Old 25th April 2009, 20:39   #91
headers's Avatar
Thanked: 457 Times
Interesting..KS should be in bangalore coming weekend. Shall call you on arrival!
Old 30th April 2009, 12:42   #92
Brutus's Avatar
Thanked: 45 Times
Khan saabh, has your xfer-case problem been solved?
Take a look at this, Sam need help on what to do with the rear end... - Page 7 - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips.
I was surfing for 33" boggers and this thing came up. This guy here lifter the xfer-case of his sami by a few inches by modding the mounts. Although there's nothing in detail, but you could get some ideas.
Brutus is offline   Reply With Quote
Old 1st May 2009, 22:23   #93
khan_sultan's Avatar
Thanked: 3,466 Times
Thanks Brutus. As I mentioned earlier, I will be doing something totally different:
  • Adding 2 more mounts on the long arm (making 4 mounts spaced by 5-6 inches each over a 1ft or so).
  • For this, on the underside of the long arm, a 2-3" wide plate will be fabricated and put across the length of the long arm
This should hopefully address the t-case mount issue as the 'increased gearing torque' will be split over 4 mounts (compared to 2 right now)
This would still mean that the mount at the short arm would remain same (just one).
If the 4 mount option fails or the short arm mount begins to fail then will try some Plan B (fabricating custom mounts)
Cheers,
khan_sultan is offline   Reply With Quote
Old 10th July 2009, 09:45   #94
Gypsy-Boy's Avatar
Hi Khan
Another solution to your t-case problem.
Mighty Kong
You should be able to get this fabricated locally.
GB
Gypsy-Boy is offline   Reply With Quote
Old 24th July 2009, 22:47   #95
Mighty Kong
Hi GB, thanks. I know about this -- it is a protection for your t-case. a kind of a custom skid plate for your t-case that sits on stock mounts.
This will not help much. What works is either reinforcing the t-case long arm or having mounts of different types.
I am still to get this work done. Will get it done soon and post an update here.
Gypsy on Steroids: Lockers installed and tested now khan_sultan 4x4 Technical 192 26th June 2014 23:34
Gypsy on Steroids: Rear Up Front (RUF) Suspension modification khan_sultan 4x4 Technical 23 3rd April 2011 21:56
Gypsy on Steroids -- The SPoA Project. EDIT: Stage-2 Started now.. khan_sultan 4x4 Technical 239 3rd February 2011 15:06
Gypsy on Steroids: Maxxis Trepador M8060 MT. Update Now on Yoko Geolander MT! khan_sultan 4x4 Technical 102 27th August 2010 16:46
Gypsy on Steroids: Next Dose -- Short Chassis for reduced rear overhang khan_sultan 4x4 Technical 56 24th March 2009 12:39
