Old 6th November 2011, 14:10   #46
svsantosh's Avatar
Thanked: 1,392 Times
Default Re: Jeep PTO units (Winches, generators etc)
I picked up the one on right... notice the slightly bigger bore.
Originally Posted by Sudarshan View Post
AFAIK , these air compressors dont run at high rpm , not more than some 1000 rpm ( usually 750 or so ) so pulley size needs to be checked .so Please check & set the RPM factor before you run the thing , check if the pulley has integrated fan for cooling
Also Engine driven compressors from trucks have their lubrication system through the engine lubrication circuit itself , you will need to check this factor also before running
1) I plan to test the RPM factor by experimenting with different pulleys.
2) This pulley is OE and has no provision for cooling AFAIK (but the 4 spokes are heavily angled like a kitchen exhaust fan and may AID? in cooling?
3) This comp has a oil bathed crank with the base being a oil sump. Notice drain bolt at bottom below data plate. Oil fill is above the data plate, looks good to hold at least 250ML oil.
Noticed a ingenious stopper in UBS's Jeep to safe guard the PTO Lever, uploading here for future ref. Pulling it back engages the PTO (Pic taken from left side of the jeep)
svsantosh is offline   Reply With Quote
Old 6th November 2011, 14:23   #47
Thanked: 822 Times
ya thats the thing I was talking about , its a fan integrated in the pulley
very good
use engine oil ( sae 40 or multigrade 20/40 ) as lubricant
Attachment 837783
fantastic but simple arrangement , thats why he is a master
Sudarshan
Sudarshan is offline   Reply With Quote
Old 11th November 2011, 18:51   #48
DeClutch 4X4's Avatar
Thanked: 64 Times
Hi jeep sir,
I was working on a client 'TruckLine Parts and Services (Sask Ltd) based in Canada, and happened to visit their site for some information and to my sruprise there was a mention of PTO and wet kit Installation.
The Good Jeeper in me stopped working on the report and quickly logged on to Tbhp to report you the same. I just hope it helps you in a way or some way.
here's the link -
Truckline Parts & Service - Home
Truckline Parts & Service - Dump Bodies / PTO's / Hydraulic Pumps & Cyclinders
Truckline Parts & Service - Parts
For jeep sake,
DeClutch
DeClutch 4X4 is offline   (3) Thanks Reply With Quote
Old 22nd November 2011, 20:06   #49
Thanked: 64 Times
Hi All,
Came across another client, claiming Manufacturers/ Importers of PTO drives. Got the details for your references.
Top Gear Transmissions Pvt Ltd
Description: Manufacturers / Importers Of planetary gear boxes, helical gear boxes, bevel helical gear boxes, sugar drives, nauta mixer drives, centifuge drives, pto drives, creep drives, winches, track drives
Contact Person : Mr Shrikant Pawar
Street : W-41 Additional Midc Satara
Province/state : Maharashtra
http://www.indianyellowpages.com/topgear/
Happy PTO hunting
For jeep sake,
DeClutch
DeClutch 4X4 is offline   (2) Thanks Reply With Quote
Old 29th December 2011, 16:35   #50
Thanked: 64 Times
Another one for reference:
Power Take Offs, Split Shaft PTO, MPVG 600 PTO, MLK V1 PTO, GBS 40 V1 PTO, EATON 6306 A PTO – Supplier from India
the manufacturer claims to supply PTO's to mahindra and other auto giants in India.
Contact:
Alpha Drives
1/1, VKK Menon Road,
Venkatapuram,
Coimbatore 641025,
India.
Phone No :+91 422 4202 951/952Email - ptos@alphadrives.co.in
And, also i came across a website selling whole lot of PTO's. I guess someone from US/UK can pick it up easily.
here you go,
http://autoline.info/s/attachments-PTO--c23tk248.html
Last edited by DeClutch 4X4 : 29th December 2011 at 16:51. Reason: Addition of information
DeClutch 4X4 is offline   (1) Thanks Reply With Quote
Old 12th January 2012, 02:25   #51
Chanderjeet's Avatar
Thanked: 103 Times
What an interesting read this has been. Very informative. Thanks everyone. I do not yet own a jeep but would be getting one sooner than later. Thanks again !
Chanderjeet is offline   Reply With Quote
3D computer modelled cars, bikes etc (3DS, Maya etc) blueraven316 Shifting gears 103 23rd January 2015 13:23
Water Powered Car / HHO Generators - Boost mileage & performance sumith Technical Stuff 88 25th November 2013 15:00
Synthetic rope vs Wire Rope for Winches Tejas@perioimpl 4x4 Technical 10 5th April 2013 01:07
Anti honda?? Anti suzi?? Anti fiat?? Anti ford etc etc?? Vent out ur opinions here!!! mclaren1885 Shifting gears 3 29th June 2006 14:23
