Old 27th January 2009, 20:03   #61
Thanked: 1,503 Times
Wicked! I know the feeling
Steeroid is offline   Reply With Quote
Old 28th January 2009, 11:38   #62
Kandisa's Avatar
Thanked: 425 Times
Great to see the update. Awesome off-roading performance with on-road zipping! Whow!
Kandisa is offline   Reply With Quote
Old 14th February 2009, 21:55   #63
Tusker4x4's Avatar
Default Crawl ratio
Hi Khan_Sultan,
I have heard from Naveen and Arjun that you have installed a crawl ration in your Gypsy. Kindly enlighten on the crawl ratio. And is it maily for the Gypsy or for Jeeps also.
Regds
Amit
Tusker4x4 is offline   Reply With Quote
Old 15th February 2009, 09:11   #64
khan_sultan's Avatar
Thanked: 3,466 Times
Originally Posted by Tusker4x4 View Post
...I have heard from Naveen and Arjun that you have installed a crawl ration in your Gypsy. Kindly enlighten on the crawl ratio. And is it maily for the Gypsy or for Jeeps also....
Amit, It's mentioned in the opening post of this thread.
here is it again:
I have 'crawler gears' in the t-case. These have 'short gear ratios'.
Crawl ratio is the ability of a 4x4 to 'literally crawl' on a terrain. The higher this ratio the better. This ability comes handy when traversing over rocks/boulders.
To give another perspective on what this means in off-roading & rock climbing, let me explain on what this will do to the 'crawl ratio' of my MG413W
The stock crawl ratio of MG413w is:
3.652 * 2.268 * 3.727 = 30.869
With the 4.16:1 t-case gearset, the crawl ratio would become:
3.652 * 4.160 * 3.727 = 56.621
To put this in perspective, the crawl ratio of a CL340 & CL340 Classic is:
3.986 * 2.460 * 4.880 = 47.851 (CL340 Classic)
3.986 * 2.460 * 5.380 = 52.754 (CL340 )
Now, the crawl ratio of my Gypsy is ~10% more than the CJ340 jeep & ~20% more than the CLASSIC.
So now I have the best of both world -- an amazing crawl ratio & all the advantages of a Gypsy (momentum, light weight, speed, etc..)
PS: I think that the Ultra Low Rock Crawler t-case gear sets are available for Jeeps also but not needed for the kind of terrain that we do in India. The jeeps have plenty of 'rock crawling' capabilities and the diesel low end torque helps. So no need for this in a Jeep.
In a petrol Gypsy, this mod address the low end torque issue with 'gearing'
khan_sultan is offline   Reply With Quote
Old 15th February 2009, 20:25   #65
Tusker4x4's Avatar
Great !!
Arjun, one of the member in NIOC just bought a new gypsy. We had a problem of reversing him back from a climb in 4x4L reverse as the engine braking did not work. Infact I think Pushkin gave you a call for this also.
So the crawl ratio is needed in gypsy. We did hear that it is there in the Army Gypsy's, is it so ?
Amit
Old 15th February 2009, 21:16   #66
Tusker4x4's Avatar
Hi Khan Sultan,
Just saw ur avtar (as they call it here).
So it was your Jeep on the climb in the Mini OTR thread in the Resort you guys were staying for the Munnar GE.
That was realy putting crwal ratio to test. Great going
Amit
Old 16th February 2009, 00:12   #67
gotzuk's Avatar
Thanked: 67 Times
Do not believe in hearsay.
Army Gypsy's are identical to civil versions in totality.
The only things extra are the rear tow plate/hook and blackout lamps.
gotzuk is offline   Reply With Quote
Old 16th February 2009, 09:14   #68
.... We had a problem of reversing him back from a climb in 4x4L reverse as the engine braking did not work.
Yes, there is a huge difference of engine braking in Petrol Gypsy & Diesel Jeeps. You can't compare the two.
... So the crawl ratio is needed in gypsy.
No. not necessary. I did not have it for 2.5 years in my Gypsy and never was able to NOT do a terrain which jeeps were able to do. It required a slightly 'different' way of tacking the terrains.
Now, why I have put in the 4.16 t-case gearset is another discussion altogether.
That should be the mantra -- for all aspects of mods also.
Old 13th March 2009, 02:27   #69
Kushagr's Avatar
Khan_Sultan great goint with the T case mod. Having driven a stock 410 I know this addresses the gypsys need for crawling. A winch would greatly enhance off road capability, given the T case mod and the rear diff -lock.
