4x4 Technical Engines, Diff-locks, SPoA, Techniques and more
Thread Tools
Old 4th December 2008, 02:15   #16 (permalink)
prmd_cochin's Avatar
Well the Nissan engine can be squeezed in, we took our guy all the way to chennai to check out the engine specs. Infact we had seen this same engine in Chennai while hunting for other jeep parts and so decided to get one for us too. We dont know exactly the formalities of importing are,we paid some 'guys' some money in Dubai and we got the engine in like a months time. I guess it came in as scrap.
Yes its a 2X2 and we are converting it into a 4X4, the navarra is 4X4 engine. Well we have our fingers crossed about mating the Mahindra box into the navarra engine, but we trust our guy, he is simply amazing. 4X4 is a must as we plan to do some serious offroading.
We also have changed the pedal alignment to the roof from the floor, its easier to drive like that.
prmd_cochin is offline   Reply With Quote
Old 4th December 2008, 15:44   #17 (permalink)
Originally Posted by mathewJ View Post
@prmd_cochin
nice 540.. can you tell me the cost of the 540 and where the workshop in cochin
It cost us 60k, we havnt kept a budget for the modifications. There is no point keeping a budget for modifications, it cannot be done within that as we found out. Travelling itself is so expensive, we went around with the entire gang that included my 2 cousines, 2 mechanics and poor me. The only thing i got cheap was the powersteering.
__________________
Ford Ikon 1.8 Nxt
Mahindra TD25
Old 4th December 2008, 17:50   #18 (permalink)
4x4addict's Avatar
Infractions: 0/1 (7)
What power steering set up are you using? How much did it cost. I'd like to do the same for my MM540.
4x4addict is online now   Reply With Quote
Old 4th December 2008, 19:08   #19 (permalink)
I'm setting up mine with a bolero power steering, almost new, this i picked up from coimbatore. It cost me 4000.
__________________
Ford Ikon 1.8 Nxt
Mahindra TD25
Old 5th December 2008, 09:43   #20 (permalink)
Kandisa's Avatar
Are you sure you didn't miss a zero while putting the cost here? An almost new bolero power steering for 4k!!! Man, I want one, tell me if some more piece is available.
-Best regards,
__________________
Kandisa
Trying to understand the JEEP thing.....
Kandisa is online now   Reply With Quote
Old 5th December 2008, 12:52   #21 (permalink)
-Best regards,
Our TD engine had a powersteering pump, so we bought only the power steering box, which cost us 2500 and another 1500 for labour. Its almost in a brand new condition, had just run 3000 km.
I should say we were lucky to get such a almost brand new piece.
__________________
Ford Ikon 1.8 Nxt
Mahindra TD25
Old 5th December 2008, 13:06   #22 (permalink)
Some off beat pictures i took when we went to Kunjithany to get the patchwork done. This is my home town,beaujtifull and silent.
That jeep was used to transport massive wood logs, dont be misled by its looks, that jeep is in perfect condition.
__________________
Ford Ikon 1.8 Nxt
Mahindra TD25
Old 5th December 2008, 20:12   #23 (permalink)
Salikt's Avatar
[quote=prmd_cochin;1080567]Some off beat pictures i took when we went to Kunjithany to get the patchwork done. This is my home town,beaujtifull and silent.
Ooops! I got a nostalgia feeling now. Looks like my home town in calicut!
Salikt is offline   Reply With Quote
Old 5th December 2008, 20:18   #24 (permalink)
Salikt's Avatar
Default MM 540/540 Wheel Base
Hi chaps,
Can any one give me the details about the wheel base for MM 540/550. If I'm not wrong it is 91 inch. Same as Jeep wranger is it?
I'm asking you the question bcoz I was thinking about the possibility of installing a Wrangler hard top on a 540/550. Is it possible to do that modification with some alterations on the body?
Old 5th December 2008, 23:24   #25 (permalink)
So finally the heart has been transplanted, phew. That was a huge huge hurdle crossed. But Kunjetan has asked me not get too enthusiastic as all can be confirmed after the engine is fired and driven around, thats still weeks away.
One more issue that cropped was that the engine was very very water sensitive. We are getting a Qualis lifting pump installed, along with a homemade alarm that would alert us when tank gets the full.
Improvisation, guys thats the name of the game !!!
MM540 with its original heart.
The new heart, and after it mounting.
The gear lever.
__________________
Ford Ikon 1.8 Nxt
Mahindra TD25
Old 6th December 2008, 18:38   #26 (permalink)
whitemm550's Avatar
make sure that you change that 'EL-CHEAPO' steering wheel, it looks messy when you do up the jeep. try fitting a scorpio or the bolero steering wheel. it looks classy.
__________________
' A WILL FINDS A WAY '
whitemm550 is offline   Reply With Quote
Old 7th December 2008, 03:02   #27 (permalink)
Thanks for the point. Will try to fit that in. How much would that cost? Here is the interior with the redone pedal set up.
__________________
Ford Ikon 1.8 Nxt
Mahindra TD25
Old 7th December 2008, 13:42   #28 (permalink)
We have finished most of the work related to the Engine.
The work that we have finished now are.
Booster brake of Nissan Load King has been successfully fitted.
Hydraulic clutch , gear box has been fitted. The clutch is hydraulic, we didnt know that. It has no cables !!!
Engine succesfully fited into the MM540 engine bay. We did face some issues as we ran out of space for the radiator, we had weld out a small porting to let the radiator in.
Now we need to fit in the lifting pump and the airfilter.
__________________
Ford Ikon 1.8 Nxt
Mahindra TD25
Old 7th December 2008, 18:04   #29 (permalink)
hey prmd_cohin, is the clutch based on hydaulic thrust bearing or it has an actuator out side [ slave cylinder] on the outer caseing? and what is the master cylinder taken from, is it from an indian vehicle or from the nissan itself?
dinar is offline   Reply With Quote
Old 7th December 2008, 19:08   #30 (permalink)
deepclutch's Avatar
everything Jeep ,you have it in Thodupuzha town which is approx 62 kms from Ernakulam.
__________________
Get GNU/Linux
ever learning procedure of becoming a defensive driver.
deepclutch is online now   Reply With Quote
Thread Tools
The Campagnola Is Reborn sushanthr77 The International Automotive Scene 1 12th September 2008 15:09
K-I-T-T is reborn! madan80 The International Automotive Scene 1 14th December 2007 10:44
Reborn at 75000 kms- my wagonR devarshi84 Long-Term Ownership Reviews 3 24th July 2007 14:31
Ferrari’s Dino reborn maxbhp The International Automotive Scene 10 10th December 2006 22:24
Tata Indigo Marina! Reborn Estate??? v12 The Indian Car Scene 10 23rd March 2004 19:47
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
