Old 2nd February 2011, 15:12   #91
ex670c's Avatar
Thanked: 1,799 Times
Default Assumption
Originally Posted by SPIKE ARRESTOR View Post
my query was "What is the basis for all these assumptions", if that means offending someone then so be it.
Spike
Hi Spike,
For Reference - http://www.team-bhp.com/forum/offici...review-52.html (Mahindra Thar : Test Drive & Review)
Question 1 - Why was the Thar Lifting Wheels.
Answer is IFS and RTI Score, even though Thar CRDe has better Rear-Axle Articulation compared to most regular JEEPs.
Question 2 - What has IFS to do with Rear Lifting.
Post#43 -- http://www.team-bhp.com/forum/4x4-te...ulation-3.html (Articulating on Articulation)
Sharath, went further to make a graph using Lifting a Tyre (on a ramp/obstacle) vs Shifting of CG.
On a Ramp/Obstacle the Rear Wheels/Type of Suspension/Chassis will determine the Articulation.
If you include these factors, the Shifting of CG in non-linear on a Ramp/Obstacle.
The basis of assumption is observation, maybe we cannot explain it in scientific terms but that does not mean it cannot happen or has not happened, and this is not a one off phenomenon.
You have explained the Shift in CG on a Bank (Side-Slope), and we are talking about in a RTI Ramp/Obstacle.
Arka
PS - I don't even get offended by sarcasm.
Old 2nd February 2011, 17:33   #92
headers's Avatar
Thanked: 457 Times
Default Re: Articulating on Articulation
And drop the 'sir' Vikram, not after we got aquainted face-face...
Nevermind Santhosh - There are some here who are pleased by that word!!
I am not an expert when it comes to offroading parlance (I am still learning), but with whatever little I know, your reasoning fails to convince me i.e. why should CG shift non linearly?
Spike, If CG shifts linearly, then all topples - I mean the rate of topple will also be linear. This somehow is not the case in real life.
There is a threshold point during the topple until which it appears slow [linear?] after which you just fall [well non linear!!!]
I have toppled twice to tell you this !
Old 2nd February 2011, 17:48   #93
ex670c's Avatar
Hi Vikram,
Stop UNCL-ing.
And describe the conditions for your Topple/s.
1) Were they on road or off-road
2) How many wheels were in the air before you toppled?
3) Was the topple caused by pronounced/sudden acceleration.
4) Please describe the vehicles and necessary mods (mechanical).
Arka
PS - Stop taking the BE & MS in UK bit seriously, go easy with the threshold
Old 2nd February 2011, 18:07   #94
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 461 Times
Body Tilt/Vehicle lift could be non-linear depending on the suspension setup (shown in the modified graph of Samurai that I posted). The shifting of CG with respect to the vehicle lift/body tilt should be linear.
That is gravity
In a real life off-roading situation you have other forces at play like centrifugal foces, force (obstruction) offered by obstacles etc. The same vehicle that is able to put one wheel up by 3 feet on a ramp without toppling could topple in a trail by climbing onto a 2 feet obstacle, because of the other forces at play.
pjbiju is offline   Reply With Quote
Old 2nd February 2011, 22:06   #95
Thanked: 2,127 Times
Bumping a thread which has gone dead for all of 4 hours!
Guys,
What will be the behaviour of a vehicle with Independent Suspension compared to a solid axle one if it has the same suspension travel and the same spring rates?
Sutripta
Old 2nd February 2011, 23:05   #96
Jaggu's Avatar
Thanked: 7,654 Times
A very amateur try, i feel vehicle can be more unstable in an offroad terrain. Reason being the IFS is attached to the vehicle which will result in high CoG compared to a low slung solid axle displacing the weight at less height.
Old 3rd February 2011, 00:55   #97
AutoNoob's Avatar
Thanked: 207 Times
Thumbs up Re: Articulating on Articulation
The FAW difference in IFS and solid axle is not significant. The majority of weight is in the differential housing and the drive shafts/ drive rods so the only difference comes from the weight of tubing of solid axle. Also, this difference is somewhat off-setted by the additional weight of CV joints. Therefore the CoG of the vehicle does not change significantly.
