Old 27th February 2011, 10:07   #16
jeepster's Avatar
Thanked: 1,035 Times
Default Re: Wheel spacer
where can i get a good quality spacers in mumbai or pune for armada to mach the track width of FFRA with front axle?
front is 57 inch closed knuckle axle.
rear is 53 (51?) inch FFRA.
in case of 51 inch a pair of 3 1/2 inch sapcers will be needed to mach the track of front axle.
in case of 53 inch a pair of 2 1/2 inch spacers will be needed to mach the track of front axle.
jeepster is offline   Reply With Quote
Old 27th February 2011, 10:48   #17
svsantosh's Avatar
Thanked: 1,444 Times
God save you... people say that even a -Ve offset rim will bust a jeeps bearings - you want a 3.5INCH Spacer. Dont do it!!
svsantosh is offline   Reply With Quote
Old 27th February 2011, 11:02   #18
jeepster's Avatar
they are for full floating rear axle, i think it can handle them.
in case they can not i will swap the axle with FJ or maxx ones. (58~59 inch track)
Old 22nd October 2011, 09:08   #19
sreejeshmp's Avatar
Thanked: 576 Times
Does a 1.5" Spacer on MM550 will effect the off road performance ?
sreejeshmp is offline   Reply With Quote
Old 19th March 2012, 19:16   #20
Thanked: 58 Times
I believe the broad consensus here, is that spacers = bad karma
Given a requirement to adapt the wheel PCD to a specific bolt pattern, what would the recommendation be ? would spacers be acceptable in this context?
lugnut is offline   Reply With Quote
Old 21st March 2012, 11:11   #21
4x4addict's Avatar
Thanked: 2,668 Times
@lugnut:
Spacer is a Spacer regardless of weather you are going to use it for PCD change for wider track. The effect on the wheel bearing is the same. That being said, a well made spacer upto an inch or so think is fine. It might decrease the life of your bearings, but there is not much of a choice is there.
4x4addict is offline   Reply With Quote
Old 12th December 2015, 20:03   #22
Thanked: 235 Times
Trying to bring a dead thread to life.
Came across this while researching on Wheel Spacers.
On a side note, i have no clue why Mahindra made the rear track width smaller than the front in the Bolero. Why would they do that? Mahindra / Bolero experts, any logic behind it?
-- Torqy
Torqy is offline   Reply With Quote
Old 14th January 2016, 13:53   #23
Bump-Stop's Avatar
Thanked: 47 Times
-- Torqy
I presume a narrower Track width at the rear improves turn radius...but I could be wrong.
Bump-Stop is offline   Reply With Quote
Front Wheel Drive v/s Rear Wheel Drive Revvhead Technical Stuff 269 3rd August 2017 15:48
Spring spacer & Spring rate question Sankar Technical Stuff 15 23rd January 2011 20:21
My Experience of using Carburetor Spacer finetuning Technical Stuff 13 15th September 2008 17:08
Wheel spacer for M800? Sankar Tyre & Alloy wheel Section 26 9th November 2007 17:44
Need some info on steering spacer. Shan2nu Technical Stuff 9 24th May 2007 05:42
