Old 22nd July 2009, 22:37   #46
swastikviji's Avatar
Thanked: 158 Times
Originally Posted by khan_sultan View Post
Hey Vijay, the snorkel looks very nice & neatly fabricated. Great work sir.
Now I need to get this done on my Gypsy soon.
Hi Sir
Design Concept From Your Postings only, you are still not patented it no ?
swastikviji is offline   Reply With Quote
Old 22nd July 2009, 22:45   #47
Sha
Sha's Avatar
Vijay snorkel looks good all set for water splash OTR.
Sha is offline   Reply With Quote
Old 22nd July 2009, 23:20   #48
trammway's Avatar
Thanked: 220 Times
Viji sir,
Any information about the pricing part of your snorkel head ? Also let me know through what channel you them in here, may be I would like to have one after our plans as discussed over the phone got into implementation stage.
trammway is offline   Reply With Quote
Old 22nd July 2009, 23:50   #49
Thanked: 158 Times
Originally Posted by trammway View Post
Viji sir,
Hi Shiva
(please Don't use Sir ok)
I paid 5000-00 ,i bought it from Ozone in Bangalore, its readily available with him hence i am not tried other options. i am preparing it for TPC mean i don't have sufficient time to search and organize, only one thing left from Arkas must have list, Seat belt, i take up this on Monday-V.Vijay
Old 23rd July 2009, 07:54   #50
discoverwild's Avatar
Thanked: 1,169 Times
A newbie's question. If the snorkel is facing forward (like the safari make), will it not imbibe water if you are riding on the highway when it is raining? Is there a place where water exits?
discoverwild is online now   Reply With Quote
Old 23rd July 2009, 09:11   #51
star_aqua's Avatar
Thanked: 89 Times
This link must answer all your doubts.
4x4 Connection - Snorkel FAQ
star_aqua is offline   Reply With Quote
Old 23rd July 2009, 10:44   #52
sreerajunnithan's Avatar
Congrats Viji. Now your engine is splash proof One observation, was it possible to extend the pipe inside the bonnet so your rubber hose is not visible outside?
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 24th July 2009, 10:59   #53
Thanks, Star_aqua. It does.
Old 24th July 2009, 22:58   #54
Thanked: 158 Times
Wink
--Sree--
Hi Sree
Its possible but my tinker already done it, now again i cant ask him to take out and redo the same, next time when i have some time i will do it, who knows what extra ideas we get after one week
Old 24th July 2009, 23:12   #55
Thanked: 158 Times
Originally Posted by Tusker4x4 View Post
Hi Headers, Just wanted to knw how to waterproof the Starter Motor, Alternator & Diffrential nipples.
After the snorkel I think these will be the only 2 places that water can damage/stall the vechile in a OTR.
Pls let me knw the other points that needs to be taken care off and suggest the solutions
Redgs
Amit
Hi Tusker,
This is the reply we got from UBS sir,
Actually the breathers which come with spring loaded caps are not an all time protection from underwater fording. They do a temperory protection while crossing streams,etc.. But for longer duration under-water operations, the M38s had tubes connected from all the breather points to the intake manifold pipe, governed by a common flap open valve.. All the best.
Yours….. UBS
Old 25th July 2009, 00:12   #56
whicked wheels's Avatar
Thanked: 56 Times
Here are some pics of my snorkel, made use of a cielo snorkel and pvc pipes.
whicked wheels is offline   Reply With Quote
Old 19th May 2010, 10:48   #57
Jaggu's Avatar
Thanked: 8,858 Times
Originally Posted by DKG View Post
9. All our Jeeps have the air intake from inside the engine. Which means the air that is going into the carb is already rarified so the engine will run hotter. One of the things I want to do is connect the aircleaner intake to a large pipe and have it suck in fresh unheated air direct, maybe a snorkel. This should help engine run cooler
Exactly what i was planning to do! Venki has already done something like this, he has made a hole in the firewall and taken the tube out and is running a bolero type air filter in his diesel engine.
What would be the best upgrade for CJ3B filter from the modern gen filters from other jeeps. BD was supposed to give us some pointers but i guess he has forgotten about this with his tight schedules
Old 19th May 2010, 10:53   #58
DKG
DKG's Avatar
Thanked: 971 Times
My Tata 207 has a large filter (like the ones that exists in our Jeeps) with dust indicator and it connects to external air intake. Perhaps BD can tell us if this is appreopriate. Its for a 3 litre engine so should be fine for the hurricane. But we need to confirm this.
If you notice there is a sheet metal plate behind the grill bars and the radiator. That would be the ideal place for the pipe intake to be installed, perhaps angled down so that water doesn't get in
DKG is offline   Reply With Quote
Old 19th May 2010, 10:55   #59
Jaggu's Avatar
Air flow for diesel's will be more than petrol engines right? So i guess similar or slightly bigger diesel engine filters should work??
Old 19th May 2010, 10:58   #60
DKG
DKG's Avatar
Thanked: 971 Times
BD and Spike should be able to clarify this one Jaggu. I really wouldn't know. I am just assuming if its good enough for a 3 litre engine should be okay for our 2.2
BTW I've never studied the design of snorkels. How does that spout ensure water vapour/ rain doesn't get into the carb?
One more issue which I hope BD or Spike will clarify. If we create a slight ram air effect for the inlet into the carb would that enhance engine power and also help it run cooler because of unheated air?
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
DIY air intake snorkel - with photos Parm 4x4 Technical 15 28th March 2013 01:46
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
Mahindra Major 4x4 jeep- A/C & Power Steering, Diff. locks, Snorkel amit kumar 4x4 Technical 5 24th December 2009 10:22
MM540 Rs 80000 prkothan Hatchbacks 5 3rd May 2006 01:10
