Old 9th December 2008, 09:41   #16
Thanked: 31 Times
Please post some specifications of the modification you plan to do.
Also why is you Jeep seen in different set of wheels in the pictures you have posted?
Cloud_Chaser is offline   Reply With Quote
Old 9th December 2008, 10:13   #17
whicked wheels's Avatar
Thanked: 56 Times
Also why is you Jeep seen in different set of wheels in the pictures you have posted?[/quote]
The wheel work is yet on, only one wheel was done for testing. The others will be done by next week.
whicked wheels is offline   Reply With Quote
Old 9th December 2008, 17:09   #18
Thanked: 56 Times
[quote=whicked wheels;1084749]This is the list of the work and the cost.
1) De-denting and painting:- rs20,000
2) Bucket seats :- rs3,500
3) Seat covers fixed type :-rs5,000
4) Maxiss mudzilla's tyres 31x10.5-15 :-rs8,500
The cost of the tyres is Rs8,500 each
Old 9th December 2008, 17:23   #19
Thanked: 56 Times
Here are some pics of overhaulin of the mechanicals.
Old 9th December 2008, 17:39   #20
prmd_cochin's Avatar
Thanked: 81 Times
This is coming out well. That fender innovation was good, me too would need to do the same.
I have alreasy started loving your machine.
prmd_cochin is offline   Reply With Quote
Old 9th December 2008, 18:27   #21
Terrainsnooper's Avatar
Very good work with the Jeep, Whicked! Pat yourself on the back for all the hard work put in so far. It'll be very interesting to see this Jeep once done, it sure will have a tremendous presence.
One question, where in Pune did you manage to get those tow hooks,front and back? Also which tyre dealer deals with the Maxxis'?
I'm glued to this one, keep the pics coming... its a great inspiration!
Terrainsnooper is offline   Reply With Quote
Old 9th December 2008, 20:28   #22
vinayrathore's Avatar
Thanked: 306 Times
Default Great Going...!
Hey Wicked Wheels!
Great Going so far!
I m also thinkin on the same lines. The vehicle should be one of a kind and recognizable from a distance.
Do shed some light on the drive train. What kind of hubs you are using etc.
I am glued too!!
Best of luck!
Vinay Rathore
vinayrathore is offline   Reply With Quote
Old 9th December 2008, 22:14   #23
Thanked: 56 Times
Thanks guys, ill try to do my best. the tow hooks were given to me by a friend he got them from some scrap guy up north, and the same guy deals in tyres too.
Hi vinay thanks man, the drive train is of a mm540 only and so are the hubs the only thing is they are the double bearing ones (rear).the front dont have free wheelings hub locks.
Note from the Team-BHP Support Staff : Please use the "edit" button if posting within 15 minutes of the first post, instead of creating another back-to-back post
Also use "Multi Quote" option for quoting Multiple posts.
Old 10th December 2008, 08:26   #24
Thanked: 4,673 Times
Dear Whicked wheels - with all due regard to the people carrying out the mechanical work on your vehicle, I may like to mention that doing work under such atrocious conditions with dust all over the place can affect bearings and quality of work. Suggest you move to a better housekept place.
Best regards,
Behram Dhabhar
DHABHAR.BEHRAM is offline   Reply With Quote
Old 10th December 2008, 11:13   #25
Thanked: 31 Times
Best regards,
Behram Dhabhar
Even I was going to suggest the same. Dont mind but from the pics it looks like a garbage dumping ground. The mechanics might be excellent with their work but as Mr. Behram suggested work enviorment does affect the performance.
Even I liked the idea of fenders, the pipes with sheet metal over it.
Old 10th December 2008, 23:14   #26
payam's Avatar
Best regards,
Behram Dhabhar
This is his own workshop and he's doing the job himself
payam is offline   Reply With Quote
Old 11th December 2008, 08:55   #27
Thanked: 56 Times
Hi payam you got it wrong its not my shop. Its the paint shop where the painting was done. I could not help it as i dont have my place any more it was rented. I wanted to do all the mechanicals in my parking but to my bad luck we just dug a bore well and there was a lot of muck around. I take a lot of care doing my work and try to keep the parts clean.
Old 11th December 2008, 19:46   #28
Salikt's Avatar
Thanked: 32 Times
Hi Wicked Wheels,
Good work and looking forward to see more pics...
BTW A question from my side about the the tubular fender/Mud guard flares. Actually the strength of material used for Fender/mudguard flares should be less than the body metal. The basic idea behind this theory is to avoid any damage to body line incase of any accident or hit on the flares. Thats why its made by either Fiber or thin metal sheets than the body metal.
In my observation, since you welded the tubes on the body, even a small crash from side tool, surely will reflect on your jeep body too.
Any way looking forward on your work progress
tks/sali
Salikt is offline   Reply With Quote
Old 12th December 2008, 10:16   #29
Thanked: 56 Times
Hi Salikt, THe tube fenders are very strong and they have given added strength to the body, but as you say in an accident you can never tell how it will hold up. Without a douth its going to bend the body depending on the impact.
Old 17th December 2008, 08:57   #30
Thanked: 56 Times
Hi guys, just got the gearbox assembly fitted last night. I also changed my 4wd shifter setup from a two leaver to a one leaver set up found in a mm550.
Never thought I'd build a Jeep! My MM540 story manveet 4x4 Vehicles 97 29th May 2017 10:22
My MM540 4X4 Build: new shell, SOA, PS etc 4x4Roadie 4x4 Vehicles 41 28th October 2016 16:54
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
My Mahindra MM540 Build kingvikz 4x4 Vehicles 53 23rd October 2012 16:45
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
