Old 6th August 2008, 11:56   #57
Samurai's Avatar
That's true, other than overheating in uphill driving, there are no other symptoms.
Old 6th August 2008, 12:14   #58
khan_sultan's Avatar
Thanked: 3,467 Times
Maybe it's time for you to visit Jammy along with your 340 and get him to sort this out for you .
khan_sultan is offline   Reply With Quote
Old 6th August 2008, 12:50   #59
Spitfire's Avatar
Thanked: 692 Times
Awaiting that compression test result.
Old 6th August 2008, 13:21   #60
Jaggu's Avatar
Thanked: 7,676 Times
Samu: Check your diesel pump calibration/settings, have a feeling that can be the reason.
Matiz Overheating & Mileage Problem Kchittilla Technical Stuff 57 27th July 2013 21:43
Fiat Linea - Overheating problem... ihrishi Technical Stuff 36 10th September 2009 15:35
Matiz - SG 99 - Overheating problem deeps79 Technical Stuff 3 10th July 2009 09:40
Strange Overheating problem with my OHC toiingg Technical Stuff 26 5th July 2008 20:22
Overheating problem in corsa... gkrishn Technical Stuff 2 14th March 2007 10:52