A definite benefit that is derived from the solid axle comes from the leverage effect. For the same spring and damper travels, the wheel travel is more in solid axle as compared to IFS. This results in higher cross articulation.
Therefore speed of vehicle while approaching an obstacle plays a crucial role in safely over-coming it. This is supported many times by off-roading experts in the Off-Roading forum.
AutoNoob is offline   Reply With Quote
Old 3rd February 2011, 10:35   #98
Jaggu's Avatar
What is FAW?
And if what you say is true, the majority of weight part, then CoG is definitely lower in a solid axle right?
Old 3rd February 2011, 10:47   #99
pjbiju's Avatar
Thanked: 461 Times
FAW - Front Axle Weight
Old 3rd February 2011, 10:48   #100
starter's Avatar
Thanked: 269 Times
What is FAW?
Full Articulation at Wheel? (too..).
Thanks Biju.
starter is offline   Reply With Quote
Old 3rd February 2011, 11:26   #101
pjbiju's Avatar
Thanked: 461 Times
Guys,
Sutripta
In a sold axle suspension setup, when one side is pushed up, it automatically tries to push the other side down (which would be less pronounced if the suspension is very stiff). This I think is a major adavantage of solid axle setup. In the IFS setup, if one side is pushed up, the other side will get pushed down only by its own weight mostly. So for cross articulation, solid axle setup will do better even if the IFS setup has the same suspension travel and spring rates. This is what I feel. I could be wrong though.
Old 3rd February 2011, 11:40   #102
Thanked: 7 Times
Guys,
Sutripta
Again, no scientific proofs and formulae , but given the same suspension travel and spring rates I think a vehicle with independent suspension will be less likely to topple than a vehicle with solid axles.
This opinion is largely influenced by having watched Baja style buggies and Tatra (and other european military vehicle manufacturers) type trucks going over boulders as if they don't exist (because it is Independent, only a single wheel is lifted while the rest of the wheels and the chassis itself hardly even tilts).
'72 Bullet is offline   Reply With Quote
Old 3rd February 2011, 11:43   #103
Thanked: 822 Times
think what will happen if the Thar's ,anti roll / stabiliser bar is removed .
I had asked this before ,
IMHO , at the cost of some high road speed,(specially cornering & above 100 kmh) this will give wonderful articulation at front & the wheels will hold good for more traction .
Sudarshan
@ 72 Bullet I feel similar,
Sudarshan is offline   Reply With Quote
Old 3rd February 2011, 11:45   #104
ex670c's Avatar
In a sold axle suspension setup, when one side is pushed up, it automatically tries to push the other side down (which would be less pronounced if the suspension is very stiff). This I think is a major advantage of solid axle setup. In the IFS setup, if one side is pushed up, the other side will get pushed down only by its own weight mostly. So for cross articulation, solid axle setup will do better even if the IFS setup has the same suspension travel and spring rates. This is what I feel. I could be wrong though.
Hi Pjbiju,
I would like to add a diagram.
Hilux 4x4 Off-road Forum - View topic - SFA vs IFS
Stock vs. IFS Lift vs. Live-Axle Conversion - Technical Articles - Four Wheeler Magazine
Arka
Sudarshan
Hi Sudarshan,
The Stabilizer Bar has secondary feature of maintaining the Wheel Track.
This will be important especially under Articulation (RTI Ramp).
How much more wheel travel will you get by removing the stabilizer bars?
Don't you think they will add more strain/load on the Lower Arms and Rack & Pinion Steering?
Arka
Old 3rd February 2011, 12:09   #105
Thanked: 822 Times
Originally Posted by ex670c View Post
Hi Sudarshan,
Thanks ( at last, I am less a JEE )
how ? can you be Thar specific
Arka
my feeling is ,if that bar is removed both sides will be acting independently .So if one wheel goes over a rock ,it will move upward in the wheel well & the opposite will still hold the ground .
As there will be no connection bet the two( the anti roll bar) it will be really an IFS
need to think deeper here , will be beneficial
Sudarshan
P.S. your IFS picture , third frame
Articulation @ Bidaraguppe lake and water wading at Dhakshina Thirupathi hisunil 4x4 Excursions 41 7th March 2011 12:48
Do Diff locks compensate for lack of articulation? tsk1979 4x4 Technical 86 3rd April 2010 12:35
