Old 1st July 2010, 17:41   #76
pdev29's Avatar
Thanked: 258 Times
Guys how do i go for snorkel in Gypsy??
how can i protect the following items
1) Ignition Coil
2) Delco
3) Spark Plugs
anyone has Snorkel on a Carb gypsy??
Please help
pdev29 is offline   Reply With Quote
Old 1st July 2010, 20:12   #77
Tejas@perioimpl's Avatar
Thanked: 5,059 Times
1) Ignition Coil
2) Delco
3) Spark Plugs
Please help
I recall a certain Mr. Flying Ibrahim using tupperware and silicone glue to good effect!
Tejas@perioimpl is offline   Reply With Quote
Old 2nd July 2010, 11:28   #78
krishnathanthri's Avatar
Thanked: 41 Times
Hi Tejas@perioimpl,
Can you please post some pics and details of the Snorkel in your Jeep.
Krishna Thanthri
krishnathanthri is offline   Reply With Quote
Old 2nd July 2010, 11:48   #79
Originally Posted by krishnathanthri View Post
Hi Tejas@perioimpl,
Krishna Thanthri
My jeep is back at the workshop. Maybe next week as soon as i get my hands on her.
EDIT: See the EXAMM thread. There are a few pics
Old 4th August 2010, 13:46   #80
Hi Tejas@perioimpl,
Krishna Thanthri
Here are some pics of the snorkel. Taken post OTR, so there's muck everywhere!
http://www.team-bhp.com/forum/4x4-ve...ml#post1977469
Old 4th August 2010, 15:06   #81
Thanked: 41 Times
Did your snorkel head came along with the below highlighted part? or its a PVC plumbing material?
Below is my Snorkel Head.
Please advice.
I am planning to fit the Snorkel based on this design concept. (Thanks to Khan)
http://www.team-bhp.com/forum/4x4-te...ml#post1139856 (Snorkel for MM540)
Notice the thickness of the pipe used.
Krishna Thanthri
Old 4th August 2010, 15:18   #82
Mine came exactly how yours is. The pipe is metal and has been custom fabricated along with the flare to fit the snorkel head.
Old 4th August 2010, 19:16   #83
sreerajunnithan's Avatar
Default Snorkel
@Tejas and Krishna,
Is that hole which i marked with red circle? And what is the purpose of that? If it is a hole, then we have a desi substitute which looks exactly same like this.
--Sree--
sreerajunnithan is offline   Reply With Quote
Old 4th August 2010, 19:39   #84
It's a beveled slot made in such a way that air can enter but water can't. Why it's there, I have no idea. Thought about it lot but couldn't come up with a satisfactory answer. It's angled in such a way that it cannot be for the ram air effect for sure.
Old 9th August 2010, 17:13   #85
khan_sultan's Avatar
Thanked: 3,467 Times
A sneak peek of the snorkel on my Gypsy :-)
Pic courtesy: Rudra
Fabrication courtesy: Swastikviji & Prithvi
khan_sultan is offline   (1) Thanks Reply With Quote
Old 9th August 2010, 17:23   #86
Thanked: 57 Times
Attachment 402871
Pic courtesy: Rudra
Cool!!! where did you pick the Snorkel Head from?
davids4x4mm550 is offline   Reply With Quote
Old 9th August 2010, 21:29   #87
Thanked: 57 Times
Attachment 402871
Pic courtesy: Rudra
Hmmm, snorkel looks cool..
Is that a hard top BTW?
livyodream is offline   Reply With Quote
Old 9th August 2010, 21:55   #88
Thanked: 136 Times
So, a introduction to the "all new" Spidy has been made here!
And yes, that is a hard-top. Guess Khan has enough of those 'wet' drives on a rainy day.
The vehicle does have a very different look now, in flesh.
Only weak point, if it can be called that, that I see is the exhaust, even though at a raised level, is not raised enough if Khan does wade thru deep enough water. But, reckon its nothing that a experienced driver like him can't handle.
HappyWheels is offline   Reply With Quote
Old 10th August 2010, 15:08   #89
Thanked: 41 Times
And where did the custom bumper go?
Post some more pics of the snorkel.
Was the fitting done as per the below post
Krishna Thanthri
Old 10th August 2010, 19:15   #90
pdev29's Avatar
Thanked: 258 Times
Khan,
more pic please (if possible pics inside the hood will help)
what happened to your bumper??
MM540 2wd to MM540 4wd and Restoration Rajith 4x4 Vehicles 48 1st October 2015 23:45
DIY air intake snorkel - with photos Parm 4x4 Technical 15 28th March 2013 01:46
MM540-4WD wish list - what you really want in your MM540-4WD? DHABHAR.BEHRAM 4x4 Vehicles 299 7th January 2010 13:02
Mahindra Major 4x4 jeep- A/C & Power Steering, Diff. locks, Snorkel amit kumar 4x4 Technical 5 24th December 2009 10:22
MM540 Rs 80000 prkothan Hatchbacks 5 3rd May 2006 01:10