Kushagr is offline   Reply With Quote
Old 23rd March 2009, 19:39   #70
Here is an update on the t-case after this weekend's recee.
As usual the torque is just amazing and managed to do some rocky terrains with amazing ease.
However I blew 2 of my t-case beading's because of the immense torque it generated while I was trying to pull out another Gypsy that as stuck.
The blown beading gave me lots of grief and good that I had a spare t-case beading that we managed to put in.
Good thing is, that with SPoA the GC is so much that one can just slide underneath and do the repairs (Yes, there are 2 people below the Gypsy in the picture below)
Learning's for me:
  • Don't use the Gypsy for pulling a stuck vehicle out -- especially if there is a MM around. The t-case beadings will just blow up & also the clutch
  • Always carry spare t-case beadings -- if possible, atleast a dozen
  • Invest time & effort in finding a permanent solution for this
Cheers,
Old 24th March 2009, 11:29   #71
ex670c's Avatar
Thanked: 1,799 Times
Default T-Case Beading/Beds/Gaskets
Learning's for me:
Cheers,
Hi Shahnawaz,
By T-Case beading do you mean the Rubber Beds on which the T-Case is mounted?.
Normally I have seen gypsy's damaging their T-Case Beds because they have not Lower or Top Cross-Member, and any impact/hit/scrap to the T-Case damages the T-Case Bed.
Have you ruled out the SPOA mod and the additional pinion angle/pinion pitch as a factor.
In case you are talking about the T-Case Gasket then check the breather plugs, they maybe blocked and are not venting the hot air, resulting in high pressure in the T-Case and Gasket Leaks/sweating.
Also the Max Torque coming out from the T-Case is
1 Gear X Low Ratio X Engine Peak Torque = 3.6 x 4.16 X 13kgm = 194kgm
Reverse X Low Ratio X Engine Peak Torque = 3.4 X 4.16 X 13kgm = 183kgm
That is not too much, and I'm sure you would have reached the same levels in every off-road after the T-Case mod.
Arka
Old 24th March 2009, 17:11   #72
Thanked: 42 Times
Shanavaz,
You have now almost doubled the torque on the axles. Some time, open it and have a look at the drive spline's condition for any wear or twisting
suresh
Suresh Stephen is offline   Reply With Quote
Old 24th March 2009, 18:47   #73
siddartha's Avatar
Thanked: 22 Times
when one of the t case beddings on my gypsy gave up , i couldnt find one in time so , i used a ss80 ( old m 800) gearbox bedding in its place , see if you can use those at all 3 points . they are bigger but managed to fit it .
the stock bedding is actually very small and the quality of the ones available are not that great .
we think of changing the t case bedding only after it breaks , may be we should change it as a part of preventive maintenance .
also which reminds me , you owe me one t case bedding , when you buy them by the dozen.
siddartha is offline   Reply With Quote
Old 24th March 2009, 19:00   #74
Originally Posted by ex670c View Post
Hi Shahnawaz,
It is the rubber beading -- 3 in nos. I broke two of them and they actually shear off due to the torque. As siddharth mentions below they are not of good quality and it is a very well known problem in modded t-case setups worldwide.
This time they sheared (I think) because while trying to pull out a gypsy. They were perfect before that.
suresh
Will do a check sometime. I know what you are referring to am have that on my mind
Originally Posted by siddartha View Post
... the stock bedding is actually very small and the quality of the ones available are not that great .
yes. 100% correct.
I had just changed all 3 just some months ago while the t-case mod was done
Yes. It was actually your spare beading that I used last week. I owe you one.
Old 24th March 2009, 20:24   #75
DirtyDan's Avatar
Thanked: 746 Times
Khan, there is sometimes a big difference between N. American English and U.K. English. This may be a case. WHAT IS A BEADING exactly? It is still unclear to me.
DirtyDan is online now   Reply With Quote
Gypsy on Steroids: Lockers installed and tested now khan_sultan 4x4 Technical 192 26th June 2014 23:34
Gypsy on Steroids: Rear Up Front (RUF) Suspension modification khan_sultan 4x4 Technical 23 3rd April 2011 21:56
Gypsy on Steroids -- The SPoA Project. EDIT: Stage-2 Started now.. khan_sultan 4x4 Technical 239 3rd February 2011 15:06
Gypsy on Steroids: Maxxis Trepador M8060 MT. Update Now on Yoko Geolander MT! khan_sultan 4x4 Technical 102 27th August 2010 16:46
Gypsy on Steroids: Next Dose -- Short Chassis for reduced rear overhang khan_sultan 4x4 Technical 56 24th March 2009 12:39
